Elektron Digitakt II
1.10A ist draußen (Bugfixes):
  • Kits did not save correctly.
  • Using [FUNC] + [YES] to select a sample for an already populated sample slot jumped to the directory of the previously selected sample rather than the directory of the selected sample.
  • The LEN parameter on the SRC page was not updated on the device after it was first edited using the Overbridge plugin.
  • The Machine selection indication on the device was not updated after changing machine using the Overbridge plugin.
  • In some rare cases, the NOTE parameter setting on the TRIG page could be ignored after updating to OS 1.10.
  • The SRR ROUT parameter’s label did not show the correct name.
  • Previewing a trig with retrig added could sometimes make the sound play indefinitely
  • When loading a preset that previously has been transferred to the device using Transfer, sometimes an incorrect sample could be loaded with the preset.
  • Sample Select NRPN did not switch the sample slots correctly.
  • In rare cases, a sample already present on the device, could erroneously be added again to the device when transferring a project using Transfer.
  • Loading preset from Overbridge plugin didn’t override MIDI machine on device
  • Sometimes a preset’s name was lost after it was added to preset pool if the preset name contained lower case characters.
  • Adding parameter locks to all active trigs on a MIDI track did not work.
  • The SLEW parameter was missing in the modulation destination list.
  • SONG mode mutes were not swapped when performing a track swap.
  • The parameters on the SRC page were missing on the device after selecting a MIDI machine using Overbridge.
  • Removing send effects from main outputs, also removed them from their individual outputs.
  • Removing parameter locks on active MIDI trigs while holding [TRK] did not work.
ob man da ne neue Sample Engine erwarten kann?
ich glaube irgendwie nicht. sowas wie modernes timestretching wird zuviel CPU power brauchen. Vor allem erwarten die Leute ja das das dann bitte auch auf allen 16 Stereospuren geht ;-)
ein Soundeditor mit dem man später noch vernündftig reinzoomen kann und samples bearbeiten , wäre aber was.
Jetzt bin ich auch Besitzer eine Digitakt 2, lange habe ich gewartet…
Und gleich eine Frage: Wackeln die Potis bei eurem DT2 auch so?
Insbesondere das Volume und Data Poti haben so viel Spiel, dass ich das eig einem Gerät dieser Preisklasse nicht durchgehen lassen möchte.
Wir wissen ja nicht wie deine wackeln.
Die haben etwas mehr Spiel.
Das kannst du nur dir selbst beantworten.
Mein persönlicher Rat wäre:
Unter der Annahem das du kein fehlerhaftes Gerät hast: in der Regel sind elektron Geräte gut und stabil verarbeitet. Benutz ihn doch ne Weile und guck mal ob es dich stört. Mir ist das wackeln erst aufgefallen als mich mal jemand danach gefragt hat. Beim normalen benutzen spielt es keine Rolle - beim DT1 waren die nach zig Jahren immer noch stabil und zuverlässig.
Das ist wohl wahr.
Sagen wir mal so, die Dinger haben so viel Spiel, dass es mir gleich aufgefallen ist.
Das ist schon mal ein guter Hinweis, vielen Dank!
die Leute sind so unterschiedlich was das angeht. Wie gesagt, ja die Teile haben etwas mehr Spiel aber das sie jemandem abgebrochen, gefallen oder nach kurzer Zeit ausgenudelt wären hab ich zumindest noch nie gehört.
