Dave Smith Prophet 6 -> Sequential ist wieder da!
Re: Neues von Dave Smith
RUNDE SACHE :supi:
wieso nicht gleich so ..
Jetzt können alle Anderen Hersteller einpacken und in den Ruhestand gehen. :)
Ah okay. Gearslutz ist seit einiger Zeit überfordert.
Meine Fresse, sieht der gut aus und klingt auch noch so. Super Zug von Yamaha mit den Namensrechten, wirklich großartig - Pro 2 freut sich auf Gesellschaft, das könnte mein Exit-Synth werden... ;-)
DSI Sequential Prophet 6
ja wie, haben wir noch gar keinen thread zum prophet 6?!?
Vintage with a Modern Twist
The Prophet-6 is Dave Smith’s tribute to the poly synth that started it all—the Sequential Prophet-5. But it’s not simply a reissue of a classic. Rather, as Dave puts it, “It’s the result of our effort to build the most awesome-sounding, modern analog poly synth possible.” The Prophet-6 takes the best qualities of the original Prophet-5—true voltage-controlled oscillators, filters, and amplifiers—and adds enhancements such as studio-quality effects, a polyphonic step sequencer, an arpeggiator, and more. The result is pure, unadulterated analog tone with the stability and reliability of a state-of-the-art modern synth.
Classic Tone, Classic Vibe
Central to the warm, punchy sound of the Prophet-6 are its two newly-designed, discrete voltage-controlled oscillators (plus sub-oscillator) per voice. Continuously variable waveshapes provide the tonal palette with triangle, sawtooth, and variable-width pulse waves. There are two discrete filters per voice—a four-pole, resonant, low-pass inspired by the original Prophet-5 filter, and a two-pole, resonant, high-pass filter. Voltage-controlled amplifiers complete the all-analog signal path.
Dual Effects
The dual effects section provides studio-quality reverbs, delays (standard and BBD), chorus and phase shifter. While the effects themselves are digital, with 24-bit, 48 kHz resolution, a true bypass maintains a full analog signal path. There’s also an independent stereo distortion effect, which is 100% analog.
Poly Mod and Poly Step Sequencing
Also present from its classic predecessor is a Poly Mod section, with enhancements. True to the original, modulation sources are filter envelope and oscillator 2 (both with bi-polar control). Destinations include oscillator 1 frequency, oscillator 1 shape, oscillator 1 pulse width, low-pass filter cutoff, and high-pass filter cutoff. Another welcome reprise is Unison mode, which features configurable voice count (1-6 voices) and key modes. The polyphonic step sequencer allows up to 64 steps and up to 6 notes per step. You can create sequences polyphonically, with rests, and sync to an external MIDI clock. The full-featured arpeggiator can be synced to external MIDI clock as well.
Easy to Program
The knob-per-function front panel offers instant access to virtually all Prophet-6 functions. Included are 500 permanent factory programs in 10 banks of 100 programs. In addition to these, you can create and save up to 500 user programs of your own. Toggling off the Preset button enables live panel mode, in which the sound of the Prophet-6 switches to the current settings of its knobs and switches. In this state, what you see is what you hear.
Easy to Play
All of this awe-inspiring sound is packed into a four octave, semi-weighted keyboard with velocity and channel aftertouch that’s an ideal combination portability and power for the project studio or the gigging musician.
