U-HE RePro One
Den Repro werde ich bei einem sale auch mal auf der Liste haben, bis dahin spiele ich immer mal wieder das Zebra 2 aus dem letzten sale.
Es lohnt sich schon.
Der Repro 1 bringt auch echt tolle Drum Sounds. Ist mir mal aufgefallen.
Daher hoff ich ja das von U he auch mal ne coole Drummaschiene in der gleichen Sound Qualität wie der Repro 1 kommt.
Vielleicht im Style und Bedienung wie der HG Fortune Vst Drum Burst. Repro Drummaschiene oder so.
Das wär noch was. ;-)
Release notes: Repro
Updated with every release (beta versions and latest builds not included)
December 10, 2024
Repro 1.1.3 (revision 16797)
MPE Update
Improvements
  • Supports the latest macOS versions (Sonoma/Sequoia)
  • Support for CLAP
  • Native Apple silicon support for Pro Tools (AAX)
  • VST3 SDK updated to 3.7.8
  • MPE support for polyphonic presets
  • MPE tag added to preset browser
  • Key control (experimental feature)
  • Doubled number of modulation slots
  • Added Mod Wheel range sliders to Repro-1
  • Mod Wheel now constrained to MIDI CH1 in Wheel Mod section
  • FX panel positions now match FX signal flow
  • Hiss Mute option added to Velvet
  • Improved GUI performance
  • Improved dialog handling
  • Added 50% & 60% GUI scaling options
  • VST2 > VST3 migration support for hosts using the IPluginCompatibility interface
  • Linux install-script improvements
  • Linux version now supports MTS-ESP microtuning
  • Browser: added option to show/hide folders
  • Browser: saving search results now supports drag & drop
  • Browser: save dialog description and usage fields now scroll while entering text
  • Browser: drag & drop folders onto smart folders to assign tags
  • Improved parameter automation in Pro Tools
  • Improved latency compensation during MIDI event scheduling
  • Registration dialog automatically purges unsupported characters
  • Windows installer comes with an uninstaller
  • Windows installer remembers last used options
  • Windows installer blocks installation to ProgramData location
  • Twitter link replaced with Mastodon in u-he menu
Fixed Bugs:
  • Fixed: distortion effect could produce aliasing
  • Fixed: performance bottleneck on AMD CPUs
  • Fixed: FL Studio randomly freezing while selecting or playing presets
  • Fixed: S&H clock behaving erratically while host playback was running in FL Studio
  • Fixed: VST2 was sorted as effect plugin in Reaper on Linux
  • Fixed: VST3 producing stuck notes in Digital Performer
  • Fixed: VST3 crashes in Digital Performer related to plugin GUI
  • Fixed: VST3 synth plugins falsely reported inputs to host
  • Fixed: sustain pedal held just one note of a chord if MPE was active in Bitwig
  • Fixed: dialogs could appear behind plugin GUI in Cubase (Windows only)
  • Fixed: it was possible to open the same dialog window twice; this could lead to a crash
  • Fixed: Windows UI scaling was messing with dialog positioning
  • Fixed: using CMD+A in dialogs made the GUI disappear in Logic
  • Fixed: aborted preset save operation could lead to wrong metadata being displayed in the inspector
  • Fixed: using the "duplicate" option in the browser could crash if permissions were missing
  • Fixed: Renoise no longer needs the "enable keyboard" option for menus to work
  • Fixed: plugin focus no longer needed for dropdown menus to work (Mac only)
  • Fixed: problem when loading the init preset immediately after loading the plugin (Mac only)
  • Fixed: plugin stayed mono when using the "Mono > Stereo" option in Logic under native silicon
  • Fixed: GUI glitch when switching to smaller GUI size (Pro Tools only)
  • Fixed: problem when automating parameters with identical names (Pro Tools only)
  • Fixed: preset search input field did not receive mouse input (Pro Tools only)
  • Fixed: VST3 produced stuck notes when using the computer keyboard to play notes in FL Studio on Mac
  • Fixed: scroll wheel not working on second display under some conditions (Windows only)
  • Fixed: installer now scaled correctly on high-resolution displays (Windows only)
  • Fixed: preset overwrite dialog was not showing up (Linux only)
  • Fixed: default author was set to preset name in presets (Linux only)
  • Fixed: auto-versioning feature wasn't working (Linux only)
  • Fixed: right-click preset selection frame wasn't disappearing (Linux only)
  • Fixed: input field was empty when editing preset search result (Linux only)
  • Fixed: double-click on menus could lead to crash (Linux only)
  • Fixed: dialogs always opened at the left edge of the screen (Linux only)
  • Fixed: dialogs could be opened multiple times (Linux only)
  • Even more small fixes and improvements
Special Notes:
  • Key control is an experimental feature. You can join the discussion over at KVR
  • This is the last version that includes VST2 support on Mac, Windows and Linux.
  • This is the last version including 32-bit support on Windows.
  • AAX and CLAP versions are 64-bit only.
