The new Novation Circuit Rhythm is a powerful and versatile sampler for creating beats and using in live situations. Using the highly intuitive bezel-less top panel, beatmakers can record samples directly to the hardware and then effortlessly cut, edit and resample those sounds. Recorded grooves can be quantized or captured off-grid by the sequencer, and layers can be built over eight sample tracks.
Live sets come to life with built-in performance FX: performers can embrace imperfection with lo-fi tape effects and use beat repeat to shred the main mix (and more). For studio-based artists, the Novation Circuit Rhythm can be integrated into any MIDI compatible studio rig. Of course, the Rhythm can also be disconnected to make beats anywhere using the built-in rechargeable battery.
Sample and resample,
Record samples directly to the hardware and effortlessly edit, shape and resample your sounds.
Slice, reverse, loop, play chromatic and more
Play samples the way you choose, whether you’re recording straight from vinyl, creating bass lines and melodies, or playing drums.
Play with Grid FX
Boost your live set with performance FX: embrace imperfection with lo-fi tape, shred your mix with beat repeat and more.
Eight Sample Tracks
Create beats with eight sample tracks, each with their own 32-step patterns, you can chain up to 256 steps per track.
clear beatmaking workflow
Go from a sample to a complete beat with ease with the powerful and practical sequencer.
Go off-grid
Capture your groove quantized or off-grid in the sequencer, and keep your beats interesting with the probability and pattern mutate functions.
FX on everything
Immerse samples in luscious reverb and delay, pump your mix with sidechain and punch with the master compressor.
Extensive connectivity
Connect to your studio with full-size five-pin MIDI in, out and thru. Sample via stereo inputs and listen via stereo out or with headphones.
Never stop creating
Use a microSD card to endlessly store and access projects.
Create anywhere
The built-in rechargeable battery offers a battery life of up to four hours, so you can make beats on the go.
Included with Circuit Rhythm
USB-C cable, USB power supply, safety information
Compatibility
Circuit Rhythm is class compliant, so it works with any modern Mac or Windows PC.
Details
32 RGB backlit velocity sensitive pads
28 RGB backlit tactile click knoppen
Aan / uit knop met oplaad status LED
USB-C ingang
Kensington MiniSaver Slot
3x MIDI DIN (In, Out, Thru)
MicroSD card slot
5mm Sync Out
Stereo Audio In (Mono Summed)
Unbalanced Stereo Out
Headphones out
8x Endless Encoder Macro knoppen met RGB indicatoren
Volume knop
Master Filter knob
