lilak
liste mal ein paar beispieltracks dazu ... von lfo kenn ich vor allem das hier, die bassline ist ein K1? die pads klingen nach eps ...
hier ist noch ein interessantes zitat von autechre zum eps. ich nehme mal an die reden vom eps16+. umprogrammieren ist immer gut! muss allerdings älter sein weil inzwischen machen die ja nur noch in MAX, leider.
AUTECHRE ON ENSONIQ SAMPLERS
Sean: "We use modified software on the sampler for live work. We found some nerd in America who writes interesting software."
Rob: "We were then able to take the sampler input and convert it to a thru for a start. Then we were able to use the software to write our own effects in the EPS."
Sean: "It's even better than the [newer, more powerful] ASR-10. You can select samples independently from the sequencer, which means that as the sequencer is running you can select your sample and edit it, turning it into a synth really. It's already got a decent OS in there, but it's really easy to modify as well.
Rob: "It's really only the American manufacturers, Ensoniq and Emu, that turn their gear into synths and not just sample playback machines."
Sean: "The EPS is just like using the Prophecy really. Everybody beats on about how smart the Prophecy is but we've been able to do that with samples for years. Much of the multiple LFO routings and the assigning of controllers to modulate controllers and so on, we can do on the EPS -- setting up quite elaborate patches on it really quickly. It's weird that Ensoniq is getting ignored in preference to Akai, which admittedly is a tighter more accurate sampler, but it still lacks a lot of scope for exploration, you can't really do a lot with it. With the EPS and the ASR-10 we're still finding things, like changing aspects of effects that you're not supposed to be able to alter."
Although when you originally bought the EPS you obviously didn't know what you know now.
Sean: "No, we bought it because we got a good deal."
Rob: "And it had on-board effects. We thought, 'it's only got two outputs but then it does have effects -- f**k it, we've only got this much money'. Before that the only sampler we had was 1.4 seconds worth on our Boss delay, so anything on top of that was a luxury."
Sean: "By necessity we've struck up a good working relationship with our samplers. The only current sampler that we would get, knowing what we know now, is probably the Kurzweil. It's the only thing that I've used that intrigues me.
Rob: "Emus as well, they seem to have a lot to them."
Sean: "Just in terms of the editability if you put a sampler into a synth you know you'll be buying all those synth facilities, whereas if you're just buying a sampler then that can be limiting. I think a lot of manufacturers still see the sampler as being limited in those respects, which is bullshit, considering the amount
of DSP chips that they pack in there. There's so much you can potentially do with them."
