R
Das wird Beamen und Zeitreise mit Sicherheit auch, nur wann...und überhaupt!?Ja der Urs Heckmann sagt halt nur: Zebra3 ist fertig wenn er fertig ist. Aber das Ding wird sicher ein Knaller.
Zebra 2.9 introduces NKS support and macOS 10.15 Catalina compatibility. We also tagged the Zebra2 and Zebrify factory patch libraries, and we added X/Y pad control for countless variations per preset.
Here are the changes since the last release, rev. 7422:
Improvements:
- Mac installer notarized (Catalina)
- NKS support for Zebra2 and Zebrify
- Added tags
- Factory presets all "XY-ified"
- Two new oscillator effects (DX, Smear)
- Browser: file system drag&drop support
- Browser: import/export of favourite assignments
- VST3 MIDI learn working
- Windows installer improvements
- Full UTF-8 support for installation paths
- Mac installer improved to prevent permission issues
- Improved GUI response time on some Macs running Mojave (sluggish GUI)
- Windows GUI performance improved (less CPU load with open GUI)
- Sustain pedal now working according to standard (0-63 = off, 64-127 = on)
Fixed:
Known Issues:
- Fixed an issue where some oscillator effect combinations would lead to silence
- Fixed an issue where parameters could take over XY value from previous preset
- Fixed an issue where Microtuning & low notes could lead to problems
- Fixed an issue with the arp when not receiving MIDI note-off events
- Fixed an issue with the MSEG in single trigger mode
- Fixed rare crash when reopening old host projects
- Fixed rare issue where newly imported presets would not show up
- Fixed multiple graphics glitches in VCF module
- Fixed a glitch when trying to adjust MSEG mod depth in Zebrify
- Fixed wrong link to ZebraHZ presets folder (Windows only)
- Various other fixes and improvements
- No Linux version yet
- Crash when trying to load script presets (e.g. Randomizer)
- MSEG graphics glitch in the fill gradient (Windows only)
- Main display context menu needs plugin focus to work (Apple issue)
Danke, d.h. ich kann lange warten.
Also eigentlich muß ich doch jetzt zuschlagen, oder?
FX dahintererzähl mal ? mit was du alles hast kann ich nicht viel anfangen. Hive hab ich auch.
Außerdem noch ZRev und Zebralette!Gerade entdeckt. Mit Zebra kommt auch Zebrify, die Effektunit von Zebra. Diese lässt sich als Effektplugin benutzen (Reverb, Delay, etc.) Ziemlich cool!
Zebra2 2.9 (revision 9436)
New features and improvements:
- Mac installer notarized for macOS 10.15 Catalina
- Factory presets all tagged and X/Ys assigned
- Five new presets for Zebrify
- Browser: file icons added
- Wavetable export function for OSC1 (DotEight only)
- VST3 MIDI-learn working
- Mac installer improved to prevent permission problems
- Modulation mapper Increment mode resets on host playback start/stop
Bug fixes:
- Fixed an issue where parameters could take over X/Y value from previous preset
- Fixed an issue with pitchbend when switching presets (VST3, Cubase only)
- Fixed an issue where microtuning & low notes could lead to problems
Known issues:
- Zebralette VST2 displays option to save as nksf, don't use it, it will crash
Depending on your hardware setup, the reaction of the fullsize editors might slow down the bigger you set the GUI size of Zebra2. Either reduce the GUI size, or, if you are on macOS, try setting your colour profile to sRGB IEC61966-2.1. Note that this might be noticable even on newer generation computers.
The factory presets in the "0 Tenth Anniversary" folder have now been sorted into the appropriate category folders, and the Anniversary folder has been removed. If you had presets in this folder marked as favourites, and you want to keep the favourite markings, backup the folder, then install the update, and then put the folder back in there before you start the updated plugin for the first time.
We improved the Windows installer to prevent wrong installations and permission issues. Please check the suggested installation paths during installation.
Ich kann mich auch nicht entscheiden.
Zebra2 hat die höhere Ersparnis mit dem Dino-Crossgrade aber irgendwie habe ich das Gefühl, dass mir Hive 2 eher zusagt, ist eben auch moderner. Aber vielleicht gibt es ja dann doch mal irgendwie Zebra 3 und man kann günstig upgraden. Andererseits gibts dann vielleicht ehh eine Aktion für Zebra 3 (wenn er denn irgendwann kommt).
Bazille ist natürlich auch noch sehr interessant. Diva und Repro und die ganzen FX habe ich ja durch das NI-Bundle vor einiger Zeit.
Die Qual der Wahl
Ich habe bei Zebra 2 heute mit dem Dino crossgrade und dem sale Preis zugeschlagen.
Selten erlebt das von den Presets so viele richtig geil klingen und meinen Geschmack treffen.
Aber klar, ist schwer sich da festzulegen.
Gibt es eigentlich für Zebra 2 ein deutsches HAndbuch, oder nur das Englische?
Das ich das nicht mit dem Microkorg probiert habe nervt mich jetzt. Das wären dann ja nur 80€, oder?
Es gab keinen 50€ Rabattgutschein wie auf der Seite steht, sondern 25%, macht 139€ Salepreis minus 25% = 104€
