Casio probiert es wieder mit Synths...
Re: Casio baut wieder Synthesizer?
Da bin ich mal gespannt. Würde es Casio wünschen. Aber analog wird da wohl nichts kommen. Eher für die große Masse. Heute nacht wohl…
Muss ja auch nicht zwingend analog sein, gute klingende Digitale sind auch klasse...
Vielleicht auch nur ein Problem mit den Zeitzonen . wenn die NAMM am 19.01 startet ist es in Japan schon fast der 20.01 bezogen auf die USA. Vermutilch hat der Programmierer das nicht bedacht.
Heute gegen 15h sollte es dann aber losgehen.
Solarvent
The XW-P1 is a true performance synthesizer that allows users to create a wide array of sounds from many preset tones, including Solo Synthesizer, Hex Layer, and Drawbar Organ tones, as well as numerous types of internal PCM and Synth waves. The unit is also loaded with a full range of functions that are useful for live performances. Weighing only 5.4 kilograms and with a slimly designed body, the XW-P1 can be powered with dry cell batteries, making it possible to be played in a wide range of live settings—from the stage to the street.
Wide selection of preset tones ensures quick access in performances
■ 100 Solo Synthesizer presets can reproduce vintage analog synthesizer sounds
■ 50 Hex Layer presets layer as many as six tones for ensemble sounds
■ 50 Drawbar Organ presets can reproduce traditional Drawbar Organ sounds
■ A total of 420 PCM Melody and PCM Drum presets have been produced from samples of various instrument sounds including pianos, guitars, and drums
Special features make it easy for discerning performers to create sounds
■ A total of 311 internal Synth waves reproduce vintage analog synthesizer sounds
■ A total of 2,158 PCM waves are built in, including wave data from the CZ series, Casio’s best-selling digital synthesizers of the 1980s
■ Users can create integrated sounds by layering analog synthesizer waves and PCM waves
■ Users can produce original Hex Layer sounds by combining as many as six preset tones
■ Users can create their own Drawbar Organ sounds by using the nine sliders
Variety of functions useful for live performances
■ Users can assign performance setups for up to four designated keyboard zones by using the Performance function
■ The Phrase Sequencer lets users create and play back musical phrases to enhance their performances
■ The Step Sequencer allows users to create and play back a variety of rhythm patterns
■ The Arpeggio function can automatically play arpeggios just by pressing keys
Useful features for applications ranging from performance to music production
■ SMF data or audio data saved on an SD card can be played back while playing the keyboard
■ MIDI devices, microphones, audio players, and other equipment can be connected using the various input and output terminals
■ Portable audio equipment or MIDI devices can be placed on the designated rubber holding space
a multifunction keys enables users to assign essential functions for DJ performances to keys
Wenn ich schon "DJ" bei so nem Gerät lese, dann krisch isch plack.
Der zweite könnte interessant sein, aber es wirkt erstmal brutal nach Tischhupe.
So als hätte man gerne "Boutique" aber man will sich doch nicht so ganz von der treuen Tischhupenkundschaft trennen.
nein, sind 2 Synthesizer - hab die Specs jetzt da..
https://www.sequencer.de/blog/?p=12013
PM und Sample / Phrase Sequencer, 61 Tasten..
Der neue XW-G1 bietet Club-DJs in einem kompakten Einzelgerät tolle Funktionen für den Einsatz von Samples und Setups, Pattern, Phrases und Loops: – Step-Sequencer (16 Steps) für das Abspielen durchlaufender Patterns im Hintergrund – Phrase-Sequencer für das Aufrufen favorisierter Musikphrasen in Kombination mit Loops inklusive
der Möglichkeit zum Overdubbing – Sample-Looper für die digitale Aufnahme und das Loopen von Pattern und selbst eingespielten
Performances, Aufnahme erfolgt über die externen Instrumenten- und Mikrofoneingänge
Über den Controller werden Beat und Sounds ständig verändert, es lebe das Live-Looping! Dazu lässt sich die Tastatur beim DJ-Einsatz zum Antriggern von Funktionen nutzen – dies ermöglicht eine Steue- rung der coolen Club-Sounds des Groove-Synthesizers in Echtzeit.
____
Der XW-P1 ist ein Synthesizer, der speziell für die Kreation und Komposition von elektronischen Sounds und die professionelle Performance bei Live-Auftritten entwickelt wurde. Der neue Performance-Synthe- sizer liefert 620 voreingestellte Presets, einschließlich Solo-Synthesizer-Presets, mit denen die Sounds analoger Vintage-Synthesizer reproduziert werden können.
Ein echter Knüller ist die 6-fach Hex-Layer-Funktion – mit dieser werden dreidimensionale Klangwelten greifbar. Aus den vorhandenen Sounds können bis zu sechs Klänge übereinander gelegt werden; kom- biniert mit der Performance-Funktion lassen sich sogar neun Klänge layern. Hierfür werden auf der Tastatur vier Zonen gebildet – bekommt eine Zone den Hex-Layer-Sound zugewiesen, sind noch drei Zonen für weitere Sounds frei. Was für kreative Möglichkeiten!
