[quote:12c9acb590=*clapptomaniac*]bin grad dr
clapptomaniac schrieb:
The requested URL /produkte/mpc2500_techdata.html was not found on this server.
Ich bin aber gerade im einen anderen Forum auf diese Informationen gestoßen...
Product Description
The Akai Professional MPC2500 Music
Production Center combines a 64-Track MIDI
Sequencer with a 32-voice 16bit Stereo Digital
Sampler. The MPC is a rock solid <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uencing
and drum programming machine with 16
velocity and pressure sensitive rubber pads.
The unit allows you to sample more efficiently.
This composition center is contained in one
extremely powerful desktop unit.
Designed for professional audio production,
the MPC2500’s intuitive and ergonomic
interface makes it the ultimate user friendly
composition studio
Two internal effects processors can be used
simultaneously. This includes a wide range of
effects algorithms, such as reverb, bit
grunger, chorus, phasers, flying pan, 4-band
EQ, compressor, and a phase shifter.
Real-time control is provided by two note
variation sliders and two Q-Link knobs. Q-link
knobs can be separately assigned to allow
flexible, real-time performance control of a
wide variety of selectable parameters. These
parameters include level, pan, filter cut-off and
resonance, tuning, LFO(low frequency
oscillator) speed depth, all effect parameters
and more.
Each assignable Q-Link knob can generate
MIDI controller data so that all performance
information can be recorded and played back
from within a <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uence. The Q-Link
Sequencer allows cyclic modulation
programming.
Following the highly acclaimed MPC60 and
MPC3000, 2 MIDI inputs and 4 MIDI outputs
come standard enabling 64 external MIDI
channel operation. In addition, the
MPC2500 can individually control its onboard
sampler up to 64 Parts, allowing users to
assign a different program on each track.
A large LCD screen allows a clear view of
<a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uence data displaying features such as a
piano roll, or a drum machine 'grid'.
Continuous MIDI data can be shown as well
as edited graphically.
The MPC2500 comes with 16MB of onboard
memory which can be expanded up to 128
MB of RAM via the optional EXM128 memory
card.
The MPC2500 has the capability of an
optional internal 80GB Hard Disk and CD-RW
drives.
Positioning
Akai Professional, in its pursuit to remain the
leader of digital sampling technology has
released the MPC 2500. This unit designed for
professional audio production, offers drum
programming, <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uencing, and sampling
capabilities. Artists now have the luxury of
producing music with a compact music
composition center.
Applications
• Sampling and creating beats
• MIDI <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uencing
• Live Performance
Customers
• Hip Hop and R&B Musicians and
Producers
• Electronic Music Musicians
Dimensions & Weight
• Dimensions:
16.33”x 3.68 x 13.10’’- 415 x 93.5(MAX 139) x
332.9(Max 334
• Weight:
13.5 Lbs 6.15kg (Excluding drives and options)
MPC 2500
KEY FEATURES AND BENEFITS
1) Improved Akai MPC design
• Large graphic LCD display based on the friendly user interface of the MPC series
• MPC’s iconic “feel” and “groove”
• Velocity and pressure sensitive pads allow for expressive programming, with more pad banks
• New Features such as Chopshop, Patched Phrase, Grid Edit, Effect and LFO sync, Mixer Automation,
and Input Thru
• Expanded Pattern-based 100,000 notes, 64-track Sequencer and 64 external MIDI channels
• 32-voice full-featured 16bit sampler equipped with 16MB of RAM with ability to hold 128 RAM
2) Extensive connectivity
• Two MIDI inputs and four MIDI outputs
• Built-in USB Slave port for connection to a Windows or Mac OS computer
• Built-in 10 analog outputs
