Parameter,MIDI string,LCD string,Min value,Max value
Osc 1 Octave,F03E0E002000000100F7,Osc 1 Octave,16,112
Osc 1 Semitone,F03E0E002000000200F7,Osc 1 Semitone,52,76
Osc 1 Detune,F03E0E002000000300F7,Osc 1 Detune,0,127
Osc 1 Pitch Bend Range,F03E0E002000000500F7,Osc1 PtchBnd Rng,0,122
Osc 1 Keytrack,F03E0E002000000600F7,Osc 1 Keytrack,0,76
Osc 1 FM Amount,F03E0E002000000700F7,Osc 1 FM Amount,0,127
Osc 2 Octave,F03E0E002000000C00F7,Osc 2 Octave,16,112
Osc 2 Semitone,F03E0E002000000D00F7,Osc 2 Semitone,52,76
Osc 2 Detune,F03E0E002000000E00F7,Osc 2 Detune,0,127
Osc 2 Sync,F03E0E002000001000F7,Osc 2 Sync,0,1
Osc 2 Pitch Bend Range,F03E0E002000001100F7,Osc2 PtchBnd Rng,0,122
Osc 2 Keytrack,F03E0E002000001200F7,Osc 2 Keytrack,0,76
Osc 2 Link,F03E0E002000001300F7,Osc 2 Link,0,1
Wavetable,F03E0E002000001900F7,Wavetable,0,127
Wave 1 Startwave,F03E0E002000001A00F7,Wave 1 Startwave,0,63
Wave 1 Start Phase,F03E0E002000001B00F7,Wave1 Srt Phase,0,127
Wave 1 Envelope Amount,F03E0E002000001C00F7,Wave 1 Env Lev,0,127
Wave 1 Envelope Velocity Amount,F03E0E002000001D00F7,Wave1 Env Vel Lv,0,127
Wave 1 Keytrack,F03E0E002000001E00F7,Wave 1 Keytrack,0,127
Wave 1 Limit,F03E0E002000001F00F7,Wave 1 Limit,0,1
Wave 2 Startwave,F03E0E002000002400F7,Wave 2 Startwave,0,63
Wave 2 Start Phase,F03E0E002000002500F7,Wave2 Srt Phase,0,127
Wave 2 Envelope Amount,F03E0E002000002600F7,Wave 2 Env Lev,0,127
Wave 2 Envelope Velocity Amount,F03E0E002000002700F7,Wave2 Env Vel Lv,0,127
Wave 2 Keytrack,F03E0E002000002800F7,Wave 2 Keytrack,0,127
Wave 2 Limit,F03E0E002000002900F7,Wave 2 Limit,0,1
Wave 2 Link,F03E0E002000002A00F7,Wave 2 Link,0,1
Mix Wave 1,F03E0E002000002F00F7,Mix Wave 1,0,127
Mix Wave 2,F03E0E002000003000F7,Mix Wave 2,0,127
Mix Ringmod,F03E0E002000003100F7,Mix Ringmod,0,127
Mix Noise,F03E0E002000003200F7,Mix Noise,0,127
Aliasing,F03E0E002000003500F7,Aliasing,0,5
Time Quantization,F03E0E002000003600F7,Tme Quantization,0,5
Clipping,F03E0E002000003700F7,Clipping,0,1
Accuracy,F03E0E002000003900F7,Accuracy,0,1
Play Parameter #1,F03E0E002000003A00F7,Play Parm #1,0,82
Play Parameter #2,F03E0E002000003B00F7,Play Parm #2,0,82
Play Parameter #3,F03E0E002000003C00F7,Play Parm #3,0,82
Play Parameter #4,F03E0E002000003D00F7,Play Parm #4,0,82
Filter 1 Cutoff,F03E0E002000003E00F7,Filter 1 Cutoff,0,127
Filter 1 Resonance,F03E0E002000003F00F7,Filt 1 Resonance,0,127
Filter 1 Type,F03E0E002000004000F7,Filter 1 Type,0,9
Filter 1 Keytrack,F03E0E002000004100F7,Filt 1 Keytrack,0,127
Filter 1 Envelope Amount,F03E0E002000004200F7,Filt 1 Env Lev,0,127
Filter 1 Envelope Velocity Amount,F03E0E002000004300F7,Flt1 Env Vel Lev,0,127
Filter 1 Special Parameter,F03E0E002000004600F7,Filt 1 Spec Parm,0,127
Filter 2 Cutoff,F03E0E002000004900F7,Filter 2 Cutoff,0,127
Filter 2 Typ,F03E0E002000004A00F7,Filter 2 Typ,0,1
Filter 2 Keytrack,F03E0E002000004B00F7,Filt 2 Keytrack,0,127