Prophet-6 Specifications
Oscillators
Two newly designed, discrete VCOs per voice
Continuously variable wave shape (triangle, sawtooth, pulse, square) per oscillator
Pulse width per oscillator
Hard sync: oscillator 1 syncs to oscillator 2
Triangle sub-octave generator (oscillator 1) per voice
Low frequency mode (oscillator 2)
Keyboard tracking on/off (oscillator 2)
Oscillator slop amount for increased tuning instability, from subtle to extreme
Mixer
Oscillator 1 amount
Oscillator 1 sub-octave amount
Oscillator 2 amount
White noise amount
High-Pass Filter
Two-pole, resonant, high-pass filter per voice
Bi-polar filter envelope amount
Velocity modulation of envelope amount
Keyboard tracking: off, half, full
Low-Pass Filter
Four-pole, resonant, low-pass filter per voice, inspired by the original Prophet 5 filter
Filter can be driven into self-oscillation with the Resonance control
Filter Envelope
Four-stage (ADSR) envelope generator
AMPLIFIER ENVELOPE
LOW FREQUENCY OSCILLATOR
Five wave shapes: triangle, sawtooth, reverse sawtooth, square, and random (sample and hold)
Clock sync (internal or external MIDI clock)
Initial amount
Mod destinations: oscillator 1 frequency, oscillator 2 frequency, oscillator 1 and 2 pulse width, low-pass filter cutoff, high-pass filter cutoff
POLY MOD
Sources: filter envelope (bi-polar) and oscillator 2 (bi-polar)
Destinations: oscillator 1 frequency, oscillator 1 shape, oscillator 1 pulse width, low-pass filter cutoff, high-pass filter cutoff
AFTERTOUCH
Source: channel (mono) aftertouch with bi-polar amount
Destinations: oscillator 1 frequency, oscillator 2 frequency, LFO amount, amplifier envelope amount, low-pass filter envelope amount, high-pass filter envelope amount
CLOCK
Master clock with tap tempo
BPM control and display
MIDI clock sync
ARPEGGIATOR
Selectable note value: 16th note, 8th note triplet, 8th note, dotted 8th note, quarter note
One, two, or three octave range
Up, down, up/down, random, and assign modes
SEQUENCER
Polyphonic step sequencer with up to 64 steps and rests
EFFECTS
Stereo analog distortion
Dual, 24-bit, 48 kHz digital effects, including: reverb (room, hall, plate, spring), delay (full bandwidth digital delay and emulated bucket brigade and tape delays), chorus, and phase shifter
Delay sync
True bypass maintains fully analog signal path when digital effects are off
PERFORMANCE CONTROLS
Full-sized, semi-weighted, 4-octave keyboard with velocity and aftertouch
Backlit pitch and mod wheels
Spring-loaded pitch wheel with selectable range per program (1 to 12 semitones up and down)
Transpose controls for an 8-octave range
Hold switch latches held notes on
Polyphonic glide (portamento)
Unison (monophonic) mode with configurable voice count, from one to all six voices, and key modes
Preset switch: when off, the front panel is live; what you see is what you hear
PATCH MEMORY
500 user and 500 factory programs in 10 banks of 100 programs each
Direct program access, including Prophet 5-style single-button access to the current set of 10 programs
IN/OUT
Left/mono and right audio outputs (2 x 1/4” phone jack)
Headphone output (stereo, 1/4” phone jack)
MIDI in, out, and thru ports
USB for bidirectional MIDI communication
Low-pass filter cutoff expression pedal input
Volume expression pedal input
Sustain footswitch input
Sequencer start/stop footswitch input
POWER
IEC AC power inlet for internal power supply
Operates worldwide on voltages between 100 and 240 volts at 50 to 60 Hz; 30 watts maximum power consumption
PHYSICAL SPECS
32” L x 12.7” W x 4.6″ H (81.3 cm x 32.3 cm x 11.7 cm)
20.0 lbs (9.5 kg)
Walnut end panels and trim
Re: dsi prophet 6
ach da.
naja, hatte mich auch schon gewundert...
ist aber nicht sehr sprechend benannt, der fred.
Re: dsi prophet 6
Für mich bis jetzt das Gerät mit dem grössten Habenwill-Faktor dieser NAMM.
Hoffentlich klingt der auch so schön, wie er aussieht.
Einziges (kleines) Manko für mich: Könnte eine Oktave mehr sein.
Ansonsten: Wahnsinn!!
Für mich das bisherige Highlight der NAMM
+1
und das soll bei den bisherigen Sachen wirklich was heißen.. die 70er sind ausgebrochen!
erinnert mich an die serie life on mars.... i had an accident and woke up in 1973,
am i mad or in a coma? Jahreszahl wäre noch zu korrigieren, aber sonst...
Re: dsi prophet 6
Excellent !!!!
Aber sind denen die Tasten ausgegangen, oder das Wallnußholz ?....
Das wär doch was, ein Synth wo man unter- oder oberhalb "modulweise" Octaven anstückeln kann....... :lol:
Na ja, und 6 Stmmen, vielleicht ist da hinten eine Buchse wo man zu Simmenvermehrung noch was einstöpseln kann.
Für Sergej Rachmaninov ist die Kiste jedenfalls nicht geeignet, esseidenn man hat 2 Stück übereinander.............
Re: dsi prophet 6
ich glaube, wir koennen da hier jetzt zumachen bitte.
