Outer Space Sounds Mostro Fm Synth
https://outerspacesounds.com/mostro/
  • It is a 4 voice polyphonic synthesizer each voice having its own envelope, LFO and sub oscillator.
  • The voices are composed of a sinusoidal carrier/modulator system where the carrier modulator ratio, the modulation index, and the feedback can be controlled from the interface.
  • It has a delay unit and a glide control.
  • It has an internal memory to store up to 100 presets.
  • It has MIDI in and out connections so it can be controlled via external hardware.
  • It has a one octave keyboard that when set to monophonic mode can be adjusted to play different scales (from chromatic to exotic scales) and in polyphonic mode can play chords in different keys.
  • The MOSTRO is packed in a wooden chassis with a painted steel cover.
