Specs:
# 4 drum modules (kick, snare, hihat, & perc)
# 1 Bass Synth module
# 4 Wav Layer sample players for use with each drum module
# Samples can be looped, reversed and start/end positions can be altered all in realtime
# Each module has it's own in-depth control panel
# X-Fade Sequencers for each drum module for mixing between 2 different beats
# Auto-Mix funtion for automatic BPM-Synced mixing between beats
# Amplitude and Filter/Pitch modulation sequencers for the Bass Synth
# LFO section for Bass Synth for modulationg the filter as well as synced pitch
# Arpeggiator for Bass Synth with portamento option
# Bass sequencer can be used for gated arps/leads or stepped sequences
# Random probability for each sequencer with 2 types of randomization
# Each sequencer can play at different speeds, directions or length
# Adjustable start/end positions for each sequencer
# MIDI options for triggering each sequencer
# Each drum sequencer can be assigned to be triggered by a seperate key
# Bass sequencer can be assigned to different octave ranges
# Host Sync function for running Cubik in sync with your host
# Drum Mixer with light up trigger analyzers
# Multiple audio outputs (channels 1-6)
# Mute/Solo switches for each module
# Delay section with damping, dotted and sync/manual rate options
# FX send control for each module
# Patch Randomization for select controls on each module
# 32 presets
