dilettant
Proud 2 be a gearslut
http://www.synthtopia.com/content/2...ttery-powered-west-coast-modular-synthesizer/
Ahead of the 2019 NAMM Show, Korg has officially introduced the volca modular – a powerful mini-modular, featuring eight modules, 50 patch points, a step sequencer, microtonal support and more.
Korg describes the volca modular as ‘A fusion of West Coast style in a volca format’.
Here’s what they have to say about it:
Synthesizers of the “West Coast style” evolved in a uniquely different direction from such musical developments. Pursuing the freedom that is inherent to electronic musical instruments, these were based on oscillators such as FM modulation which generated numerous overtones, and used random and complex control signals and low-pass gate circuits to vary tonal character and volume, so that slight movement of a knob might dramatically transform the sound. While their potential was acknowledged, the resulting sound and its changes were difficult to predict, causing these synths to be used in a more experimental capacity.
For these reasons, hardware products of this style have been few in number. However, recent years have seen the popularity of modular synths such as Eurorack, as well as DAW plugin instruments that resurrect classic bygone synths of the past. This world-wide movement toward embracing interesting sounds has received renewed attention, spurring a new look at the sounds of this style.
Starting from analog, and freely taking in all elements including FM and PCM, the volca series has also focused on this trend. And now, this distinctive “West Coast style” sound has been added to the KORG volca series.
The Korg volca modular features 8 modules:
Korg Volca Modular Video Intro:
Pricing and Availability
The volca modular will both be available in early 2019, priced at $199.99. See the Korg site for more info.
- SOURCE: This consists of a triangle VCO carrier and a modulator. The complex overtones generated by FM modulation are sent through a wave folder circuit to add additional overtones, producing a distinctive sound. This module is important in determining the basic character of the sound of volca modular.
- FUNCTIONS: This section consists of two function (envelope) generators. In addition to an ADH generator with attack, hold, and release, there’s a Rise-Fall generator, also known as a slope generator, which not only applies time-varying change to the sound but also lets you patch the end trigger out back into the trigger in as a loop, making it usable as a VCO or LFO.
- WOGGLE: This is a random signal generator containing a sample & hold circuit that uses pink noise as its source. Two outputs are provided, allowing it to output either stepped or smooth random noise.
- SPLIT: This module distributes one input to two outputs. It can also be used in the reverse direction, combining two control or audio signals into one.
- DUAL LPG: This consists of two low-pass gate circuits. Typical of the West Coast style of synthesis, the module packages a filter with an amp, allowing the brightness and volume of the sound to vary together.
- UTILITY: This is a mixing scaling module that combines two signals in various ways. It can mix not only audio signals but also control signals, as well as inverting or attenuating those signals.
- SPACE OUT: This is a stereo module that applies a reverb-like effect to the audio signal.
- SEQUENCES: This module is for connecting to the internal sequencer. You can set the tempo, and select different rhythm divisions to output via the gate counter.
