Dirtywave M8 Tracker
Frisch aus Discord, die Liste mit den neuen Features:
2024-07-06 - Version 4.0.0 Beta
New: Configurable 3 band biquad EQ added to main mix, global effects, and instruments
New: Launchpad Pro MK3 MIDI Control Surface support added in MIDI Settings view
New: Instrument Pool view for managing instruments as a list.
New: Post-filter LIMIT/CLIP distortion modes added: R1 and R2 (Rectified 1 and 2)
New: Wavsynth "OVERFLOW" shapes (literal data overflow) replaced with 60+ wavetables
New: Wavsynth MIRROR parameter renamed SCAN due to being able to scan the new wavetables
New: ZDF (zero delay feedback) lowpass and highpass filter added to filter type
New: Scales now have a global tuning parameter to diverge from A440
New: Table TIC FE mode - The first 12 rows of the table are mapped to note
New: FX commands: DJC,DJR,DJT (renamed DJF to DJC) for sequencing the DJ filter
New: FX command: RTO (Repeat To) - Holds the repeat command (REP) at a specific value
New: FX command: ART (Arp tics/time) - Set the tic rate of the ARP command
New: FX command: EQS and EQI FX commands for setting the EQ bank for song or the current instrument
New: FX command: GGR (Global groove) - Set the groove for all tracks
New: FX command: INS (Instrument) - Set the current instrument
Improved: No longer exit from Live-mode after loading a song
Improved: File browser now automatically sorts directories with 128 entries or less
Improved: "DRUNK" LFO shape no longer retriggers from zero
Improved: ADSR now has better scaling on the low range (more small values)
Improved: PITCH mod destination amount now has better scaling on the low range
Improved: Play button always stops if sequence is running (regardless of phrase / chain / song playback)
Improved: FX list view has a new category for instrument envelopes
Improved: Trig envelope now triggers correctly if the trigger event happened before the instrument started
Improved: Delay send FX now has a mono/summed input (was left channel only before)
Improved: Pre-load samples on song queued load for better initial triggering of samples
Fix: When out of phrases, cloning did not display an error
ich habe bisher nur kurz reinschauen können..eq ist schonmal eine super sache, auch der instrumentenpool. auch nett ist der neue "ins"-Befehl, damit kann z.B. über "rnl" (random left) einfach ein zufallsinstrument aus dem pool wählen lassen, ähnlich bei elektron per zufall einen sample auswählen, geht hier mit allen instrumenten..mehr habe ich neben der Arbeit bisher nicht anschauen können.. **edit: ich muss zugeben das ich mit dem bisherigen Featureset schon mehr als zufrieden bin und auch bei weitem nicht alles nutze **
Jo, die Zukunft wird zeigen, was mit den neuen Features alles möglich sein wird. Die erweiterten Arp-Befehle finde ich auch interessant. Bisher konnte der M8 ja nur diese ausgelutschten Chipsound Arpeggios. Mit den neuen Befehlen wird der Arpeggiator musikalisch etwas vielseitiger einsetzbar.
Da ich keine Betaversionen für Hardware mag, werde ich warten, bis die 4.0 released wurde.
..mit der beta4 hatte ich gestern einen harten Crash, werde das gleich mal rekonstruieren und im discord posten..entweder war es der eq oder der ins-Befehl..
Falls noch nicht bekannt:
  • Open M8 Tips Tricks and Findings.pdf
Jetzt ist es offizell...
