Holz
Salud!
Neues Beta-Update im DSI Forum:
http://dsiforum.org/viewtopic.php?t=4727
Main OS 1.3.0.12
Extended bar count to 8 bars per beat
Added new quantize value of 'Off' which allows unquantized recording that automatically populates the 'delay time' variable based on when the step was recorded
Note that there are not advanced editing features at this time so there is no easy way to quantize everything at once. This will be added in a later version
Added system variable for Mute/Solo behavior that allows you to mute only the sequencer or have it mute/solo both sequencer and live playback
Added system variable for Sound Slider Mode allowing you to control sounds with the sliders in realtime
Note: This does not change recording the params, they are still step only
Sounds now hold over beat transitions
Added numbers to sample list for Osc 3/4
Added quick navigation through categories in Osc 3/4 sample selection: hold 'shift' and use the shape or soft encoder assigned to shape to navigate through categories
Improved pot hysteresis when pad function changed and pot has not been touched
Fixed bug: Sequencer out incorrectly stealing a voice
Note: For now, any sound assigned to the MIDI Sequencer channel does not trigger sounds in the Tempest, only external
Fixed bug: SPP handling incorrect
Fixed bug: When swing set to system soft encoders controlling swing param not functioning
Fixed bug: Pitch wheel not reset on beat loads
Klasse Entwicklung. Ich liebe die Kiste von Tag zu Tag mehr...
Main OS 1.3.0.12
