Immerhin: Man scheint Samples ab SD-Karte laden zu können...
...über die Anzahl der verfügbaren Velocity-Layer schweigt sich Roland (wie immer!) wieder einmal galant aus! :rolleyes:
Du erwartest nicht wirklich Velocity Layer^^?
Man kann froh sein, wenn es Velocity auf Amp für die Samples gibt.
600 Sec. Samples von SD Karte steht in dem Link oben. 128 Drum Kits und 128 User Patterns.
Wird schon ein cooles Teil! Mit den Fadern macht eh Spass!
Roland TR-8S specs
Product Highlights
Machine Models: 808, 606, 909, 707, 727
128 User Drum Kits + 128 User Patterns
11 Instruments with Multiple ACB Tones
Preset Samples: 150 Tones or Greater
SD Card for Sample Playback: 600 Seconds
16 Steps per Measure with 8 Variations
Updated Instrument and Master FX
Motion Recording Function
Side Chain, Scatter, and Auto Fill In
USB Audio and MIDI
Drum Kits User Drum Kits: 128
Patterns User Patterns: 128
Step Sequencer 11 x instrument parts
1 x exclusive part for trigger out
16 x steps per 1 measure
8 x (A - H) variations per 1 pattern
2 x fill-in patterns per 1 pattern
Instruments Bass Drum: 11 ACB tones
Snare Drum: 8 ACB tones
Tom: 15 ACB tones
Rim Shot: 3 ACB tones
Hand Clap: 5 ACB tones
Hi Hat: 8 ACB tones
Cymbal: 8 ACB tones
Percussion: 23 ACB tones
Preset Samples: 150 tones or greater
User Sample Import User Samples: Imported from SD card for playback
Available Format: WAV, AIFF
Total Time for All Samples: Approximately 600 seconds (at 44.1 kHz, mono)
The maximum length of a single audio file that can be imported is approximately 180 seconds (at 44.1 kHz)
Effects Inst FX: Thru, Hpf, Lpf, Lpf/Hpf, H boost, L boost, L/H Boost, Isolator, Transient, Compressor, Drive, Comp+Drv, Crusher
Reverb: Ambi, Room, Hall 1, Hall 2, Plate, Mod
Delay: Dly, Pan, Tape echo
Master FX: Hpf, Lpf, Lpf/Hpf, H Boost, L boost, L/H boost, Isolator, Transient, Transient 2, Compressor, Drive, Overdrive, Distortion, Fuzz, Crusher, Phaser, Flanger, Sbf, Noise
Other: Side chain (for Ext in), Scatter (as one of Auto Fill-In functions)
Display 16-characters, 2-line (backlit LCD)
7-segments, 4-characters (LED)
External Storage SD card (SDHC supported) for backup/restore function and import sample data
Connectors Phone Jack: 1 x Stereo 1/4" / 6.3 mm phone type
Mix Out (L/Mono, R) Jacks: 2 x 1/4" / 6.3 mm TRS phone type
Assignable Out/Trigger Out (1 - 6) Jacks: 6 x 1/4" / 6.3 mm phone type
Ext In (L/Mono, R) Jacks: 2 x 1/4" / 6.3 mm phone type
Trigger Out Jack: 1 x 1/8" / 3.5 mm
MIDI (In, Out) Connectors: 2 x 5-pin DIN
USB Port: USB type B (Audio, MIDI)
DC In Jack
USB Audio, MIDI
Power Supply AC adapter
Current Draw 2000 mA
Dimensions (W x D x H) 16.1 x 10.4 x 2.3" / 409 x 236 x 58 mm
Weight 4.6 lb / 2.1 kg
[/QUOTE]
Externes Netzteil, kein MIDI-Thru.
Preis: 700 USD
Na ja, eigentlich das, wie die TR8 hätte sofort raus kommen müssen, dafür werden jetzt alle TR8s enorm entwertet, demnächst mit Verramschpreisen auf Ebay...
Die rel. massige FX Sektion wirds hier klanglich hauptsächlich reissen. DANN sind die jetzt endlich enthaltenen 8 Outs aber fast schon wieder obsolet :achso:
nanu es gibt jetzt weniger Knöpfe zum sound-tweaken? ... Attack, Comp, Snappy fehlen
Ext In hat einen Volume Poti, also gibt's wohl.
Scatter ist teil der Auto Fill Sektion anscheinend.
Der CTRL Knob hat ja diese CTRL Select Taste unter dem Display.
Geheimnisvolle Sache:amen:
Zitat von der Webseite:
"Neben dem Master FX Regler verfügt jeder Kanal über einen personalisierbaren CTRL Regler, mit dem du jederzeit schnellen Zugriff auf die vielfältigen Möglichkeiten der Klangbearbeitung hast. Ganz gleich, ob du die Attack der Kick, den Snap der Snare, die Phaser-Intensität oder den Verzerrungsgrad einstellen willst – du kannst jeden gewünschten Effektparameter auf den CTRL oder Master FX Regler legen und für jedes Kit individuell abspeichern. Darüber hinaus werden sowohl die Instrumenten- als auch die Master-Effekte mit allen Einstellungen pro Kit gespeichert, so dass du deine Produktionen jederzeit live verwenden kannst."
Das mit der Fill-Funktion finde ich ziemlich gut. Ich komme ja eher aus der Arranger-Ecke und da sind Fills Standard. In der elektronischen Musik ist der Rhythmus tendenziell statisch und ohne Fills. Da muss man jedes Fill oder die Pattern-Änderung programmieren, was ich ziemlich nervig finde. Meine DrumBrute hat immerhin eine Loop Funktion, die man auch gut als Rhythmus-Brücke verwenden kann. Fills kann die aber leider nicht.
