Neues Battery 3-Update
Hi,
für alle 'Betroffenen'. NI hat für Battery 3 ein neues Update rausgetan: Battery 3.1.1 (R532)
Gruss
...hab ich da n Bug gefunden?
wenn ich den MIDI-Learn Modus verwende um einen Drehregler zuzuweisen, kann ich diese Zuordnung danach nicht mehr löschen;
da steht zwar "Cancel Learn Midi Automation" aber der Drehregler bleibt weiterhin zugewiesen...oder mach ich da wat falsch??? :roll:
Mmmh, mal testen und das hier sei nachgereicht:
We're pleased to announce that the BATTERY 3.1 update is now available for free download. The update contains several new
features and workflow improvements, and some fixes.
Mac® users please note: This version requires an Intel Mac® and Mac® OS X 10.5 (or later)!
You can download the update via the NI Service Center or the Online Update Manager [1].
We strongly recommend downloading and installing this update to ensure the best possible user experience and reliability.
Main new and improved features:
- Vintage Emulations: As of version 3.1, you can emulate the sound characteristic of the two vintage drum machines MPC60* and SP-1200*,
with four different settings from 'low' to high'. You may apply individual settings to every single cell.
- Improved MIDI Learn: BATTERY 3.1 features an improved MIDI Learn function for all automatable sliders and knobs - it is applied by
simply clicking the right mouse button / ctrl-click, making assigning MIDI controllers a breeze.
- Mac OS® X: 64bit support for Audio Unit and standalone version.
- Multiprocessor support to deliver even better performance on modern Multiprocessor systems.
- Loading Behavior: You can now set the desired loading behavior in BATTERY when double-clicking a loadable file in the Browser View Tab, to adjust it to your personal workflow.
- Improved Samples Missing Dialog: The Samples Missing dialog now remembers your selection of the search folder for subsequent appearances. This is especially useful if numerous BATTERY Kits or a host project have been moved to a different folder, normally resulting in multiple Samples Missing dialogs. Now you only have to specify the new search folder once.
Gruss
Ich kann auch die Automap-version von Battery nicht mehr aufmachen, seit ich das update installiert habe!
Da erscheint dann ein leeres Fenster mit den Parameternummern... hm, so ein sch***
muss ich ma selber zitieren...
also das Automap-Fenster braucht man dazu um die mit Midi-Learn zugewiesenen Controller wieder zu löschen.
Wenn ich n frischen Battery aufmache steht bei mir nur ein Controller (Modulation) drin.
Ich wills ja nicht fix zugewiesen haben, sondern mir mit Automap, jetzt, da es endlich unkompliziert gehen soll bei Battery, eine Controlmap bauen, die immer dann erscheint, wenn ich auf eine Spur mit Battery gehe...
Aber naja, muß ich wohl auf ein neues Update warten, vielleicht gehts ja dann..
Scheint mal wieder Bananensoftware ("Reift beim Kunden") zu sein. Ich lasse lieber vorerst alles so wie es ist.