Effect Type,F03E0E002000004C00F7,Effect Type,0,7
Amplifier Volume,F03E0E002000004D00F7,Amplifier Volume,0,127
Amplifier Envelope Velocity Amount,F03E0E002000004F00F7,Ampl Env Vel Lev,0,127
Amplifier Keytrack,F03E0E002000005000F7,Ampl Keytrack,0,127
Effect Parameter #1,F03E0E002000005100F7,Effect Parm #1,0,127
Chorus,F03E0E002000005200F7,Chorus,0,1
Effect Parameter #2,F03E0E002000005300F7,Effect Parm #2,0,127
Panning,F03E0E002000005400F7,Panning,0,127
Panning Keytrack,F03E0E002000005500F7,Panning Keytrack,0,127
Effect Parameter #3,F03E0E002000005600F7,Effect Parm #3,0,127
Glide Active,F03E0E002000005700F7,Glide Active,0,1
Glide Type,F03E0E002000005800F7,Glide Type,0,3
Glide Mode,F03E0E002000005900F7,Glide Mode,0,1
Glide Time,F03E0E002000005A00F7,Glide Time,0,127
Arpeggiator Active,F03E0E002000005C00F7,Arp Active,0,2
Arpeggiator Tempo,F03E0E002000005D00F7,Arp Tempo,1,127
Arpeggiator Clock,F03E0E002000005E00F7,Arp Clock,0,15
Arpeggiator Range,F03E0E002000005F00F7,Arp Range,1,10
Arpeggiator Pattern,F03E0E002000006000F7,Arpeggiator Patt,0,127
Arpeggiator Direction,F03E0E002000006100F7,Arp Direction,0,3
Arpeggiator Note Order,F03E0E002000006200F7,Arp Note Order,0,3
Arpeggiator Velocity,F03E0E002000006300F7,Arp Velocity,0,1
Arpeggiator Reset on Pattern Start,F03E0E002000006400F7,Arp Reset on Pat,0,1
Arpeggiator User Pattern Length,F03E0E002000006500F7,Arp Usr Patt Lgt,0,15
Arpeggiator User Pattern Pos 1,F03E0E002000006600F7,Arp Usr Patt Pos,0,4
Arpeggiator User Pattern Pos 5,F03E0E002000006700F7,Arp Usr Patt Pos,0,8
Arpeggiator User Pattern Pos 9,F03E0E002000006800F7,Arp Usr Patt Pos,0,12
Arpeggiator User Pattern Pos 13,F03E0E002000006900F7,Arp Usr Patt Pos,0,16
Allocation Mode,F03E0E002000006C00F7,Allocation Mode,0,1
Assignment,F03E0E002000006D00F7,Assignment,0,2
Detune,F03E0E002000006E00F7,Detune,0,127
DePan,F03E0E002000007000F7,DePan,0,127
Filter Env Attack,F03E0E002000007100F7,Filt Env Attack,0,127
Filter Env Decay,F03E0E002000007200F7,Filter Env Decay,0,127
Filter Env Sustain,F03E0E002000007300F7,Filt Env Sustain,0,127
Filter Env Release,F03E0E002000007400F7,Filt Env Release,0,127
Filter Env Trigger,F03E0E002000007500F7,Filt Env Trigger,0,2
Amplifier Env Attack,F03E0E002000007700F7,Ampl Env Atk,0,127
Amplifier Env Decay,F03E0E002000007800F7,Ampl Env Dec,0,127
Amplifier Env Sustain,F03E0E002000007900F7,Ampl Env Sust,0,127
Amplifier Env Release,F03E0E002000007A00F7,Ampl Env Rel,0,127
Amplifier Env Trigger,F03E0E002000007B00F7,Ampl Env Trig,0,2
Wave Env Time 1,F03E0E002000007D00F7,Wave Env Time 1,0,127
Wave Env Level 1,F03E0E002000007E00F7,Wave Env Level 1,0,127
Wave Env Time 2,F03E0E002000007F00F7,Wave Env Time 2,0,127
Wave Env Level 2,F03E0E002000010000F7,Wave Env Level 2,0,127
Wave Env Time 3,F03E0E002000010100F7,Wave Env Time 3,0,127
Wave Env Level 3,F03E0E002000010200F7,Wave Env Level 3,0,127
