ORCHID | chord generating synthesizer
ich frag mich vro allem immer was bei den kunden nicht stimmt. welcher normale mensch, der älter als 5 ist, kann denn auch nur irgendwas mit einem 1-oktaven-keyboard anfangen?
und dann werden einem diese kinderspielzeuge immer so präsentiert als ob jemand den konzertflügel neu erfunden hätte.
geht doch ;-)
M.i.a.u.: robworld
Gibt inzwischen ne (kostenlose) Patreon-Seite.
This Wednesday, 4th December from 2pm PST / 5pm EST Tom, Telepathic Technical Director and co-founder, is going to be answering your questions. The AMA will be text-based, and he’ll be answering as much as he can, for as long as he can.
Re. US release
Pre-order will be available on the 18th of December, with the Orchids shipping late-Jan!
Weiterhin noch re. global release:
This is because we can only get certification for the US right now. We're going through the motions to make sure we can get Orchid into other markets as soon as possible but I can say that it'll be in the first half of 2025.
Our wider release will be in the first half of 2025!
Uuund noch ein paar Infos, während ich so durch die Threads auf Patreon klicker:
Bluetooth-MIDI support?
Unfortunately there's no Bluetooth planned at this time, however we do offer USB MIDI and 5 pin DIN MIDI outputs
pitch-bend? velocity? aftertouch?
Velocity 100%, pitch-bend and aftertouch... good ideas to add to future firmware updates. I'll add them to the list of potential features
If first users have the opportunity to "shape and refine" the Orchid, does this mean there will be future firmware updates to the device to access the new features?
Yes indeed! The first 1000 units will come with all the fully functional features we think is best, but then we want to hear from YOU and release versions based on what you'd like to see.
Is there any way to save / recall sequences?
There's a Loop mode that lets you record sequences real time, play them back, and even overdub. There's also a pattern sequencer as part of the performance features (think of it as an arpeggiator with custom patterns!).
Audio is output through a 3.5mm headphone jack located on the back of the unit
Just wondering what was the thought process behind not having a line output and/or headphone output?
We included a headphone output! We went with headphone over line because it offers the flexibility to use Orchid on the move, while still being functional in a studio setting with some tweaks. Opting for just a line output would have limited portability for those relying on headphones when creating away from a studio.
M.i.a.u.: oli
Das sind doch fast alles gute Nachrichten (kein Bluetooth bzw. Aftertouch kann ich persönlich gut verschmerzen, und für "richtige" Stereo-Ausgangsbuchsen braucht's nur ein Y-Kabel).
Lass mal die ersten amerikanischen Nutzer den Orchid feinschleifen, und wenn dann der ganze CE-Kram etc. geregelt ist, kriegen wir im Rest der Welt ein (hoffentlich) ausgereiftes Instrument.
Ich wünsche den Herstellern jedenfalls Erfolg dabei - und wenn sie das Ding gestemmt kriegen und es bei uns verfügbar machen, werde ich bestimmt einer der ersten Besteller sein.
Schöne Grüße
Bert
M.i.a.u.: oli und hardberg
  • #34
Hier noch ein paar zusätzliche Infos vom AMA:
Orchid sends the bass note to one MIDI channel and the chord notes to a separate MIDI channel as they are played, so arpeggiation comes through via MIDI. Separately, Orchid also sends all the notes of chord at once on yet another MIDI channel.
Will the keys be velocity sensitive? What about aftertouch or poly-aftertouch
Yes to velocity! No to aftertouch
What are the dimensions of it?
Measuring by hand (This may be subject to slight change)306mm x 186mm x 50mm
2) the looper — excellent thing to have! can you please please make it sync to a midi clock?
2) Syncing is something I'll need to talk more to our development team about. In the first release, it will be using it's own internal clock.
8 Chords styles it's not a Limitation for make modern Music ? & it's possible to make Chords Inversion ?
The left hand keys allow you to create quite a large amount of chord types. While there are the standard triads (Dim, Maj, Min, Sus), the other four let you add extensions.. all four of them if you like! So it's not just 8 chords, but 64 (in theory).Yes to Chord Inversions, it's one of the main features of the unit.
Can the Orchid do quarter tones?
unfortunately not - we've decided to go with semi tones as our smallest increment
Would love to hear about the internals, specifically as to what’s powering the synth engine?
during roll out things will be a closed system. The internal synth engine is a BEAST with many different features and engines unlike I've seen before.. as to giving users access to this - this will be discussed later down after the release date as there's more work to be done there, we just want to get this in peoples hands ASAP.
