Synthstrom Audible Deluge Groovebox (in Deutschland kaufbar)
In beta20 gibt es nun wieder ein paar kleine Änderungen.
  • New feature - there’s now a “PREViewing” setting in the settings menu, to control whether samples will preview audibly in the file browser. Settings are ON, OFF, and CONDitional - under which previewing will only occur if playback is off. This setting replaces the old method of holding shift before pressing the audition pad of the row you’re going to browse for - that will no longer work. Default is ON for existing devices, but will be COND for new devices in the future.
  • Rearranged a couple of other things in settings menu - the LAYOut submenu is now renamed to PADS - which is a bit easier to make sense of on the 4-digit display. And the MONItoring setting is moved into the RECOrding submenu, and its SMARt option is renamed to CONDitional, to match the new PREViewing setting and make a bit more sense.
  • Muting Instruments in arranger now stops them echoing or being sounded by MIDI input. As discussed in a thread a couple of days ago. I'm hoping this will be helpful for people and won't cause problems in anyone's existing workflow. Still open to feedback if you have any thoughts.
Grüße
Wie versprochen, hier die Ankündigung: Im Laufe des heutigen Abends wird das große Overlay für den Deluge verfügbar sein (und steht für den morgigen Versand bereit). :)
Es sind noch ein paar Shortcuts hinzugekommen, sowie kleine kosmetische Verbesserungen. Die Fotos auf der Webseite zeigen die aktuelle Version.
beta.22+21 updates
  • Fixed E245 error in arranger relating to undoing deleting or creating clips, especially MIDI ones
  • Fixed - in arranger, just before an audio clip stopped playing, you could hear the beginning of it again briefly
  • Deleting a note not no longer grabs its velocity to use as the default
  • Fixed the MIDI "RESTart" command, for resetting play position, wasn't working if the Deluge was the syncing slave
  • Fixed case where first note in a clip could skip being recorded
  • Fixed - if an audio clip instance in arranger was shorter than the actual clip, and was "made unique / white", the clip would speed up
  • Fixed again - potential crash on undoing audio clip recording
Hab mir mal aus Neugier das neue Overlay angeschaut und konnte gar kein Start- und Endbutton mehr finden. Bin ich blind oder gibt es die Schalter nicht mehr?
Roland Treiberupdates - hab ich noch nie von gehört. Machen die nicht. Daher - alles bald nicht mehr nutzbar im Rechner per USB, wie beim V.
Hey Catalina!
Ich habe mein(e) Lektion(en) gelernt: Roland-Geräte, die nicht class-compliant sind, kaufe ich nicht mehr. Am meisten hat mich das bei der SonicCell geärgert, weil dieses Teil ohne aktuellen Treiber 50% seines Funktionsumfangs verliert.
Zurück zum Deluge:
Im Newsletter ist ein Producer Guide angekündigt. Ich hab von diesem Menschen schon den Guide zum Digitakt als PDF gekauft. Der ist sehr brauchbar und hat nur ein paar Euros gekostet. Da das Deluge-Manual nach wie vor scheiße ist, ist die Anschaffung mit ziemlicher Sicherheit ein No Brainer.
Hier die aktualisierte Liste der Devices, die im MIDI-Host-Mode funktionieren (Quelle: FB Deluge Beta-Gruppe):
  • Akai APCmini
  • Akai APC40 MK2
  • Akai LPK25
  • Akai MPD218
  • Akai MPK 249
  • Akai MPK Mini (1st Generation)
  • Akai MidiMIX
  • Alesis qx25
  • Alesis V49
  • Arturia Keystep (NB: USB midi input works great. Deluge will sync to internal clock of Keystep. Keystep still requires CV clock when trying to use the deluge clock.)
  • Arturia Microfreak
  • Arturia Microlab
  • Arturia Minilab Mk I
  • Arturia Minilab Mk2.