Trash80heute um 02:42 Uhr​
Version 4.0.0 Released. EQs, Instrument Pool, Launchpad support, Wavsynth wavetables...@M8s Firmware Update instructions have not changed. Read the readme.txt file if you need instructions.Current M8 Firmware:https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zipHeadless Teensy 4.1 Firmware: (Updated for version 4.0.0)https://github.com/DirtyWave/M8HeadlessFirmware
2024-07-25 - Version 4.0.0
- New: Configurable 3 band biquad EQ added to main mix, global effects, and instruments
- New: Launchpad Pro MK3 MIDI Control Surface support added in MIDI Settings view
- New: Instrument Pool view for managing instruments as a list
- New: Post-filter LIMIT/CLIP distortion modes added: POST:W1 and POST:W2 (Waveshaper 1 and 2)
- New: Wavsynth "OVERFLOW" shapes (literal data overflow) replaced with 60+ wavetables
- New: Wavsynth MIRROR parameter renamed SCAN due to being able to scan the new wavetables
- New: ZDF (zero delay feedback) lowpass and highpass filter added to filter type
- New: Scales now have a global tuning parameter to diverge from A440
- New: Table TIC FE mode - The first 12 rows of the table are mapped to note
- New: FX commands: DJC,DJR,DJT (renamed DJF to DJC) for sequencing the DJ filter
- New: FX command: RTO (Repeat To) - Holds the repeat command (REP) at a specific value
- New: FX command: ARC (Arp config) - Set the tic rate, arp direction, and number of octaves for the ARP command
- New: FX command: EQM and EQI FX commands for setting the EQ bank for song mix or the current instrument
- New: FX command: GGR (Global groove) - Set the groove for all tracks
- New: FX command: INS (Instrument) - Set the current instrument
- Improved: No longer exit from Live-mode after loading a song
- Improved: "DRUNK" LFO shape no longer retriggers from zero
- Improved: ADSR now has better scaling on the low range (more small values)
- Improved: PITCH mod destination amount now has better scaling on the low range
- Improved: Play button always stops if sequence is running (regardless of phrase / chain / song playback)
- Improved: FX list view has a new category for instrument envelopes
- Improved: Trig envelope now triggers correctly if the trigger event happened before the instrument started
- Improved: Delay send FX now has a mono/summed input (was left channel only before)
- Improved: Pre-load samples on song queued load for better initial triggering of samples
- Fix: When out of phrases, cloning did not display an error- Fix: Disable remote display for boot options view
- Fix: Instrument - Delete shortcut ([OPT]+[EDIT]) on LOAD or SAVE instrument deleted characters from instrument name
- Fix: Tearing artifact on value sliders (more prevalent on Model:02)
- Fix: Instrument Mod - Trig envelope did not work correctly when using multiple instruments (some without a trig mod) in the same track
- Fix: Big-font mode song navigation issue on track 8 if the info area appeared
- Fix: Info area mini-map displayed the wrong [P] position when navigating up from Chain view
- Fix: Phrase - When using scales it was possible to edit notes past note number 127
- Fix: Cursor clearing issues on big font mode when toggling right side info area
- Fix: When editing down a note using scale on the lowest octave, it could toggle between C-1 and the lowest scale note
- Fix: Sample Editor - Xfade loop could cause distortion with 24 bit wav files
- Fix: DEL (Delay FX command) with a HOPFF in the same row caused a crash
Trash8023.01.25, 18:32​
Version 4.0.2 Released. A few minor bugs were left floating around.
:stickbugged:
Headless Teensy 4.1 Firmware: (Updated for version 4.0.2)https://github.com/DirtyWave/M8HeadlessFirmwareFull changelog can be read here:https://github.com/Dirtywave/M8Firmware/blob/main/changelog.txt
2025-01-23 - Version 4.0.2
- Improved: Project view - Groove and scale setting now only take effect after releasing edit for live performance
- Fix: Project - Global groove setting did not change correctly during live playback
- Fix: External Instrument - Fixed Left/Right/Stereo input settings not working correctly
- Fix: Clear unused instruments (Project view "CLEAR UNUSED INST/TBL") did not check if instrument is used via INS commands in tables
- Fix: Wavsynth - Hard-crash if setting INT command to an empty instrument on the table's first row
- Fix: Display drawing issue on big-font mode when sticking the right side navigation (SHIFTx3)
Trash80heute um 04:46 Uhr​
Do you like to read? I like to read too... I have read so many audio books. @M8s The 4.0 Manual update is finally available. Download it here: https://dirtywave.com/support
