Nur OnTopic „Materializer“ Convolution mit Samples als IR
Ok hier nochmal was cleaner auf einem Break. Wieder Dry>dann Innerspace rein, erst A dann B dann A und verschiedene Materialien/Spaces durchgezappt.
  • Innerspaced 2.mp3
    4,4 MB
Als Update für Interessenten:
Hab da was gefunden https://www.polyeffects.com/polyeffects/p/beebo
„Convolution reverb allows you to capture a real space. It has become the dominant technology for studio reverb but it's very high CPU requirements have restricted its use in hardware before. With Beebo it's now possible. You can easily capture a space or a vintage reverb tank you like the sound of or download one of the thousands online. You can then accurately have the sound of famous studios, concert halls, deep caves, your own bathroom or giant plate reverbs. You can also use convolution in creative ways by loading non-reverb sounds.“
Weiter: „
„If you want modular or weirder effects, the bitmangle, freeze, granular, 6 different virtual analog filters, powerful LFOs, time stretch, turntable stop, step sequencer, twist delay, VCA, wavefolder, quantiser, attenuverter and more will cover it.
There’s some very powerful modules ported from the best eurorack modules including a granular texture synthesiser, a 16 model macro oscillator voice and a meta modulator with 7 blendable signal combining algorithms including ring modulation, comparators and cross folding.
The MIDI to V/oct module allows you to drive the synthesis modules from MIDI note input.“
Das hört sich SEHR interessant an mit der Kombi out of the box IRs zu verarbeiten. Envelope Follower usw gibt es auch. Mit voller Midi Kontrolle von „außen“ wahrscheinlich sehr mächtig.