Wave Env Time 4,F03E0E002000010300F7,Wave Env Time 4,0,127
Wave Env Level 4,F03E0E002000010400F7,Wave Env Level 4,0,127
Wave Env Time 5,F03E0E002000010500F7,Wave Env Time 5,0,127
Wave Env Level 5,F03E0E002000010600F7,Wave Env Level 5,0,127
Wave Env Time 6,F03E0E002000010700F7,Wave Env Time 6,0,127
Wave Env Level 6,F03E0E002000010800F7,Wave Env Level 6,0,127
Wave Env Time 7,F03E0E002000010900F7,Wave Env Time 7,0,127
Wave Env Level 7,F03E0E002000010A00F7,Wave Env Level 7,0,127
Wave Env Time 8,F03E0E002000010B00F7,Wave Env Time 8,0,127
Wave Env Level 8,F03E0E002000010C00F7,Wave Env Level 8,0,127
Wave Env Trigger,F03E0E002000010D00F7,Wave Env Trigger,0,2
Wave Key On Loop,F03E0E002000010E00F7,Wave Key On Loop,0,1
Wave Key On Loop Start,F03E0E002000010F00F7,Wav Key On Lp Sr,0,7
Wave Key On Loop End,F03E0E002000011000F7,Wav Key On Lp En,0,7
Wave Key Off Loop,F03E0E002000011100F7,Wave Key Off Lp,0,1
Wave Key Off Loop Start,F03E0E002000011200F7,Wav Key Off Lp S,0,7
Wave Key Off Loop End,F03E0E002000011300F7,Wav Key Off Lp E,0,7
Free Env Time 1,F03E0E002000011500F7,Free Env Time 1,0,127
Free Env Level 1,F03E0E002000011600F7,Free Env Level 1,0,127
Free Env Time 2,F03E0E002000011700F7,Free Env Time 2,0,127
Free Env Level 2,F03E0E002000011800F7,Free Env Level 2,0,127
Free Env Time 3,F03E0E002000011900F7,Free Env Time 3,0,127
Free Env Level 3,F03E0E002000011A00F7,Free Env Level 3,0,127
Free Env Release Time,F03E0E002000011B00F7,Free Env Rel Tme,0,127
Free Env Release Level,F03E0E002000011C00F7,Free Env Rel Lev,0,127
Free Env Trigger,F03E0E002000011D00F7,Free Env Trigger,0,2
LFO 1 Rate,F03E0E002000011F00F7,LFO 1 Rate,0,127
LFO 1 Shape,F03E0E002000012000F7,LFO 1 Shape,0,5
LFO 1 Delay,F03E0E002000012100F7,LFO 1 Delay,0,127
LFO 1 Sync,F03E0E002000012200F7,LFO 1 Sync,0,3
LFO 1 Symmetry,F03E0E002000012300F7,LFO 1 Symmetry,0,127
LFO 1 Humanize,F03E0E002000012400F7,LFO 1 Humanize,0,127
LFO 2 Rate,F03E0E002000012600F7,LFO 2 Rate,0,127
LFO 2 Shape,F03E0E002000012700F7,LFO 2 Shape,0,5
LFO 2 Delay,F03E0E002000012800F7,LFO 2 Delay,0,127
LFO 2 Sync,F03E0E002000012900F7,LFO 2 Sync,0,3
LFO 2 Symmetry,F03E0E002000012A00F7,LFO 2 Symmetry,0,127
LFO 2 Humanize,F03E0E002000012B00F7,LFO 2 Humanize,0,127
LFO 2 Phase,F03E0E002000012C00F7,LFO 2 Phase,0,127
Modifier Delay Source,F03E0E002000012E00F7,Modifier Dly Src,0,31
Modifier Delay Time,F03E0E002000012F00F7,Modifier Dly Tme,0,127
Modifier 1 Source 1,F03E0E002000013000F7,Modifier 1 Src 1,0,31
Modifier 1 Source 2,F03E0E002000013100F7,Modifier 1 Src 2,0,31
Modifier 1 Type,F03E0E002000013200F7,Modifier 1 Type,0,15
Modifier 1 Parameter,F03E0E002000013300F7,Modifier 1 Parm,0,127
Modifier 2 Source 1,F03E0E002000013400F7,Modifier 2 Src 1,0,31
Modifier 2 Source 2,F03E0E002000013500F7,Modifier 2 Src 2,0,31
Modifier 2 Type,F03E0E002000013600F7,Modifier 2 Type,0,15
Modifier 2 Parameter,F03E0E002000013700F7,Modifier 2 Parm,0,127