ERGO: Es scheint, als hätte Roland DIESMAL nicht enttäuscht.
(wobei ich für so ein Live-Dingens eher keine Verwendung hätte)
Das Sampling ist keins bzw. Samples von SD Karte laden, oder?
Trotzdem coole Maschine. :)
Fills so zugänglich zu haben ist wunderbar!
Schade, dass man dafür ne TR-8 2 braucht, die alte TR-8 ist ja nun nicht soo alt^^Aber was solls, daran gewöhnt man sich auch...
Ich finds nicht schlecht. Vor allem sieht das Gerät nicht mehr so affig aus.... :)
witzig, dass die TR-8 gegen die neue schon fast irgendwie vintage aussieht :)
die "s" ist die erste drum machine, die mich echt interessiert, hauptsaechlich wegen dem direktzugriff. ansonsten war ich immer ganz happy mit meinen Ipad-drummies, wenn halt die bedienung net so fummelig waer. dabei faellt mir ein: preislich liegt das dingen ja nicht weit von nem Ipad pro weg...:denk:
Geht mir ähnlich.
"Das Beste aus beiden Welten" wäre cool...
Bin mittlerweile von der Funktionalität aufm iPad her etwas verwöhnt, daher hätte ich gerne bei der TR8S noch Ableton Link und irgendwie ne geschmeidige Einbindung, um Sounds hin- und herzuschnicken (wie z.B. mit Audioshare) :lollo:
neuer drummie mit 606/707/727/808/909 und user samples per sd-karte.
review von peter kirn/cdm
von der produkt-website:
User Drum Kit:
128
User Patterns:
128
Step Sequencer:
11 instrument parts and 1 exclusive part for trigger out
16 steps per 1 variation
8 (A – H) variations per 1 pattern
2 Fill-in patterns per 1 pattern
INST tone:
(Tone can be assigned to each 11 instrument parts freely.)
BASS DRUM: 11 ACB tones
SNARE DRUM: 8 ACB tones
TOM: 15 ACB tones
RIM SHOT: 3 ACB tones
HAND CLAP: 5 ACB tones
HI HAT: 8 ACB tones
CYMBAL: 8 ACB tones
PERCUSSION: 23 ACB tones
PRESET SAMPLE: 300 tones or greater
USER SAMPLE (imported form SD CARD for playback): Available format: WAV, AIFF
Total time for all samples: Approximately 600 sec (at 44.1 kHz, mono)
* The maximum length of a single audio file that can be imported is approximately 180 seconds (at 44.1 kHz).
Effects:
INST FX: THRU, HPF, LPF, LPF/HPF, H BOOST, L BOOST, L/H BOOST, ISOLATOR, TRANSIENT, COMPRESSOR, DRIVE, COMP+DRV, CRUSHER
REVERB: AMBI, ROOM, HALL1, HALL2, PLATE, MOD
DELAY: DLY, PAN, TAPE ECHO
MASTER FX: HPF, LPF, LPF/HPF, H BOOST, L BOOST, L/H BOOST, ISOLATOR, TRANSIENT, TRANSIENT2, COMPRESSOR, DRIVE, OVERDRIVE, DISTORTION, FUZZ, CRUSHER, PHASER, FLANGER, SBF, NOISE
Other: SIDE CHAIN (for EXT IN), SCATTER (as one of AUTO FILL IN function)
Display:
16 characters, 2 line (backlit LCD)
7 segments, 4 characters (LED)
External Storage:
SD Card (SDHC supported) for backup/restore function and import sample data
Connectors:
PHONES jack: Stereo 1/4-inch phone type
MIX OUT (L/MONO, R) jacks: 1/4-inch TRS phone type
ASSIGNABLE OUT/TRIGGER OUT (1 – 6) jacks: 1/4-inch phone type
EXT IN (L/MONO, R) jacks: 1/4-inch phone type
TRIGGER OUT jack: Miniature phone type
MIDI (IN, OUT) connectors
USB port: USB type B (Audio, MIDI)
DC IN jack
Power Supply:
AC adaptor
Current Draw
2,000 mA
Accessories:
AC adaptor
Owner's manual
Leaflet “USING THE UNIT SAFELY”
Size and Weight:
Width 409 mm
Depth 263 mm
Height 58 mm
Weight 2.1 kg
Ich hatte die "alte" TR8, war gut und hat Spass gemacht. Ich habe sie dann verkauft. Die "S" würde ich mir allerdings zulegen. Hört sich gut an und das Design sagt mir zu. Ich glaub ich spare schonmal.
Ich lese gerade auf der Roland Webseite:
- Total Recall
und das:
Audio- und MIDI-Interface
Neben der Tatsache, dass die TR-8S die leistungsfähigste Drum Machine aller Zeiten ist, fungiert diese zudem als vollständiges Mehrkanal-Audio- und MIDI-Interface. Sobald du deine TR-8S mit einem Computer oder AIRA Link Host verbindest, kannst du MIDI-Daten und hochauflösendes Audio über ein einzelnes USB-Kabel übertragen. Auf diese Weise kannst du jedes einzelne Drum-Instrument auf einem separaten Kanal aufnehmen und individuell bearbeiten, Parameter-Fahrten über CC-Nachrichten in deiner DAW automatisieren oder deine TR-8S mit deinem Computer oder dem Roland MX-1 Mix Performer für Live-Sets und Jam-Sessions synchronisieren.
Jetzt frage ich mich, warum sollte ich noch meine Analog Rytm MK1 behalten. Bei der Rytm fehlte mir schon immer der direkte Zugang zu Volume und genug Potis!!!
Kennt jemand den Preis?
