C
changeling
Intellijel macht grad mächtig Dampf. Hier der nächste Streich:
Bin mal auf die Preise gespannt. Dat Mutagen is für mich aber schonmal ein must-have.
intellijel schrieb:Mutagen: 12HP
6x3 performance mixer
- 6 direct coupled inputs suitable for audio or CV
-each channel has a slide switch to select one of three output busses A/B/C
-each channel has a logic controlled mute. Mute generated by tactile switch or pulse/gate to the CTL inputs (pulse mode or gate mode selected by jumpers on back).
-leds show mute status
-Mute/Gate inputs accept any signal with a rising edge (could be sine, triangle, random etc.)
-Has link via ribbon cable to HexVCA
NOTE: panel displayed is a sample. They are revising them with smaller square punch outs for the switches so that they will be more flush.
HexVCA: 8HP
-6 channel VCA using high quality THATcorp VCA ICs.
-CV of each channel has led monitor
-outputs normalled to a summed output, normals broken when taken as individual outs.
-Also has inverse sum output useful for CV
-Has matching link header as found on the Mutagen for linking the two modules together. Link connects the outputs of each vca to the input normals of the mixer.
-Leds color coordinated to help keep track of channels bewteen the two.
Azimuth: 8hp
-Constant power panner/stereo ballance/crossfader and dual vca
-contains an additional vactrol based stereo width circuit (allows cv control of stereo material in the range of mono->stereo->extra wide via negative cross bleed.
-Bipolar and Unipolar CV inputs for the pan control
-Leds have smooth fading for displaying pan position.
Combine all three to get a VC mixer with VC stereo controls, volume and muting.
NOTE: these three modules will go into production in approximately one week but will not be ready in time for x-mas. Should ship first week of January.
