Windows Vista features a completely re-written audio stack based on the Universal Audio Architecture. Because of the architectural changes in the redesigned audio stack, a direct path from DirectSound to the audio drivers does not exist.[1] DirectSound and other APIs such as MME are emulated as WASAPI Session instances. DirectSound runs in emulation mode on the Microsoft software mixer. The emulator does not have hardware abstraction, so there is no hardware DirectSound acceleration, meaning hardware and software relying on DirectSound acceleration may have degraded performance. It's likely a supposed performance hit might not be noticeable, depending on the application and actual system hardware. In the case of hardware 3D audio effects played using DirectSound3D, they will not be playable.
Third-party APIs such as ASIO and OpenAL are not affected by these architectural changes in Windows Vista. A solution for applications that wish to take advantage of hardware accelerated high-quality 3D positional audio is to use OpenAL. However, this only works if the manufacturer provides an OpenAL driver for their hardware.[2]
As of 2007, a solution to re-enable hardware acceleration of DirectSound3D and Audio Effects, such as EAX, called Creative ALchemy was launched.[3] Creative ALchemy intercepts calls to DirectSound3D and translates them into OpenAL calls to be processed by supported hardware such as Sound Blaster X-Fi and Sound Blaster Audigy. For software-based Creative audio solutions, ALchemy utilizes its built-in 3D audio engine without using OpenAL at all.
Realtek, a manufacturer of integrated HD audio codecs, has a product similar to ALchemy called 3D SoundBack. C-Media, a manufacturer of PC sound card chipsets, also has a solution called Xear3D EX, although it works instead by intercepting DirectSound3D calls transparently in the background without any user intervention.
