Tom Noise
Vielleicht mal bei Make Noise anfragen. Ich habe das bisher einzeln nirgends zum Kauf gesehen.Gibt es von Make-Noise den CV-Bus Mk2 auch einzeln zu kaufen? Das wäre vielleicht noch eine geile Idee...
Make Noise CV- Bus
On Tue, May 14, 2024 at 9:53 AM Burkhard <mymail> wrote:
Hi.
I already have an intellijel 7U case and only need the Make Noise CV bus module.
But I already have lots of Make Noise modules: Maths, Moddemix, Spectraphon, DPO, DXG, QPAS, Mimeophon. As a good and paying customer I thought you would make an excuse for me, since the CV bus is just a part like everything else, it’s all modular, so it doesn’t belong to the case necessarily.
Best noisy regards,
BurkeyboarderlinerX
Sent from my iPhone
On 14. May 2024, at 15:37, technical support <technical@makenoisemusic.com> wrote:Hi Burkhard,
Thanks for writing in!
Unfortunately at this time we are only selling the CV Bus mk II as part of the 4 Zone Bus Board Case.
If you are interested in getting a case, I would be happy to point you towards a shop near you that has them in stock.
Let us know if you have any other questions, we will be happy to help.
Thanks,
Mike Johnson
On Mon, May 13, 2024 at 1:02 PM Burkhard <my-mail> wrote:Very dear makers of the Make Noise ecosystem,
I hope this mail finds you well suited. May I sincerely ask you the honest question, if it would be possible to get a CV Bus Mk II as an new or exchange part directly to buy from you?
That would be really great!
Have a wonderful and very noisy day.
Best regards of regards,
Yours faithfully,
Burkhard.
Danke für das Teilen der Nachricht. Ist hilfreich - vor allem der Hinweis, falls man was gebrauchtes sucht.
Dein Bild bezieht sich aber auf die 3U Maße, wobei das CV Bus Modul 1U ist. Hier die Maße vom MKI. Die Maße der Platine weiß ich nicht, werde das Modul nun aber auch nicht ausbauen, da das Einbauen mit den sliding nuts recht fummelig ist. sorry.Bin etwas überrascht von der Make Noise Mail.
Kannst du bestätigen, dass bei deinem Make Noise CV-Bus die Platine des PCB schmäler als 110mm ist?
Ich habe keine vergleichbare Spezifikation des Make Noise CV-Bus Mk1 / Mk2 gefunden, wohl auch geil das kein frei verkäufliches Modul ist.
Also muss ich die Information von Make Noise einfach so glauben, oder irgendjemand kann es mal nachmessen...
Das wäre sehr hilfreich.
Breite ca. 527mm und Höhe 43mm
Da vertust Du Dich glaube ich. Die Frontplatten liegen idR oben auf, da gilt dann bestimmt das 44,45mm Maß.das laut Spec nur 39,6
Krass, ja Du hast Recht! Sehe ich auch jetzt erst.Also so wie ich das (in der Zeichnung und auch bei meinem Case) sehe, liegen die Module nicht oben auf, sondern gleiten in einer Schiene. Und diese ist 39,65mm.
plus Zoll und MwSt
Ich kenne Zorx Electronics nicht, aber ich würde es mir gut überlegen ob ich so viel Geld an eine ich sag mal "noname" firma zahlen würde. Vielleicht tue ich denen unrecht, aber Eurorack ist eben auch ein bischen Anarchie, da kann man schnell ne "Firma" mit webshops zusammenzimmern und man weiss dann nicht, ob mit gleichen Qualitätsansprüchen gearbeitet wird wie die etablierten Firmen. Das ist auf der einen Seite toll, weil dadurch viele interessante Sachen auf den Markt kommen, andererseits würde ich da bei dem hohen Preis den Du oben ausgerechnet hast eher Vorsicht walten lassen. Das ist jedenfalls meine Erfahrung.
sorry, aber das ist mal wieder voll daneben von Dir, woher willst Du bitte wissen wovon ich noch nichts gehört habe?da gibt es viele Module von Firmen von denen haben wir beide noch nie was gehört.