Als Dave Smith den Pro 2 vorstellte, hatte ich gleich das Gefühl, dass der Synth was ganz Besonderes wird. Blind bestellt, was ich sonst wirklich nie mache - und es ist ein Volltreffer. Hier bin ich mir noch viel sicherer, das wird ein All Time Favorite, ein Klassiker!
Glitzert ganz schön schon schon! Weiß nicht, ob's schon erwähnt wurde, aber hieß das nicht früher *Sequential Circuits* ?
Re: SCI Prophet 6 (nicht DSI)
*doch* dsi! die firma heisst immer noch so.
ist ja schoen, dass er den markennamen 'sequential' zurueck hat, aber der anbieter heisst immer noch 'dave smith instruments'! einfach mal nen blick aufs anbieterlogo werfen (oder auch nur auf die url): http://www.davesmithinstruments.com/product/prophet-6/
also wer auch immer da gerade meinen thread umbenannt hat: bitte zurueckaendern.
oder meintehalben wegen der doppelung loeschen.
aber nicht einfach andererleute threads umbenennen, sowas tut man nicht!
also wirklich, wo sind wir denn hier?
[edit:] so, hab das mal grad selbst in die hand genommen - und muss mich dennoch sehr wundern.
ansonsten: diesen fred bitte zu machen und hier ueber das neue instrument von dave smith weiterdiskutieren. danke.
ich bin jetzt erstmal raus... [/edit]
sehr sexy - wenn der nicht von dave so plattgebürstet wurde wie die anderen sachen ist das ne echte willensprüfung. da mir keiner der dave-synths vom klang der vco´s und filter nur annäherd glaubhaft vermitteln konnte warum ich das nicht auch mit plugins machen könnte (nutze keine weil ich den rechner auslasse zum mucken) wage ich aber auch hier erstmal sehr zweifelnd zu sein.
klingts wie SCI bin ich sehr interessiert _ klingts nach dave werf ich für guten analogen sound doch lieber meinen virusTI an :mrgreen:
weine immer noch meinem proone nach :?
Geht mir auch so, aber Filter ist diskret, VCOs auch, neue Schaltungen. Das Demo klingt in meinen Ohren auch deutlich besser als was ich bis jetzt so von DSI kenne..
Re: dsi 'sequential' prophet 6
Frage: hatte der Prophet 5 nicht integrierte Schaltkreise für VCO und VCF? War da nicht stets die Diskussion wegen Chips, die nicht mehr hergestellt werden?
Und jetzt mit dem neuen Prophet 6 soll jede Stimme diskret aufgebaut sein?
Und was heisst eigentlich "diskret aufgebauter Schaltkreis" genau? Sind das nicht auch maschinell hergestellte Platinen mit Miniwiderständen/kondensatoren/dioden, die direkt auf der Platine angebracht sind (also ohne Drähte)? Zwar keine IC's, aber dennoch nicht reparabel mit Lötkolben? Diese Frage stelle ich mir auch bei Eurorackmodulen, wo gelegentlich auch von diskret aufgebauter Schaltung gesprochen und in der Regel gerne mal das doppelte des Preises verlangt wird im Vergleich zu den Modulen mit IC's. Oder auch das neue Audiointerface von Arturia das mit diskret aufgebauten Preamps wirbt.
Und wenn bei einem Fehler dann doch die ganze Voicecard ausgewechselt werden müsste, was ist dann der Vorteil? Höhere Entwicklungskosten für IC's?
Re: DSI Sequential Prophet 6
Im Prophet-5 werkelten CEMs und SSMs (rev2 Filter)
Diskret aufgebaut war nur der OB-X (nicht Xa)
Sorry, diskret muss nicht gleich besser heissen. Klingt aber trotzdem deutlich anders, insofern ich das auf youtube videos beurteilen kann. Einen Prophet 5 würd ich gerade wegen den Chips nicht mehr kaufen. Da wären mir die Service Kosten einfach zu hoch..
Edit: Davon haben mir auch ein paar eingefleischte Prophet-5 Servicetechniker davon abgeraten. Und wenn mein Servicetechniker des Vertrauens mir das so sagt, dann glaub ich ihm das auch ;-)
Re: Neues von Dave Smith -> Sequential ist wieder da!
Klar wird das der Pro 2 auch. Mein Prophet 08 muss für den Prophet 6 gehen. Eiserne Regel: kommt was Neues, geht was Vorhandenes- schnief. Kaufe und vor allem Verkaufe ja nicht so viel. Was für eine Kombi: Pro 2/Prophet 6 :adore:
