Per-part arpeggiator
Each of the eight parts now have individual, independent arpeggiators, for building complex polyrhythmic patterns.
Arpeggiator probability
The new arpeggiator probability feature brings an element of randomness to each arpeggiator, turning SL MkIII into a generative and constantly evolving instrument.
Step probability
The probability of a programmed step can be altered, bringing creative irregularity and extending the musical palette of the SL MkIII.
Sequencer transpose (with pads)
The SL MkIII’s pads can now be used to make sequencer transposition a powerful performance tool.
Pattern octave transpose
Allows patterns to be transposed across the octave range, to find the perfect pitch and experiment with ideas.
Toggle swing per-part
With swing on or off per part, it’s possible to build contrasting layers of groove for more complex rhythmic results.
Pattern shift
Now it's possible to quickly offset the start and end points of a pattern together to explore variations and manage sequences.
Pitch bend to CV
The pitch-bend wheel can now be mapped to the CV output, opening up more expression possibilities for modular synth users and other external hardware control applications.
In addition to the new performance features, v1.4 includes some bug fixes — including one for Logic Pro users — which improve the SL MkIII exprience.
To download the v1.4 firmware update, connect your controller via USB and navigate your browser to Novation Components, then follow prompts on screen.
... und auch für BitwigBleibt in der Hauptsache doch nur ein Abelton Live Controller mit CV Support.
neinhat das immer noch dieses bescheuerte automap ?
das ist auch mein Hauptkritikpunkt... Ansonsten, bevor ich das vergesse, ein tolles Teil! Ich nutze den Sequencer nicht/wenig und missbrauche die midi-Spuren-Zuordnung zum jammen - ich hätte gerne mehr rudimentäre Masterkeyboard-Funktionalität, die Splits zB bräuchte ich nicht einmal, einfach zum live-jammen flexibel per Knopf all meine Outboard-Synths ansteuern. Das mit den Templates (davon könnte es gerne mehr geben...) ist ja schonmal ein Ansatz (nur das ich zu blond bin komplexe Program-Change Befehle zu senden.... das bin aber wohl eher ich und nicht die fehlende Möglichkeit). Möglich sein sollte das Software/Firmware-technisch... Vielleicht nimmt @Moogulator das ja kurzfristig in den Stream mit auf?nur 2x8 Midi Controller pro Template, die dann auch noch umständlich über das Menü ausgewählt werden müssen