(gab auch noch ne Antwort, dass die Synth-Engine intern entwickelt wurde. Und dass keine Samples verwendet werden)
(und ausserdem gibt es keine drums)
will there be something different about the first 1000 units vs the larger worldwides batches after? i.e. numbered units 1-1000 for the first batch or signed by the team? or different color for the first batch?
We have no plans to change anything cosmetically or that would affect the operation of the device, V1 and V2 will operate identically, apart from shipping with the latest firmware, but users of all units can update theirs to the latest at any time.
Could you speak to some of the music theory behind the orchid? How will the buttons work in creating harmonic step motion? I know some music theory, and there seems to be many possibilities in creating pretty chords and extensions
The Chord Logic engine we've built doesn't necessarily stray from traditional music theory in any way (we wouldn't dare try to recreate musical theory - imagine the comments) - the magic happens in the way it deals with chord progressions and inversions. It creates smooth, natural transitions which brings a human element with it. It's like a jazz pianist would play chords, rather than a computer. The algorithm selects notes that feel natural and pleasing to hear each new chord you play.This does expand outward into experimental land a bit with Key mode, where it Quantizes (harmonically) into fixed keys / notes, which makes crafting chords effortless... I've personally made many MANY happy little accidents. But, when the accidents aren't happy / dissonant, you're a few button pushes away from resolving the tension with something pleasing - and then you've created a happy little sonic story.When I studied musical theory, my teacher once told me "if you ever hit a wrong note, you're only two semitones max away from resolving it" - this has stuck with me for years.. and with Orchid, the same logic applies - but to chords rather than individual notes
Und dann gibt es noch ein neues Video, das (sehr...) kurz den looper-mode zeigt:
Key-mode (quantization auf ne scale):
M.i.a.u.: oli und robworld
  • #35
Die Möglichkeit der Synchronisation mit anderen Sequencern wäre für mich ein extrem wichtiges Detail - aber da werden sie auch nicht drumrumkommen, das langfristig zu implementieren, denke ich.
Hoffen wir mal das Beste...
Schöne Grüße
Bert
M.i.a.u.: robworld und dubsetter
ich hab da schon etwas zweifel:
ob ein 1-oktaven-keyboard so ideal fuer die grundton-wahl ist?
ob man fuers voicing wirklich gerne am encoder kurbeln will?
ob die akkordtypen-wahl ausreicht?
mir scheint der ndlr da erstmal das rundere konzept
wenn auch komplexer, aber nicht teurer.
das retro-design ist natuerlich geschmackssache.
ein "ndler-light" (nur eine ebene, aber ein paar mehr hands-on knoeppe oder so)
waere vielleicht nett...
  • #38
das design erinnert mich gerade nen büschn an BRAUN...
Für Braun sind die Taster zu eckig.
Das Design ist aber schon sehr "retro", und ich überlege schon die ganze Zeit, wo ich sowas schonmal gesehen habe - 70er/80er Radiowecker, Sprechanlage, Tischorgel, Telefon, Tischrechner. Alleine schon die Gehäuseform mit den Lüftungsschlitzen und die Farben sind sehr charakteristisch, aber ich komm nicht drauf.
Hier sind doch eigentlich genug 60er Jahrgänge (und älter) versammelt die sich an ein Gerät dieser Optik erinnern könnten :)
  • #41
Schwer zu sagen. Von der Form her ist das für mich eher 70er, aber die Farbe ist mehr 80er. Auf jeden Fall spricht es den Nostalgiker in mir an!
Edit: Vielleicht so etwas? Ist von Kleinanzeigen :D
Zwar was völlig anderes, aber da kommt mir auch wieder Rosita Stereo Commander in den Sinn. Und jetzt genug OT von meiner Seite (sorry!)
M.i.a.u.: oli, dubsetter, robworld und eine weitere Person
  • #42
Ja, genau das ist das Problem. Es gab durchaus einige solche Geräte von meist deutschen Herstellern mit ähnlichem Design, zB SABA oder Grundig, aber ich hab da noch nicht genau das gefunden, was ich vorm inneren Auge habe. Das Korg SV-1/2 ist da von der Gehäuseform her durchaus ählich gelagert.
M.i.a.u.: oli und HairyHands
  • #43
Mich erinnert es so ein bischen an die alten Tisch-Rechenmaschinen:
M.i.a.u.: oli, dubsetter, microbug und 2 andere
  • #44
Ha, so einen Weltron-Radiowecker hab ich auch.
