j3122
klasse, Du hast den Download direkt verlinkt! Vielen Dank!Firmware for download:
Folgende Updates: https://www.playtempera.com/support/Firmware for download: Tempera firmware 2.0 (released 25th June 2024)
Changelog
Version 2.0 (June 2024)
- Per-emitter FX send level: Adjust the amount of effects applied to each emitter for eg. better separation of percussive and tonal sounds. Layering complex sounds has become much easier.
- Double the amount of modulators: From 5 per voice to 10 per voice.
- Relative X and Y scrubbing: Easily grain-scrub in two dimensions across the touch grid surface. Perfect pairing for the Tempera concept.
- Adjustable LED and emitter colors: Personalize the look of your Tempera, including having better color separation for those of us with a different color perception.
- Improved onboard keyboard: The new chromatic piano-like keyboard layout has better usability and clear visual feedback for standalone operation.
- Quantized random grain detune: Grains’ random detune can now be quantized to fifths, octaves, or both, providing a natural shimmer or extra harmony.
- Reverb upgrade: The new reverb algorithm provides richer and smoother reflections, and faster diffuse properties. Perfect for lush and wide soundscapes.
- Modulator visualization: Modulators now provide improved visual feedback so it’s easier to get a clear picture of their behavior.
- Stable and reliable MIDI clock sync: Improved clock BPM detection, MIDI clock sync is now durable and reliable.
- Canvas quicksave: Save your project (“canvas” in Tempera lore) immediately with a quick and handy shortcut.
- New shortcut for emitter editing: Newly added shortcut makes it easier to edit, cycle and organize emitter configurations.
- New global MIDI channel parameter: Integrate Tempera easily into a bigger setup, while allowing for per-emitter MIDI channels.
- Delay upgrade: A dot mode is added, along with smoother filter coloring
- Bug fixes & polishing: The amount of bugs fixed, streamlining and polishing is too long to list.
- User manual: Online or PDF version
Tempera v2.1-beta1 :
- NEW parameter Align X under Spray X knob, which when turned off, allows to source grains "in between" the tracks.
Andre — heute um 19:43 Uhr
Dear friends and all lovely people,as we near the release of production Tempera v2.1 fimware, here's a v2.1-beta7 with some nice improvements:
Also the webpage has been updated with a coming soon hypnoswirl https://www.playtempera.com/Install the firmware the same way as before:
- New mod source: MIDI note velocity
- New mod source: MIDI note index (low note -- low number, high note -- high number)
- Fix to previous beta: Grain Attack is set to Off when loading older canvases
- New UI visuals for the filters
- New option for each emitter: toggle if the emitter is being processed by the filter or not
- New bunch of various scales for the overlay keyboard
- New UI scope visuals for the modulators
- Includes quickfix for overlay keyboard bug
- Download https://fw.beetlecrab.audio/tempera/tempera-2.1-beta7-1.firmware and place it on an SD card or USB flash drive
- Insert it into Tempera and turn Tempera on while holding the Round button
- Follow instructions on the displays
Ich frage mich ob Tempera ein Flop ist. Ich finde das Konzept eigentlich super. Klanglich erinnert mich aber alles an Clouds. (Klar kein Wunder bei einem Granularsampler).
Gibt es jemanden der damit arbeitet? Wäre ganz nett würde ich mich täuschen.
Fühlt sich für mich nicht so an. Zum Vergleich hab ich hier ein Liven TextureLab, das ist weitaus sperriger zu bedienen!Ich frage mich ob Tempera ein Flop ist.
In wie fern, worauf bezogen? Bezogen auf die verkauften Stückzahlen, in der Nutzung bei Musikproduktionen, beim Bekanntheitsgrad?Gibt es jemanden der damit arbeitet? Wäre ganz nett würde ich mich täuschen.
Andre — heute um 18:59 Uhr
Hello friends! It took a while but the next Tempera firmware is ready to go.
This time there's a big improvement to the rolling tape aka live grains. There's a new Skip toggle parameter, which when engaged, makes the tape slip-skip in quarter notes. In other words, the running tape doesn't move smoothly but in a stepped way, which allows for live remixing incoming rhythmic audio.
To support this, the MIDI clock architecture has been revised again because the looping needs to be really tight and correct. Also there's a small visualization int the sample trimmer that shows segments to which the slip-skip is aligned.
Apart from small support things and bug fixes I expect this to be the last big thing for the v2.1 release, please give this a beta-test and report if you find bugs. There will probably be some since this is a fairly fragile process that can fall apart at any bug opportunity.
Here's the firmware: https://fw.beetlecrab.audio/tempera/tempera-2.1-beta8.firmware
And also a little demo showing how it works, pardon the camera shake i need either a better tripod or a stronger floor!