Der neue Performance-Synthesizer von CASIO bietet viel Potenzial für phantastische Synthesizer- Sounds. Über vier frei belegbare Drehcontroller können unterschiedlichste Parameter in Echtzeit ge- steuert werden (z.B. Resonance, Cut-off, DSP etc.) Allein die fetten Klänge des Solo-Synthesizers – un- ter anderem viele CASIO Kultklänge aus den 80ern zum Beispiel aus der CZ-Serie – und die vollwertige Zugriegelorgel (9 Registerstufen) machen den XW-P1 zum nächsten CASIO Kultobjekt.
Step-Sequencer zum beliebigen Erstellen und Abspielen von Rhythmus-Patterns
• 100 verschiedene Rhythmus-Patterns sind bereits vorprogrammiert • Bis zu 100 selbst erstellte Rhythmus-Patterns können als User-Sequenzen abgespeichert werden • Für Improvisationen bestehender Rhythmus-Patterns stehen 16 Parameter/Knöpfe zur Verfügung • Mit der Chain-Funktion können bis zu 99 Rhythmus-Patterns zusammengefügt und als Loop
abgespielt werden
Phrase-Sequencer für die ultimative Groove-Performance
• Phrase-Parts aus 100 voreingestellten Musikphrasen lassen sich je nach Modus entweder einmalig oder als Endlosschleife abspielen
• Bis zu 100 individuell auf der Tastatur eingespielte Musikphrasen lassen sich als eigene Phrasen abspeichern
Nützliche Funktionen für das DJing
• Multifunktions-Buttons für die Zuweisung von wesentlichen DJ-Funktionen an spezielle Tasten • 420 Presets einschließlich Solo-Synthesizer- und PCM-Klänge für den schnellen Zugriff über
die Tastatur • Mit der Arpeggio-Funktion lassen sich durch einfachen Tastendruck automatisch Arpeggios
abspielen
Sample-Looper zum digitalen Sampeln von Sounds
• Mit dem XW-G1 lassen sich externe Sounds sampeln und als bis zu 19 Sekunden langer Loop abspielen, auch das Overdubbing ist möglich
• Gesampelte Sounds, die als eigene Klänge abgespeichert wurden, lassen sich über die Tastatur abspielen
Individuelle Soundkreationen für noch mehr Spielfreude
• Für das Kreieren eigener Sounds stehen eine große Bandbreite von Presets sowie interne PCM- und Synthesizer-Wellenformen zur Auswahl
• Verschiedene Input- und Output-Terminals ermöglichen den Anschluss von Audio-Equipment und MIDI-kompatiblen Geräten wie DJ-Ausrüstung und Musikinstrumente, für die Ablage der Kleingeräte (iPod u.a.) bietet das übersichtliche Gehäuse einen sicheren rutschfesten Platz
Hauptfunktionen Performance-Synthesizer XW-P1
Große Auswahl an voreingestellten Klängen für Direktzugriff im Live-Einsatz
• 100 Solo-Synthesizer-Presets für die Reproduktion von Sounds analoger Vintage-Synthesizer • 50 Hex-Layer-Presets für das Layern von bis zu sechs Einzelklängen zu voluminösen Gesamtsounds • 50 Zugriegel-Presets für die Reproduktion traditioneller Sounds einer Registerorgel • PCM-Melodie- und PCM-Drum-Presets (insgesamt 420), generiert aus Samples
verschiedenster Instrumente wie Pianos, Gitarren und Schlagzeugen
Profifunktionen für die einfache Soundkreation
• Reproduktion von Sounds analoger Vintage-Synthesizer mithilfe der internen Synthesizer- Wellenformen (insgesamt 311)
• Integrierte PCM-Wellenformen (insgesamt 2.158), einschließlich der Wellenformdaten der legendären Synthesizer-Klänge der CZ-Serie von CASIO
+++ PRESSEINFORMATION CASIO EMI +++ Norderstedt, 19. Januar 2012 +++
• Möglichkeit zur eigenen Entwicklung integrierter Sounds durch Schichtung von analogen Synthesizer- und PCM-Wellenformen
• Erzeugung originaler Hex-Layer-Sounds durch Kombination von bis zu sechs voreingestellten Klangfarben durch den Anwender
• Kreation eigener Zugriegel-Sounds durch Nutzung von neun Schiebereglern
Vielzahl an nützlichen Funktionen für die Live-Performance
• Performance-Funktion für die Zuweisung von Live-Setups auf bis zu vier Zonen der Tastatur • Phrase-Sequencer für die ultimative Groove-Performance • Mit der Arpeggio-Funktion lassen sich durch einfachen Tastendruck automatisch Arpeggios
abspielen • Step-Sequencer für das Abspielen von Begleitpattern und das Einbinden von Improvisationen
während der Live-Performance
Weitere Features für Einsatzbereiche von Live-Auftritt bis Musikproduktion
• Auf einer SD-Karte gespeicherte SMF- oder Audiodaten lassen sich jederzeit als Playback abspielen • Anschluss von MIDI-Geräten, Mikrofonen, Audiospielern und anderem Equipment über
verschiedene Input- und Output-Anschlüsse, für die Ablage der Kleingeräte (iPod u.a.) bietet das übersichtliche Gehäuse einen sicheren rutschfesten Platz
__
  • PM_Synthesizers_190112_fin.pdf
Moogulator schrieb:
es gibt 2 neue Synthesizer von Casio
Ach was :agent:
Wollte an sich nur wissen wofür das "PM" vor Synthesizer steht.Auch die Specs geben da nicht so viel preis.Vielleicht hab ich's aber auch übersehen.
