Critter & Guitari Pocket Piano Mini Electronic Synthesizer
Anonymous
http://www.ebay.de/itm/Critter-Guitari- ... 2a413123ea
schaut lustig aus :mrgreen:
http://www.ebay.de/itm/Critter-Guitari- ... 5d4e9d65e5
The Pocket Piano is a mini electronic synthesizer with a big sound. The synthesizer features 6 unique modes:
Vibrato synth
Harmonic sweeper
2-Octave arpeggiator
Octave cascade
Mono FM synth
FM arpeggiator
The Pocket Piano is housed in a sturdy aluminum and hardwood case and also includes a built-in speaker, a 1/4" output jack, and wooden keys made for a refined touch. It can be powered both by a 9V battery or a 9V DC Power Supply (not included).
When you change modes with the right-most wooden button, a color LED above that button indicates what mode is selected with a different color for each mode. The entire keyboard may be tuned over a 2 octave range by turning the knob second from right. Volume is controlled by the right-most knob. The function of the remaining two left knobs depend on what mode is selected, and are described below. There is also a button that selects waveform (sine, square, triangle, sawtooth) in the first four modes, and shifts the keyboard an octave higher in the last two modes.
Re: Critter & Guitari Pocket Piano Mini Electronic Synthesiz
Ich finde den Bolsa Bass auch cool. (: Hatte greade eben noch nen plausch mit Guitari, die sind fleißig am schrauben die beiden. Die Nachfrage steigt :supi: Der Kaleidoloop geht in Moment am besten weg.
Das Teil hat schon den Weg in den Mainstream gefunden.
Mal das "Achtung Fertig"-Album von 2raumwohnung gesehen?
Schöne Grüße,
Bert
Kaleidoloop ich habs bei EBAY gefunden...gleich mal googeln, was du meinst ;-)
http://turntablelab.com/products/critte ... oloop-teal
das hier, schaut auf den ersten Blick wie eine Thermin aus :denk:
can i Loop?
src: http://soundcloud.com/critterandguitari/kaleidoloop-forward-and?in=critterandguitari/sets/kaleidoloop-samples
he Critter & Guitari KALEIDOLOOP is a social, portable sound collector. It’s designed to be taken anywhere and everywhere to gather and manipulate all kinds of sounds. Record sounds from your kitchen, the recording studio, and campfire jam.
Use several KALEIDOLOOPS to build up layers of sound, pass a sound from one to another and play with resonance, invent new musical games, practice speaking in reverse, alter playback speed and explore new harmonies, carry sounds around the room... the list is endless. Best of all the KALEIDOLOOP stores everything it records, so you have a rec rd of your sound journey.
The KALEIDOLOOP features simple controls for recording, navigating sounds, and altering playback speed and direction. The included microphone and built-in speaker make the perfect pair, with enough clarity and volume to recreate sounds with alarming realism. You can also remove the microphone and use the 1/4" input and output jacks instead.
- See more at: http://turntablelab.com/products/critte ... 2w96N.dpuf
hab gerade auf der c&g website gelesen, dass pocket pianos welche vor 2014 gebaut werden nun nicht mehr von c&g geupdated werden. das ist echt schade, denn ich habe so eins und vermisse den im aktuellen update vorhandenen "holD2 mode schmerzlich. ist es möglich dieses update irgendwie selbst durchzuführen?
schätze man wird ein bestimmtes chip-schreib-gerät brauchen, aber wenn man das hätte bzw jemanden kennt, wäre es dann machbar?
