Glou Glou Flancher BBD Effekte | Synthesizer @ Sequencer-Forum
Lauflicht
Lauflicht
TR4ever
Glou Glou hat 4 verschiedene analoge, BBD-basierte Stereo-Effekte veröffentlicht, siehe auch Demo des "bright" Delays FL-5B hier im Thread: https://www.sequencer.de/synthesize...nd-demo-ohne-gesabbel-aber-mit-synths.171395/
Zitat von dort:
What’s Flancher ?
Flancher is a line of 4 different stereo, analog, voltage controlled pedals. They use BBD (bucket brigade device) chips running internally at 15V and are comparable to late 70’s chorus delay studio rack units such as Roland SBF-325 or Boss DM-100.
The FL9 and FL7 are geared towards pitch modulation such as chorus, flanger, vibrato, and quasi-ring mod sounds.
The FL5B and FL5D are delays (B stands for Bright, D for Dark).
There are subtle but significant differences between the two units in each pair.
The FL9 uses a 256 stage BBD, while the FL7 uses a 1024 stage BBD. More stages means more delay time, but also more noise.
The FL7 has more delay time available (from 1.5ms to 34ms), but the sound is more filtered. The FL9 has a much smaller range of times (from 0.4ms to 9ms), but can reach ultra-short times that the FL7 cannot.
These differences mean that the FL9 more suited for flanger sounds, while the FL7 is a more natural fit for chorus sounds.
The FL5B and FL5D both use a 4096 stage BBD, but apply it in different ways. The FL5D has a more lo-fi character overall: the tone is more filtered, there are more low-end frequencies, and the feedback is more prone to distortion.
The FL5D starts clipping with a 1V peak-to-peak signal, while the FL5B begins clipping at 2V peak-to-peak.
The FL5B has a range from 12ms to 470ms, with a maximum clean time of 280ms.
The FL5D has a range from 16ms to 630ms, with a maximum clean time of 350ms.
Sind alle basiert auf 2x Xvive MN3009 mit unterschiedlicher Stufenzahl und 15 V Betrieb. Headroom 1 V p-p oder 2 V p-p.
Wie ist das Teil den verglichen mit dem Meraki?
Ich empfand das Meraki als etwas düsterer im Klang, hatte aber auch die FL-5B (bright) Version. Je nach Variante hat das Meraki auch deutlich höhere Delayzeiten, was sicherlich ein wichtiger Faktor sein kann. Dem Meraki fehlen die CV-Schnittstellen, dafür lässt es sich per MIDI einbinden. Verarbeitung ist bei beiden Top
Danke Dir. Ich hab das Meraki ja hier und finde das unfassbar toll. Empfindlich am Eingang (vor allem mit den Sequentials), aber klanglich wie nichts anderes. Aber natürlich interessiert mich das hier geteste Teil. Etwas schade, dass man halt zwei Gerät aus einem gemacht hat wie ich finde. Aber Juut.
Ich habe mir die Flanchers 5B und 9 gegönnt.
Ich war seit einiger Zeit auf der Suche nach einem analogen Flanger – der sollte idealerweise echt stereo und CV-steuerbar sein. Die Auswahl ist da sehr übersichtlich… Ein SBF-325 entpuppte sich beim Testen/Abholen als defekt … Ich war schon kurz davor, mir zwei Komorebi zu kaufen als die Meldung über die Flanchers kam und …
... ich war selten so begeistert von einem Gerät wie vom Flancher 9. Er ist bis ins Detail praktisch durchdacht und es passt einfach alles.
Natürlich am wichtigsten: er klingt wunderbar.
Darüber hinaus:
Stereo rein und raus
Ein ziemlich mächtiger LFO (Audio-Bereich, Phasenverschiebung links rechts, die Überblendung von Dreieck nach Sinus scheint unspektakulär, ist aber super nützlich)
CV-Steuerung ALLER Parameter (ob das wirklich nötig ist, weiß ich nicht, aber haben ist besser als brauchen …)
Pedal-Interface
Dedizierte Potis für Dry + Wet sind praktisch
Formfaktor fast perfekt (es hätte für mich ruhig noch etwas größer sein können, aber es ist zum Glück weit entfernt von fummelig wie Eurorack)
Platzierung der Anschlüsse und Potis perfekt
Optionaler Ständer für bessere Ergonomie auf dem Tisch
Er liefert einen etwas klobigen Mult-Kaktus mit. Der tut’s, aber praktisch ist er nicht. Stackables sind sicher besser.
Die CV-Steuerung und der ungewöhnliche LFO machen ihn sehr flexibel und gemeinsam mit dem wunderbaren Grundklang wird daraus eine echte Waffe, die richtig viel Spaß macht.