  • Axoloti+MTM
  • Behringer X-Touch Mini
  • C-thru-music AXIS-49
  • CraftRhythm - Modal
  • Craft Synth 2.0
  • DSI Rev2
  • Faderfox (UC-4)
  • FaderFox PC4
  • IK Multimedia iRig Pads
  • Joué
  • Keith McMillen BopPad
  • Keith Mc Millen K Board
  • KeithMcMillen QuNeo
  • Kenton KILLAMIX-MINI
  • Korg nanoKEY Studio
  • Korg nanoKEY2
  • Korg microKEY Air 37
  • Korg microKontrol
  • Korg Minilogue XD
  • Korg Monologue
  • Korg Padkontrol KPC1
  • Launchpad Pro (NB: sometimes, not 100% yet)
  • Launch control XL (NB: if plugged into Deluge after booting with another USB-MIDI device)
  • LinnSrument
  • M-Audio Keystation 49e
  • Modal Skulpt
  • Moog Grandmother
  • NDLR
  • Nektar Panorama P6
  • Nord Lead A1
  • Novation Circuit
  • Novation Circuit Mono Station
  • Novation SL MK2 49 key
  • Roland A01
  • Roli Seaboard Rise - tested in Piano mode
  • Roli Seaboard Block
  • Roli Lighpad M - tested in note mode set to single channel MIDI
  • Sensel Morph
  • Teenage Engineering OP-Z & OP-1
  • UNO synth
  • V-meter
  • Xkey Air25
  • Yamaha Reface
Mein Deluge ist kürzlich durch ein Missgeschick ein Stockwerk tiefer durch eine Bodentüre gefallen. Fallhöhe waren so 2 Meter. Mehrere Holzecken sind leicht eingeschlagen. Sonst hat das Gehäuse aber guten Widerstand geleistet. Ist nichts verbogen oder abgebrochen.
Nur Starten wollte der Deluge nicht mehr.
Hatte aber schon einen Verdacht. Nach dem öffenen des Deluge hat es sich Bestätigt, das einzige Problem war das die Batterie herausgerutscht war. OK, die Batterie-Kontakt-Lasche war auch verbogen. Ein bisschen gegendrücken und die Lasche war wieder in Position.
Jetzt funktioniert der Deluge wieder.
Also, unfreiwilliger Falltest bestanden.
Ist ja auch nicht viel drin, das kaputt gehen kann. Worst Case wäre ein Platinenbruch oder ausgerissene Encoder. Das Blechgehäuse ist wirklich extrem massiv, ich habs beim Tausch gegen das 3.0-Panel gesehen. Die Holzteile kannst du übrigens im Webshop von Synthstrom als Ersatzteile ordern.
Mich würde interessieren, was an euren Midiports hängt.
Ich mach mal den Anfang:
Midi In : meistens gar nichts , weil ich noch unentschlossen bin.
Midi Out : wechselweise Blofeld oder Neutron
Würde mich freuen, wenn ihr mitmacht.
Midi in : ab und zu die Bassstation 2
Midi usb : Behringer xtouch mini
Midi Out : Deepmind 12d/Waldorf Blofeld/Access Virus/x0xb0x/tt 303 Mk2/ab und zu ML303/Sh01a/Behrimoog /Volca FM/Behringer RD8/Novation Bassstation 2
Funktioniert aber erst ab Deluge FW3.0 und du musst ein extra Netzteil am Deluge anstecken.
Und im moment funktioniert es nur als USB midi in.
In: LinnStrument (Welches den Deluge momentan öfter einfrieren lässt und andere lustige Bugs triggert), Keith McMillen Softstep und manchmal die Rytm als Masterclock (Alle durch einen Kenton MIDI merger)
Out: Prophet 12 und Rev2, Novation Peak, Moog Slim Phatty, Analog Rytm (Wenn sie nicht am In hängt), 1010music Blackbox, LinnStrument
USB ist noch ungenutzt, sehe den Sinn dahinter für die Studioanwendung noch nicht.