Modifier 3 Source 1,F03E0E002000013C00F7,Modifier 3 Src 1,0,31
Modifier 3 Source 2,F03E0E002000013D00F7,Modifier 3 Src 2,0,31
Modifier 3 Type,F03E0E002000013E00F7,Modifier 3 Type,0,15
Modifier 3 Parameter,F03E0E002000013F00F7,Modifier 3 Parm,0,127
Mod 1 Source,F03E0E002000014000F7,Mod 1 Source,0,31
Mod 1 Amount,F03E0E002000014100F7,Mod 1 Amount,0,127
Mod 1 Destination,F03E0E002000014200F7,Mod 1 Dest,0,33
Mod 2 Source,F03E0E002000014300F7,Mod 2 Source,0,31
Mod 2 Amount,F03E0E002000014400F7,Mod 2 Amount,0,127
Mod 2 Destination,F03E0E002000014500F7,Mod 2 Dest,0,33
Mod 3 Source,F03E0E002000014600F7,Mod 3 Source,0,31
Mod 3 Amount,F03E0E002000014700F7,Mod 3 Amount,0,127
Mod 3 Destination,F03E0E002000014800F7,Mod 3 Dest,0,33
Mod 4 Source,F03E0E002000014900F7,Mod 4 Source,0,31
Mod 4 Amount,F03E0E002000014A00F7,Mod 4 Amount,0,127
Mod 4 Destination,F03E0E002000014B00F7,Mod 4 Dest,0,33
Mod 5 Source,F03E0E002000014C00F7,Mod 5 Source,0,31
Mod 5 Amount,F03E0E002000014D00F7,Mod 5 Amount,0,127
Mod 5 Destination,F03E0E002000014E00F7,Mod 5 Dest,0,33
Mod 6 Source,F03E0E002000014F00F7,Mod 6 Source,0,31
Mod 6 Amount,F03E0E002000015000F7,Mod 6 Amount,0,127
Mod 6 Destination,F03E0E002000015100F7,Mod 6 Dest,0,33
Mod 7 Source,F03E0E002000015200F7,Mod 7 Source,0,31
Mod 7 Amount,F03E0E002000015300F7,Mod 7 Amount,0,127
Mod 7 Destination,F03E0E002000015400F7,Mod 7 Dest,0,33
Mod 8 Source,F03E0E002000015500F7,Mod 8 Source,0,31
Mod 8 Amount,F03E0E002000015600F7,Mod 8 Amount,0,127
Mod 8 Destination,F03E0E002000015700F7,Mod 8 Dest,0,33
Mod 9 Source,F03E0E002000015800F7,Mod 9 Source,0,31
Mod 9 Amount,F03E0E002000015900F7,Mod 9 Amount,0,127
Mod 9 Destination,F03E0E002000015A00F7,Mod 9 Dest,0,33
Mod 10 Source,F03E0E002000015B00F7,Mod 10 Source,0,31
Mod 10 Amount,F03E0E002000015C00F7,Mod 10 Amount,0,127
Mod 10 Destination,F03E0E002000015D00F7,Mod 10 Dest,0,33
Mod 11 Source,F03E0E002000015E00F7,Mod 11 Source,0,31
Mod 11 Amount,F03E0E002000015F00F7,Mod 11 Amount,0,127
Mod 11 Destination,F03E0E002000016000F7,Mod 11 Dest,0,33
Mod 12 Source,F03E0E002000016100F7,Mod 12 Source,0,31
Mod 12 Amount,F03E0E002000016200F7,Mod 12 Amount,0,127
Mod 12 Destination,F03E0E002000016300F7,Mod 12 Dest,0,33
Mod 13 Source,F03E0E002000016400F7,Mod 13 Source,0,31
Mod 13 Amount,F03E0E002000016500F7,Mod 13 Amount,0,127
Mod 13 Destination,F03E0E002000016600F7,Mod 13 Dest,0,33
Mod 14 Source,F03E0E002000016700F7,Mod 14 Source,0,31
Mod 14 Amount,F03E0E002000016800F7,Mod 14 Amount,0,127
Mod 14 Destination,F03E0E002000016900F7,Mod 14 Dest,0,33
Mod 15 Source,F03E0E002000016A00F7,Mod 15 Source,0,31
Mod 15 Amount,F03E0E002000016B00F7,Mod 15 Amount,0,127
Mod 15 Destination,F03E0E002000016C00F7,Mod 15 Dest,0,33
Mod 16 Source,F03E0E002000016D00F7,Mod 16 Source,0,31
Mod 16 Amount,F03E0E002000016E00F7,Mod 16 Amount,0,127
Mod 16 Destination,F03E0E002000016F00F7,Mod 16 Dest,0,33
