darsho
Sö Sünteßeisör !
http://www.modormusic.com/
https://www.facebook.com/modormusic
Specifications
Modor NF-1
Polyphony
8 voices
Memory
256 patches, all factory presets overwritable
Connections
9V, 600mA adapter connection, positive voltage on center pin
MIDI IN/THRU/OUT connections, 3x 5-pin DIN connection
Audio Left and Right outputs, 6.35mm mono jack
Sustain switch, 6.35mm mono jack
Volume/modulation pedal, 6.35mm stereo jack
Front panel controls
42 rotary knobs
20 switches
1 rotary encoder control
1 Power switch/volume knob
Display
16x2 green backlit LCD display
Osc section
3 identical fully independant oscillators
10 waveforms:
SAW: pulse width modulation sawtooth wave
SQU: pulse width modulation square/pulse wave
TRI: pulse width modulation triangle wave
SYNC: sounding like a oscillator-synced wave
ADD: additive harmonics
SONAR: resonant bandpass filtered noise
WIND: wind instrument noise
ARC: arcade game style noise
FM: sinus FM pair
FBFM: feedback sinus FM pair
Filter section
12dB/oct resonant filter switchable as lowpass, hipass, bandpass or bandstop (notch)
Formant filter with 3 morphing vowels, 10 vowel presets and user controllable formant frequencies
Effects section
"Comb filter" effect section to create chorus, flanger, ... effects
Delay effect section to create echo effects
Modulation section
4 3-stage envelopes, 3 level settings and 4 time settings
2 switchable LFO's with TRI/SAW/SQU/SIN waveforms, 1 TRI-LFO connected to modwheel, 1 random S&H with lowpass option
7 user-defineable modulation lines, 16 source signals, 59 destination parameters
MIDI
Full realtime MIDI control of all sound parameters
Pitch Bend, Modwheel (CTRL#1), Expression pedal (CTRL#7), Velocity and Aftertouch can be used as modulation sources
Measurements
Width: 440mm without rack ears, 480mm with rack ears (19")
Height: 267mm (10.5"/ 6U)
Depth: 40mm (front) - 80mm (back)
Rackmountable
Height: 6 rackunits
Rack mounting ears included
Recessed backside connections to ease rack mounting (no lost rackspace above)
Accesoires
Manual
230V AC power adapter
Wooden side panels
Rack mounting ears