Allerdings in einer Farbe, die früher mal schneeweiß war, sich jetzt aber der Orchid-Farbe annähert (und dadurch viel besser zum Rest der Schlafzimmereinrichtung passt).
Funktioniert tadellos, auch das Radio. Toller Sound sogar! Fünf Euro vom Flohmarkt.
Ich bin sehr gespannt auf das Orchid-Teil - besonders, ob das mit der Synchronisation noch was wird.
Schöne Grüße
Bert
  • #45
Naja, wenn, dann höchstens über den USB-Port, denke ich - die hatten erwähnt, dass sich an der Hardware nix mehr (groß) ändern wird.
Was mich dazu noch ein bisschen abtörnt, ist der alleinige Kopfhörerausgang (nagut, das wäre noch zu verkraften) und dass (gefühlt) alle Demos nur den Ton von den integrierten Lautsprechern aufnimmt. Das soll natürlich die "Ungebundenheit" unterstreichen, könnte aber auch in mangelndes Vertrauen in die Klangqualität gedeutet werden
Anyway, morgen nachmittag PST gibts nen "password drop" für die Webseite, über die man dann first-come-first-served bestellen kann (1000 Geräte auf 8000+ Mitglieder im patreon).
Ich schau mir das erstmal an. $550 plus shipping sind dann doch etwas viel...
  • #46
Ich möchte nochmal sagen, dass mich einige Features und Workflows doch sehr an den Midicake Arp erinnern, der aber zum großen Unterschied keine eigene Tonerzeugung hat.
  • #47
Himmel, dieses Grün - bei WV/Audi hieß das "Manila Grün" oder so, gab auch ganze Jugendzimmergarnituren in dieser Farbe.
Ich kann mich auch an einen Designentwurf für den Minimoog erinnern, der ähnlich aussah ("Wannen-Design"), hatte ich mal auf so einem Extra-Blatt, müßte ich mal suchen, leider kein Bild davon im Netz gefunden bzw nicht den richtigen Suchbegriff benutzt.
M.i.a.u.: HairyHands
  • #49
Ich finde das Ding interessant, um per Midi andere Sachen anzusteuern. Aber nur dafür auch wieder ein bisserl teuer.
  • #50
Im Badezimmer nannte mann das "Mossgrün"!:sowhat:
  • #51
Vielleicht sowas wie das SABA RC11 in der Art mit der geschwungenen Gehäuseform?
M.i.a.u.: robworld
  • #52
Generell scheint mir das Design von Orchid an der Space Age Ästhetik der 70er angelehnt zu sein.
Wie z.B. am Weltron 2002.
Man beachte auch die Preise für solche Space Age Elektronik…
M.i.a.u.: robworld
  • #54
Nochmal was von Weltron…
Hier auf der Seite sind übrigens sehr viele schicke und schick fotografierte Produkte aus der Zeit.
  • #56
Gab mal wieder ein Update:
If you're an owner of the First 1000 Orchids, you'll be receiving a shipping confirmation in your email, along with an ECMS tracking number
Dann wird es vermutlich bald eine Schwemme entsprechender Influencer-Videos geben... hurra?
(an mich geht übrigens keiner - das war mir dann doch ein bisschen teuer)
  • #58
Ich geb's zu, es ist etwas unfair, das gerade hier im Thread zu fragen, aber hier ist die Chance auf Antwort halt hoch:
Kürzlich wurde hier ein anderes, auch Akkorde erzeugendes Gerät vorgestellt, und zwar anhand eines Videos, in dem eine junge Frau mit asiatischem Aussehen das Gerät präsentierte.
Was war das für'n Teil?
Ich kann mich nicht an den Namen erinnern...
Danke für Hinweise!
Schöne Grüße
Bert
  • #60
Danke dir!
Aber die waren's alle drei nicht. Und Kordbot auch nicht, und auch nicht dieses Mini-Omnichord.
Muss was Neueres sein (NAMM?), das Video hab ich erst vor ein paar Wochen gesehen.
Kleines schwarzes (?) Gerät, von einer jungen Asiatin auf Englisch vorgeführt.
Der Witz (für mich) war dabei, dass man gefundene Akkorde auf Buttons speichern kann, um Akkordfolgen zu generieren.
Und ich meine, der Tipp war hier aus dem Forum gekommen.
Schöne Grüße
Bert