Andre — gestern um 14:48 Uhr
Hello friends, hope you had a great week!Big thanks to everyone who reported bugs, improvement ideas and suggestions, it means a lot, is very helpful and indicates the direction of travel. As we're trying to wrap up the v2.1 release, the new Tempera v2.1-beta14. Please give it a go and report how it goes
Grab the firmware file here: https://fw.beetlecrab.audio/tempera/tempera-2.1-beta14.firmware
- Fix various recording bugs and regressions
- Fix grain pan toggle activating on button release instead of on button press
- Fix when adjusting waveform trim range, this would sometimes flip the stereo field, not any longer
- Fix a small off-by-one error in grain firing in sync mode where they would sometimes fire too early
- Fix live grains glitching when the read head overtakes the write head should be removed. Please test this and let me know how it goes
- Improvement SprayX/Y now indicate the range and direction of spraying so it's not just a mysterious number. "Align" buttons were moved below "Relative X/Y" so it's clear that the cell alignment is final
- Improvement the Trim menu is tweaked: the waveform is larger, the brackets are moved a bit out of the way and their size indicate their significance. Buttons were reorganized a little bit too. "Listen to ending" and "Trim ending" were removed to make room for future things.
- Improvement when holding a note on the overlay keyboard and changing the layout or octave etc, the previous held note was difficult to find and untoggle. This is now easier: simply press the lit cell and note will untoggle regardless of which channel or octave it was placed at
- Improvement a QR Code leading to online docs is added to the system settings
- Polish in the modulator UI indications, the modulator is plotted even when not assigned to anything
- Polish the BPM now cannot be adjusted when Tempera is clock synced and is greyed out
Andre — heute um 17:33 Uhr
Hello everyone, the v2.1 firmware is getting better almost every day, with big thanks to the amazing bug catchers @TUAN @ekkomouse @mafic pulse @- ★ - BROCKSTAR - ★ - another round of bugs and quirks are fixed, and a few things are polished and improved in the new Tempera v2.1-beta16:
Please note that the "Base note" keyboard mode is hilariously broken, please do not use it until it's decided what to do with it.Tune your receivers to https://fw.beetlecrab.audio/tempera/tempera-2.1-beta16.firmware. Any new or old bugs, quirks or weird behaviors or improvement opportunities, report in tempera
- Includes hotfixes from the previous 15-1, 15-2 and 15-3 arc related to BPM being set to 0 and subsequently dividing by that 0
- Fixed a bug where Tempera would start recording immediately unless the recording meters are observed
- Fixed a wrong indication of incoming audio volume when entering
- Polish Grain treshold is now greyed out when "Record" is toggled
- Fixed the the click sound from the button when recording with the internal microphone on both beginning and end of the recording
- Improved Note index modulator renamed to "Key track" so it's clearer what it does, and its logic changed from a cryptic "Bias" parameter to two parameters: "Note from" and "Note to"
- Fixed the Key track modulator now plotter-scopes correctly
- Fixed a bug where if a latching emitter would be left "in limbo" with a special move, the -> Clear now restores a clean state
- Improved Transpose parameter now indicates the note and octave number
- Fixed Emitter 3 is now Pan instead of M/S on the Empty.canvas @Sally
- A few minor polishings here and there
Andre — heute um 14:23 Uhr
Hello friends and hope you're having a great start to the new year! We are go for a Tempera v2.1-rc1 firmware with a couple of last-minute housekeeping additions that were missing, along with a few bug fixes:
- New manual Start/Stop for internal and send clocks
- New small indicator of running clock at the BPM UI item
- New pentatonic minor and major scales/layouts
- New MIDI Program Change support: loads Nth canvas from the folder where the current canvas is loaded from, sorted alphabetically. (
please note that currently the sorting is naive and "100" will come before "99". This will be amended soon
- New Tap tempo
- Fixed Tempera can now send MIDI clock properly
- Fixed the AR modulator that can shut the whole modulator after it runs its course, requiring a note retrigger
- Fixed the vertical keyboard layouts are now no longer "bottoms up" to be consistent with the chromatic keyboard
- Removed the "Base note" keyboard layout until we find a way to implement it properly
Please give it a go and report bugs and weird things
- Download the firmware bytes from https://fw.beetlecrab.audio/tempera/tempera-2.1-rc1.firmware and place them on an SD card or USB flash drive
Andre — heute um 15:21 Uhr
After yesterday's bug hunting session, with big thankings to @TUAN @screech @camillomuc @ekkomouse a small Tempera firmware update v2.1-rc2 with a few fixes:
Firmware file here: https://fw.beetlecrab.audio/tempera/tempera-2.1-rc2.firmware
- Probably Fixed a sometimes double-grain trigger that causes glitch-like sound and maybe
causes some drift accumulation![]()
- Fixed a regression where the chromatic layout got vertically reversed
- Fixed crash/hang when a too high note was pressed on the overlay keyboard
- Improved global settings resetting -- button now needs to be held and gives a blink confirmation after it's done
- Minor reorganization of parameters grouping so it's ordered more reasonably
