				Schon installiert? Wenn ja, wie ist so dein Eindruck?BETA 2 mit bugfixes:
Discord - Group Chat That’s All Fun & Games
Discord is great for playing games and chilling with friends, or even building a worldwide community. Customize your own space to talk, play, and hang out.discord.com
	Frisch aus Discord, die Liste mit den neuen Features:
2024-07-06 - Version 4.0.0 Beta
Trash80 — heute um 02:42 Uhr
Version 4.0.0 Released. EQs, Instrument Pool, Launchpad support, Wavsynth wavetables...@M8s Firmware Update instructions have not changed. Read the readme.txt file if you need instructions.Current M8 Firmware:https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zipHeadless Teensy 4.1 Firmware: (Updated for version 4.0.0)https://github.com/DirtyWave/M8HeadlessFirmware
2024-07-25 - Version 4.0.0
- New: Configurable 3 band biquad EQ added to main mix, global effects, and instruments
- New: Launchpad Pro MK3 MIDI Control Surface support added in MIDI Settings view
- New: Instrument Pool view for managing instruments as a list
- New: Post-filter LIMIT/CLIP distortion modes added: POST:W1 and POST:W2 (Waveshaper 1 and 2)
- New: Wavsynth "OVERFLOW" shapes (literal data overflow) replaced with 60+ wavetables
- New: Wavsynth MIRROR parameter renamed SCAN due to being able to scan the new wavetables
- New: ZDF (zero delay feedback) lowpass and highpass filter added to filter type
- New: Scales now have a global tuning parameter to diverge from A440
- New: Table TIC FE mode - The first 12 rows of the table are mapped to note
- New: FX commands: DJC,DJR,DJT (renamed DJF to DJC) for sequencing the DJ filter
- New: FX command: RTO (Repeat To) - Holds the repeat command (REP) at a specific value
- New: FX command: ARC (Arp config) - Set the tic rate, arp direction, and number of octaves for the ARP command
- New: FX command: EQM and EQI FX commands for setting the EQ bank for song mix or the current instrument
- New: FX command: GGR (Global groove) - Set the groove for all tracks
- New: FX command: INS (Instrument) - Set the current instrument
- Improved: No longer exit from Live-mode after loading a song
- Improved: "DRUNK" LFO shape no longer retriggers from zero
- Improved: ADSR now has better scaling on the low range (more small values)
- Improved: PITCH mod destination amount now has better scaling on the low range
- Improved: Play button always stops if sequence is running (regardless of phrase / chain / song playback)
- Improved: FX list view has a new category for instrument envelopes
- Improved: Trig envelope now triggers correctly if the trigger event happened before the instrument started
- Improved: Delay send FX now has a mono/summed input (was left channel only before)
- Improved: Pre-load samples on song queued load for better initial triggering of samples
- Fix: When out of phrases, cloning did not display an error- Fix: Disable remote display for boot options view
- Fix: Instrument - Delete shortcut ([OPT]+[EDIT]) on LOAD or SAVE instrument deleted characters from instrument name
- Fix: Tearing artifact on value sliders (more prevalent on Model:02)
- Fix: Instrument Mod - Trig envelope did not work correctly when using multiple instruments (some without a trig mod) in the same track
- Fix: Big-font mode song navigation issue on track 8 if the info area appeared
- Fix: Info area mini-map displayed the wrong [P] position when navigating up from Chain view
- Fix: Phrase - When using scales it was possible to edit notes past note number 127
- Fix: Cursor clearing issues on big font mode when toggling right side info area
- Fix: When editing down a note using scale on the lowest octave, it could toggle between C-1 and the lowest scale note
- Fix: Sample Editor - Xfade loop could cause distortion with 24 bit wav files
- Fix: DEL (Delay FX command) with a HOPFF in the same row caused a crash
