Stochas open-source sequencer software (ehemals von Audio Vitamins, jetzt vom Surge-Team)
IvoFX
Habe keinen Thread dazu gefunden. Ausprobiert habe ich die software ebenfalls nicht, hatte sie mir gebookmarkt und vergesssen.
Klingt aber interessant. Hat jemand damit Erfahrung? Klingt ein bischen wie Elektron als software.
Wenn es eine gute midi Implementation hat würde es vielleicht sinn Machen das auf einer raspi laufen zu lassen, mit nem touch-screen.
Features
Stochas is at it’s core a step sequencer, which means it generates MIDI notes. As such it does not generate any sound of it’s own but can be used to sequence other plugins and/or hardware synthesizers. Although it can be used for basic step sequencing, it’s main function is to provide randomness to the step sequencing process. It does this in a few ways:
  • Randomly determine whether a note should be played or not (create more dynamic and varied drum patterns)
  • Randomly choose between two or more notes to play at a specific time (create random or semi-random melodic or drum lines)
  • Add slight timing randomness to notes so that they play slightly before or after their position
  • Add randomness to velocity and length of notes
In addition to the randomness features, it offers a wealth of features:
  • Suitable for both drum and melodic programming
  • Live performance features - Most features can be controlled by MIDI so that you can mute/unmute layers, switch patterns, change timing, transpose notes, etc.
  • Polyrhythms - Create up to 4 simultaneous layers with different time signature, playback speed and/or number of steps per layer.
  • Patterns - switch between patterns during playback for more variety.
  • Timing - Parts can be played at eg half-time or double-time, etc
  • Groove and humanization - Steps can be individually shifted off the grid. Basic swing can be applied, as well as grooves. Grooves can be imported from MIDI files.
  • Chords - quickly select and add chords to your sequence
  • Note customization - Select which MIDI notes are visible in your grid, and even customize the names (useful for drumkits). These customizations can be imported/exported. In addition you can select from standard scales to make it easy to program in melodies.
  • Chain mode allows procedural programming (e.g. “if this note plays/doesn’t play then always/never play this other note”)
  • Record incoming MIDI to the grid
  • Themable interface
https://www.youtube.com/watch?v=PRXUt9Q9EB0
https://www.youtube.com/watch?v=Wyx8cz7oxLI&t=691s
Ja, schließe mich an. Sehr interessant. Hat das Teil jemand im Standalone-Betrieb syncen können? Hab gerade alles probiert aber Stochas akzeptiert die Clock vom Circuit nicht. Im Auto-Modus rennt er einfach los und Instant passiert nix (?)
gewagtes experiment, dem user eine kästchen/pattern/parts/pianoroll/spuren oberfläche dafür zu präsentieren, obwohl es eigentlich was ganz anderes macht.
aber schön, dass das jetzt free und open ist, viel besser als es zu vergessen. :)
