Anonymous
Bastl-Instruments-Knit-Rider-Eurorack-step-Sequenzer-Expander-Modul-doepfer-mfb
Knit Rider is a very versatile 6 voice trigger sequencer with a fast, modern workflow. There are 4 bars in one pattern, every bar has 16 steps, each of which has 4 sub-steps, which makes it 256 steps per pattern. And there are 64 patterns in total ! This allows you to create very detailed patterns while retaining the intuitivity and speed of classic 16 step sequencers. Use the bar buttons to navigate inside the 4 bars. Hold a certain step – the bar buttons will now show the substeps in that step – press the bar buttons to edit the substeps.
Active step feature allows you to set any number of steps you want to have independently for each voice (or for all voices at the same time). You can also deactivate individual steps in the middle of a sequence. All voices have mute feature and can be set to be in trigger or gate mode. You can also record the sequences by tapping on the voice buttons with adjustable quantisation. Jump feature allows you to repeat certain step of the sequence for all voices which is great for performance and non-linear playback of patterns. Knit rider can by master or slave when it comes to tempo and you can set the clock input ratio (it one clock is 1 substep, 2 substeps, 1 step or 2 steps). There is also FN button which gives you access to additional features for fast and effective workflow.
Frei nach google:
Knit-Reiter ist ein sehr vielseitiger 6 Stimme Trigger-Sequenzer mit einem schnellen, modernen Workflow. Es gibt 4 Bars in einem Muster, jede Bar 16 Stufen, von denen jede 4 Teilschritte, die es 256 Schritten macht pro Muster hat. Und es gibt 64 Muster in total! Damit können Sie sehr detaillierte Muster zu schaffen unter Beibehaltung der Intuitivität und Geschwindigkeit der klassischen 16 Step-Sequenzer. Verwenden Sie die Tasten, um bar in den 4 Bars zu navigieren. Halten Sie einen bestimmten Schritt - die Leisten-Schaltflächen werden nun die Unterschritte, dass der Schritt - Drücken Sie die Tasten, um bar die Unterschritte bearbeiten.
Aktiver Schritt Funktion können Sie eine beliebige Anzahl von Schritten können unabhängig für jede Stimme (oder für alle Stimmen zur gleichen Zeit) haben möchten. Sie können auch einzelne Schritte Deaktivieren in der Mitte einer Sequenz. Alle Stimmen haben Mute-Funktion und kann so eingestellt werden, um in Trigger- oder Gate-Modus betrachtet werden. Sie können auch die Sequenzen aufzuzeichnen, indem Sie auf den Voice-Tasten mit einstellbarer Quantisierung. Jump-Funktion können Sie bestimmte Schritt der Sequenz für alle Stimmen, die große für Leistung und nicht-lineare Wiedergabe von Mustern zu wiederholen. Strick Fahrer kann durch Master oder Slave, wenn es um Tempo geht und Sie können den Takteingang Verhältnis eingestellt (es einen Taktschritt 1, 2 Unterschritte, 1 Schritt oder 2 Stufen). Es gibt auch FN-Taste, die Sie Zugriff auf zusätzliche Funktionen für eine schnelle und effektive Arbeitsabläufe ermöglicht.
Frei nach google:
