GFI Skylar Reverb und Orca Delay
Green Dino
Green Dino
X---X---X---X
Jeweils 4 Engines aus dem Specular Tempus als kleine Pedale. Ganze zwei Presets (!)
GFI Skylar Reverb
Algorithms
  • Spatium
  • Shimmer
  • Plate
  • Tremble (tremolo-reverb with tap-tempo)
Specification​
  • Input impedance : 1 MOhm.
  • Output impedance : 1K Ohm.
  • DAC / ADC resolution : 24 bits.
  • Current consumption : ~110 mA.
  • Weight : 0.6 Kg (1.6 lbs).
  • Dimension : 12 (L) x 7.2 (W) x 5.5 (H) cm
  • Power source : 9VDC (negative center) - not supplied.
Key Features​
  • 4 select reverb algorithms.
  • 2 presets
  • 4 knobs with button
  • Intuitive interface with LCD screen.
  • Mono / Stereo input and output.
  • Expression pedal and tap-tempo input.
  • Momentary action supported.
User Manual
GFI Orca Delay
Algorithms
  • Digital (max delay time : 1 second)
  • Tape (max delay time : 1 second)
  • Diffuse (max delay time : 1 second)
  • Ambiental (max delay time : 840 milisecond)
Specification​
  • Power source : 9VDC (negative center).
Key Features​
  • 4 select delay algorithms.
  • 2 presets
User Manual
