Hier sind die Spezifikationen. Man beachte die LA-Wellenformen:
■ Keyboard 61 keys (with velocity and channel aftertouch), Dual Elastic Audio Synthesis Core withAP-Synthesis and Vocal Designer ■ Sound Generator Configuration Oscillator (envelope x 4 + LFO x 1), Modulator x 1 per Tone, COSM (envelope x 2 + LFO x 1) x 2, TVA (envelope x 1 + LFO x 1) x 1, Tone FX x 1, AP-SYNTHESIS (Articulative Phrase Synthesis) x 1*, Vocal Designer x 1*, *Shared by both Upper and Lower Tone ■ Methods by Which Oscillators Produce Sound PCM/Variphrase (Preset waveforms +
Sampling waveforms), Analog Modeling (14 waves: SAW, SQUARE, TRIANGLE, SINE, RAMP, JUNO, HQSAW, HQ-SQUARE, NOISE, LA-SAW, LA-SQUARE, SUPER-SAW, FEEDBACK-OSC, X-MOD-OSC),
External Input ■ Modulator 4 Modulation types (RING, FM, ENV-RING, OSC-SYNC), MIX and STEREO-MIX ■ COSM 16 types (OD/DS, W-SHAPE, AMP, SPEAKER, RESONATOR, SBF1, SBF2, COMB, DUAL, TVF,
DYN-TVF, COMP, LIMITER, F-SHIFT, LO-FI, TB-FILTER) ■ Zones (Splits for Rhythm/Filter Bank) 16 Zones per Tone ■ Maximum Polyphony TBA (Varies depending on the load placed on the sound generator.)
■ Internal Memory Project: 1, Patches: 256, Tones: 512, Waves: TBA, Wave memory (RAM): TBA (64 Mbytes) ■ External Storage Device USB Flash Memory ■ Effects Tone FX: 2 (41 types Multi-effects), Chorus: 1 (8 types)*, Reverb: 1 (10 types)*, *Shared in the both of Upper and Lower Tone ■ System EQ 4 bands ■ Sampling Frequency Internal: 44.1 kHz, Digital Audio IN/OUT: 96, 48, 44.1 kHz ■ Signal Processing Internal Processing <Sound generating section: 32 bits (floating point) <Effects section> 24 bits (fixed point) <DA Conversion> 24 bits <AD Conversion> 24 bits ■ Nominal Output Level MAIN OUT: +4 dBu, DIRECT OUT: +4 dBu ■ Nominal Input Level INPUT (LINE): -20 dBu, INPUT (MIC): -46 dBu ■ Arpeggiator * Patterns: User programmable (support use of control change messages), Motifs: 8 types, Tempo: 20 to 250 BPM *Shared in the both of Upper and Lower Tone ■ Multi Step Modulator Tracks: 4, Steps: 16, Tempo: 20 to 250 BPM ■ Display Graphic 320 x 240 dot backlit TFT LCD with touch screen ■ Controllers Pitch Bend / Modulation Lever, Time Trip Pad, D Beam Controller (Twin beam), Assignable Control Knobs (C1, C2)
■ Connectors Headphones Jack, Main Output Jacks (L/MONO, R) (1/4 inch phone type), Direct Output Jacks (L, R) (1/4 inch phone type), Input Jacks (L, R) (1/4 inch phone type), Hold Pedal Jack, Control Pedal Jacks (1, 2) (assignable), MIDI Connectors (IN, OUT, THRU), USB Function Connector (supports USB 2.0 file transfer, USB 1.1 USB-MIDI and Audio Streaming), USB Host Connector (supports USB 2.0 Flash Memory), Digital Audio Interface (24-bit, IEC60958): COAXIAL (IN, OUT), OPTICAL (IN, OUT), AC Inlet ■ Power Supply AC 115 V, AC 117 V, AC 220 V, AC 230 V, AC 240 V (50/60 Hz) ■ Power Consumption TBA ■ Dimensions 1066 (W) x 411 (D) x 125 (H) mm/ 42 (W) x 16-3/16 (D) x 4-15/16 (H) inches ■ Weight 14.1 kg / 31 lbs 2 oz ■ Accessories Owner's Manual, CD-ROM (USB Driver for Windows/MacOS), USB Memory Protector, Power Cord ■ Options Keyboard Stand: KS-12, Pedal Switch: DP, Foot Switch: BOSS FS-5U, Expression Pedal: EV-5, BOSS FV-300L * 0 dBu= 0.775 Vrms * The specifications are subject to change without notice.
