Neues Squarp Hapax OS 2.0 ist da
Der Hapax Sequencer bekommt ein neues großes OS 2.0 - darin sind eine Menge neue Dinge und bessere Bedienung.
Übrigens (wie in der letzten SequencerTalk Sendung - Deluge hat auch ein massives neues OS - das Community OS ist da und bietet eine Menge Neues. Siehe SequencerTalk 192
HapaxOS 2.00 beta A
December 7, 2023
New features
  • GLOBAL: 16 patterns per track (instead of 8)
  • GLOBAL: AUTOLOAD last project saved
  • GLOBAL: new mode MIX/MUTE
  • REC: multitrack recording, cf. MIX/MUTE mode
  • EFFECTS: new FX ECHO
  • EFFECTS: new FX OUTPUT
  • AUTOM: new ALGO CURVES
  • TRACK MODE : export pattern to midi file, import midi file to pattern
  • STEP: follow needle
  • STEP: note preview when adding a step (on STOP)
  • STEP: quick step length with 2 fingers
  • STEP: new MATH param NO FX (the event will bypass the FX chain)
  • STEP POLY : adds ALGO CURVES pitch destination
  • STEP POLY/DRUM : improved ALGO CURVES UX and adds more curves and parameters.
  • PATTERN : tracks STOP
  • PATTERN : pattern follow actions
  • PATTERN : custom pattern colors
  • PROJECT: pScale stick up / stick down / filter
  • SETTINGS : Track latency compensation
  • SETTINGS : more assignable actions for pedal
  • SETTINGS : RETRIG gate outputs
  • SETTINGS : new option SYNC IN > CLOCK SOURCE > MIDI AUTO DETECTION
  • LIVE: new parameter to select velocity of the matrix pads
  • LIVE: new parameter to select the RGB view (show notes in pattern, show scale in chromatic view)
Bug fixes
  • SAVE AS or LOAD was randomly unclickable
  • Track quantize was not reset after a NEW PROJECT
  • Step rotate/move left/right was not displayed on leds
  • Overall stability improvements
Ergonomics & Misc.
  • SETTINGS MISC: new SCREEN sub-menu, for anti-flicker options
  • PALETTE : choose your color with HSL instead of RGB
  • screensaver
  • SAVE/LOAD : project browser now support DELETE+CLICK to delete a project
Breaking changes
  • STEP: Selections now require two HOLD-pad actions. Quick presses are now used for the "quick step length" feature.
HapaxOS 2.00 beta B
December 8, 2023
Bug fixes
  • MIDI I/O: USB outputs never sent ALL NOTE OFF / ALL SOUND OFF messages
  • 2ND+TRACK: impossible to load Instrument Definition files
  • 2ND+TRACK: clicking on QUANTIZE opened the MIDI export dialog
  • 2ND+TRACK: errors could occur during MIDI export
Ergonomics & Misc.
  • Midi monitor is now showing the input/output port of the message