• 2 1/4” stereo analog inputs and outputs with 16bit/44.1kHz sampling
• Master/Slave synchronization capabilities: MIDI clock
• 2 Assignable Footswitch inputs
3) Sample Library Compatibility- Compatible with Akai MPC1000 Sequence, .wav, Program,
MPC2000/2000XL Sequence, .wav, SND, Program, MPC2500 Sequences, .wav, Programs,
MPC3000, Z4/Z8.wav and S5000/6000.wav
4) Extensive sound control
• Extensive sample editing that includes cut and paste, timestretch, slice, resampling etc, with waveform
display
• Dynamic resonant multi-mode filters, 2 envelope generators and 1 LFO for each of the 32 voices
• 2 Q-Link sliders and 2 knobs for real-time control over a wide variety of dynamic changes
5) Self-contained
• Optional user installable Internal hard drive to store custom sound libraries and <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uences
• Optional user installable CD-RW drive to load CD-ROM libraries, sample Audio CDs, and backup
personal data
MPC 2500
SPECIFICATIONS
SOUND GENERATOR
• Sampling rate 44.1kHz
• Memory capacity 16MB standard (11.5MB for sound memory), expandable to 128MB
• Recording time 136sec. (16MB, MONO), 24m28sec. (128MB, MONO)
• Memory expansion slot 1 x for optional EXM128
• Data format 16-bit linear
• Polyphony 32
• Dynamic filtering 2 x 2-pole filter per voice
• Filter type Low pass, Band pass, High pass
• Preset sound memory 5MB
• Number of programs 24
EFFECTS
• Effects 2 stereo effects and Master effect
Effect type Chorus, Flanger, Bit grunger, 4 band EQ, Compressor, Phase shifter, Tremolo, Flying
Pan, Reverb, Delay
• Master effect: 4 band EQ, Compressor
SEQUENCER
• Maximum events 100,000 notes
• Resolution 96 parts per 1/4-note
• Sequences 99
• Tracks per <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uence 64
• MIDI output channels 64 (16 channels x 4 outputs)
• Song mode 20 songs, 250 steps per song
• Drum pad 16 (velocity and pressure sensitive)
• Drum pad banks 4
• Sync mode MIDI clock
DRUM PADS:
• 16 velocity and pressure sensitive pads
• 4 pad banks
• 16 Levels: Velocity, Tuning
• Automated Pad Mixer (Level, Pan and FX send)
• Track Mute and Next Sequence features for live performance
DATA COMPATIBILITY
• MPC1000 SEQ, WAV, PGM
• MPC2000/2000XL SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
• MPC2500 SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
• MPC3000 SND (THRU Computer)
• Z4/Z8 WAV only
• S5000/6000 WAV only (THRU Computer)
• S1000/3000 No compatibility
MPC2500
SPECIFICATIONS
SOUND GENERATOR
• Polyphony 32
EFFECTS
Pan, Reverb, Delay
SEQUENCER
• Sequences 99
• Drum pad banks 4
DRUM PADS:
• 4 pad banks
DATA COMPATIBILITY
• Z4/Z8 WAV only
MPC2500
SPECIFICATIONS
Q-LINK
• 2 sliders and 2 rotary knobs
• Assignable to internal sampler controls: pitch, filter cutoff, resonance, LFO, attack, decay, and Assignable to internal
effects parameters
• Assignable to external Midi Controllers
GENERAL
• 240 x 64 dot graphic LCD w/back light
• Compact Flash (up to 2GB)
CONNECTIONS
• Record input (L and R) 1/4-inch stereo phone x 2, balanced -40dBu, input impedance 11k ohms;
• Max. Input level +10dBu
• Digital input RCA-pin x 1 S/PDIF
• Stereo output (L and R) 1/4-inch phone x 2 balanced +11dBu, output impedance 1k Ohms,
• Max. output level +22dBu
• 4 individual outputs 1/4-inch phone x 4 balanced +11dBu, output impedance 1k Ohms,
• Phones output 1/4-inch stereo phone x 1, 200mW / 100 ohms
• Digital output RCA-pin x 1 S/PDIF
• MIDI inputs 5-pin DIN x 2
• MIDI outputs 5-pin DIN x 4
• USB Slave connector x 1, USB MASS STORAGE CLASS support
• (You need Windows 2000/Me/XP or later version, or MacOS 9.x/10.x or later version.)
• Footswitches 1/4-inch phone x 2
POWER
• 100-240V AC, 50/60Hz
• Consumption: 70W max (with all options)
STANDARD ACCESSORIES
32MB Compact Flash card, Power cable, Operator's manual
OPTIONS
EXM128 128MB expansion memory card
MPC2500
