WTF?! Soll man sich jetzt noch Reaktor3 zusätzlich zur 5er kaufen, damit man alte Sachen aufmachen kann ???Native Instruments schrieb:Ensembles saved with REAKTOR 3 will not open in REAKTOR 5 unless the REAKTOR 3 USB copy protection key is plugged in. If you have the key, install it and plug it into your USB port, then open the REAKTOR 3 ensembles in REAKTOR 5 and save them as REAKTOR 5 files. Once you’ve done this, you’ll be able to open the ensemble files without using the key. There is also a Batch Processing function to perform the convertion of many files at once.