Crabman schrieb:
Ach was :agent:
Steht für Pre-Menstruell.
Soll wohl den weiblichen Teil der Kundschaft anziehen.
Vielleicht wird der zweite ja ein Geheimtipp unter Beatbastlern, wie einst der Casio Rap-Man...
Irgendwie befürchte ich, das Teil geht völlig am Markt vorbei :roll:[/quote]
jap das geht aber so richtig vorbei.... raven max halt
Vermutlich hat man die Demos extremst am Markt vorbei… naja…
Und das mit PM, PD oder was auch immer ist natürlich Kappes, auch von mir das.
Würde ich jetzt nicht unbedingt so sehen.
Weisst du, welchen Markt die damit bedienen möchten...?
Man sollte vlt. das erst einmal als einen Schritt auf einen weite(re)n Markt von Casio ansehen,
auch wenn Casio bisher noch keinen Impulskauf damit bei mir ausgelöst hat 8)
Gruss
die Hex -layer funktion hört sich klasse an
auch einen internen step-sequencer begrüsse ich sehr (mein musik-pc ist seit ca.1 jahr kalt :mrgreen: )
aber dat ding is ja sowas von hässlich , da müssen noch boxen dranne um die optik ab zu runden :twisted:
na , mal schauen was dat so kosten soll :floet:
Und vor allem wie es dann wirklich klingt :lol:
Für Tasten-Leute im Hintergrund von Michael Wendler bis DJ Bobo, für Leute mit Hang zu 90s Euro Discopop in einer Box ... :mrgreen:
Aber so schlecht möchte ich es gar nicht machen...
Die meisten Leute hier im Forum dürften in der Tat nicht zur Zielgruppe gehören, aber für uns gibt es ja auch neues Spielzeug.
Sehe ich (leider) auch so.
Das Ding in dem Video ist quasi ein "Kronos, bzw. Jup80 für Arme" und spricht auch genau dieses Benutzervolk an.
Für den (zu erwartenden) Preis kann man sich sowas, wenn man noch keins hat, aber auch als Masterkeyboard hinstellen.
Aber da ist ja noch ein 2tes Gerät, vielleicht geht das mehr in unsere Richtung...
Die Neuen von Casio haben mit der CZ-/VZ-Serie so viel zu tun, wie der JP-80 mit dem JP-8. Im Prinzip hat Casio neues Spielzeugs für die Tischhupenfraktion entwickelt. Und das vielleicht gar nicht mal schlecht. Der Mythos der Casio-Synthesizer (insb. CZ-Serie) basiert sowieso nahezu ausschließlich auf einer späten Wiederentdeckung. Damals, als die Dinger aktuell waren (CZ-Serie) bzw. verbessert wurden (VZ-Serie), wollte die niemand kaufen. Dass dann doch noch welche über den Ladentisch gingen, lag am vergleichsweise niedrigen Preis. Ich denke, diese Erfahrung hat Casio geprägt und: So wie damals läuft's im Prinzip auch heute noch. Deshalb ist Casio aus meiner Sicht auch nicht in den Synthesizer-Markt zurückgekehrt. Der Begriff Synthesizer wird hier in einer weiten Definition verwendet, um die Tischhupe aufzuwerten. Das ist ok, da mit den neuen Tischhupen die zeitgemäße Performance in den Mittelpunkt rückt. Das ist wahrscheinlich der einzige Aspekt, der die Zielgruppe noch davon abhalten kann, ausschließlich mit Computer bzw. iPad zu produzieren. Mehr davon kann somit nicht schaden ...
Glaub das wird ein Motif für Arme.
Im sehr viel performance-orientierteren KSS-Forum auf Harmony Central sind sie lustigerweise alle begeistert von dem Teil..
Casio´s zielte schon immer auf den Low Budget Markt, das war in den Achtzigern so, und das ist es auch heute. Bei den Digital Pianos und den anderen Produkten war es nie anders gewesen. Die PD Synthese damals war auch nur eine Strategie die kostspielige Analog Produktion zu umgehen.
