accSone crusher-X 9 - granular plugin
The full list:
  • Adds VST3 support (64bit)
  • Adds Sidechain (2 extra live inputs) support for GCO and Envelopes (Adds 2 Sidechain GCO modes: Clean and Ring)
  • Adds 2 Global Grain Modulation Matrices (GMMs). Each have 4 individual configurable modulation slots (Mod 1-4). Each slot can modulate (or invert modulate) the Offset, Mod, Freq, Spread or Phase of a target Grain Modulation. All Modulation and Target switches smooth controlled by the Morph system. The UI shows all modulations on the affected Fader Controls.
  • Adds Atmos bed 7.1.2 Surround Mode and two additional that improves surround channel mapping for DAWs like Logic (5.1 Logic and 7.1 SDDS Logic)
  • Adds Generator LifeTime (G-Life) Grain Modulation. If the Generator Lifetime has been exceeded they can be revived with a new Respawn button, with MIDI-Note Events, a Level Trigger or with Quantization. Generator Life Time is indicated in the Grain View by a clock symbols
  • Adds Generator LifeTime (G-Life) Modulation Type to let Grain Modulations being controlled by the Generators "age"
  • Adds Generator LifeTime (G-Life) Scan Mode Type to let Grain Modulations Spline and Steps Modulations being scanned by the Generators "age"
  • Adds Grain Launch Scan Mode for Step and Spline Grain Modulations (single step move on each grain launch - supports advanced modulation algorithms). Attached also to "Morph to 0Hz" system.
  • Adds Grain Controlled MIDI (GCM) functionality. If enabled, each grain launch creates MIDI NoteOn and NoteOff events to control outboard MIDI devices in sync with the grain creation
  • Adds Direct MIDI Out selection in settings to send MIDI direct to external MIDI devices as many DAWs doesn't support MIDI Out routing for Audio Effect Plug-Ins
  • Adds a <Disable DSP> button to settings that could disable audio processing when a Grain To MIDI Mode is activated
  • Adds a real-time Windows Tilt functionality to squeeze and tilt Grain Amplitudes
  • Adds Grain launch counter indicator on Adore Panel
  • Adds UI Keyboard enablement for non-pitched MIDI modes
  • Adds a Level Trigger visual feedback in Left and Right Trigger Level Trackbar
  • Adds Audio File path in settings. All audio files that are contained in the Audio File path will be avail on DCO/GCO/Load Buffer selection Menus.
  • Adds MP3 Audio File support
  • Adds Normalization to Audio File import (DCO, GCO, Grain Buffer)
  • Adds 4 new GCO Modes: Clean Live Granulator Input, Live Granulator Input with GCO ringmodulation, Clean Sidechain, Sidechain with GCO ringmodulation
  • Adds GCO Spline shortcut button on Granulizer Panel
  • Adds Categories for the Patch selector
  • Adds coloring of active Grain Modulations in Grain Modulation Meters
  • Adds "Handover To Global" buttons for each Grain Modulation. The current Grain Modulation settings will be transferred to the desired Global Modulation so that it can be used to group with other Grain Modulations
  • Adds X/Y Grain Modulation Assignment Hints to PM-Field
  • Adds Playback Speed Fader in DCO Editor
  • Adds meaningful labels to plug-in mode parameters instead of just a number
  • Adds Keyboard Shortcut to Hints, streamlined Shortcut handling and adds shortcut for Granulizer Clear
  • Adds DCO Editor open button
  • Adds CC74 Grain Modulation Mode also for non MPE MIDI Modes
  • Adds an automatic open of the Envelope Follower Editors on Grain Modulation Mode selection
  • Adds more factory sounds
  • Optimizes Grain to MIDI Controller behavior - MIDI Channel and Controller Number Range are now adjustable
  • Optimizes speed of the DCO Waveform UI
  • Optimizes behavior of Buffer Load button to allow direct switching of Audio Files without switching back to Life Mode
  • Optimizes appearing of the Spline/Step Editor (on top of an already opened editor without removing the current editor)
  • Optimizes noise generation level
  • Optimizes Waveform display in Grain View so that non reachable samples beyond maximal delay lengths are not shown
  • Optimizes Level Panel layout
  • Fixes undo/redo all parameter automation send bug
  • Fixes bug loading a wav file with unknown chunks
  • Fixes crash that happened sometimes during loading of large audio files
  • Fixes not cleared grains in Grain View on longer Birth times
  • Fixes morph bug for continuous Grain Modulation Mod changes
  • Fixes plug-in parameter scaling issues for discrete parameters
  • Fixes a bug that caused a hang of longer grains on patch changes
  • Fixes a bug that caused a wrong erasing of the MIDI- or Parameter-Map while loading MIDI-Map file
  • Fixes a bug that sometime caused Release Controller not to work as expected
  • Windows: Fixes Shortcut Key issues with stand-alone VST wrapper
  • macOS: Adds M1 / Silicon native architecture support
Similar threads
