E
e6o5
Ich habe nichts dazu gefunden. Gibt es die Moeglichkeit SysEx-Strings in Reaktor zu "verschicken"?
If you're on pc you might be able to hack something together using MidiOx filtering, but I doubt it. Likely this would require a dedicated program to sit on the midi port and translate sysex into cc. The problem is sysex is a very different sort of message than the cc, since it is not fixed length. Bizarre that faders would be outputting sysex--are there no config options on the hardware?
