PHENOL - Patchable Analog Synthesizer
Re: PHENOL - Kompatiblität Eurorack?
Mick von Tiefengrund schrieb:
Frage an die Elektronik-Freaks;
Der Phenol hat ja einpolige Bananenstecker, bekomme ich da Probleme, wenn ich Spannungen mit meinem Eurorack "austauschen" möchte?
Gibt es da Adapter, die die Masse beider Systeme verbindet? Ich denke ja, dass beim Eurorack beide Pole galvanisch getrennt sind von den Frontplatten und Metallteilen des Gehäuses.
Oder habe ich da was grundsätzlich falsch verstanden?
kurz gesagt: das geht!
von den faqs der website (auszug):
"Voltage Compatibility with Other Systems
Many people have asked about the compatibility between Phenol and other modular formats. As was stated above, Phenol uses the same voltage standards as the Kilpatrick Format modular system which will hopefully be adapted as an industry format within the coming years. It solves a number of existing problems with most modular systems both electrically and mechanically.
All CV and audio signals range from -5V to +5V. Pitch uses the industry standard 1V/octave.
Pulse and gate signals use 0V = off, and +5V = on. This is pretty much the standard on most systems. Phenol pulse/gate inputs will activate with voltages above about 1V.
Conversion to/from other cable types such as minijack (1/8" or 3.5mm) or 1/4" can be easily accomplished by making a small breakout box or just making cables that have a banana plug on one end and the other type of plug on the other end. The only important concern is that you must connect the ground of your other system to the front panel ground connection on Phenol before patching. You can use a minijack / banana cable plugged into an unused jack on your other system to ensure the ground is connected all the time. Phenol provides a dedicated ground jack for this purpose."
Dank Dir Danielxiang,
Da steht dem Erwerb dieses "Habenwill-Modular-System" nur noch eine schmerzhafte Investition im Wege.
Da ich solche Kichstarter Aktionen gerne unterstütze,
habe ich gleich bei den ersten 20 Early Bird Einheiten zugeschlagen.
Die Katze im Sack also...
Wenn er mir doch nicht schmecken sollte,
werde ich ihn nächsten Sommer hier anbieten ;-)
Hat jemand eine Empfehlung für Kabel/Adapter
um den Phenol mit dem Eurorack zu verbinden ?
Das wird sich legal wohl kaum vermeiden lassen.
Weiß aber auch nicht wie ihr auf EUR 540,-- kommt. Das wird mehr werden und dann halt plus ca. 22%. :sad:
seh ich auch so. Werde warten, bis die Schneiders den im Laden haben. Preis schätze ich auf 899 € :floet:
...will den Phenol als Ergänzung zum Easel (schaun wir mal ob das geht. Okt/ Volt - mäßig.....)
Seid gesegnet liebe Sequencer.de-Gemeinde :amen:
naja, die knapp 800 kanadischen dollar als Backer sind laut währungsrechner eben diese rund 540 euro, etwaige steuern hab ich da nicht berücksichtigt
..leider keine neue sound-demo...das nächste update kommt wohl erst wenn die katze im sack ist (ist sie ja eh schon eine weile)
passend zum erfolgreichen ende der kickstarter-kampagne schreibt der kölner stadtanzeiger:
"Eilmeldung: Gestank nach faulen Eiern über dem Kölner Stadtgebiet
Über dem Kölner Stadtgebiet riecht es nach faulen Eiern. Es handelt sich nach Angaben der Feuerwehr um Phenol. Ursache ist eine technische Störung auf dem Godorfer Werksgelände der Rheinland Raffinerie. Die Feuerwehr ist vor Ort. Gefahr für die Bevölkerung besteht derzeit nicht."
:selfhammer:
ahja, mal eine frage an wissende: wenn ich z.b. beim osc das rechteck verkabel, ist das osc signal dann quasi "weg", oder kann ich zusätzlich auch noch die triangle verkabeln?
:selfhammer:
:D :D :D
vermute mal das du die triangle trotzdem dann noch nehmen kannst. hatte bisher zumindest keinen vco bei dem es anders gewesen ist.
ich glaub nicht, das es gut funktioniert, denn der Easel hat ja keinen 1Volt/Oct. Standard.
Einbinden / kombinieren kann man natürlich das schon, nur mit dem tonal spielen, also mit Sequenzer etc., wird das nix.
Braucht man sowas :)
http://www.schneidersladen.de/de/synovatron-cvgt1.html
ein neues update mit der fertigen rev. B wurde veröffentlicht samt (kurzem) video :)
text:
Hi folks! While the campaign was coming to a close last week I was feverishly soldering the new version of PHENOL. After much code hacking and testing I am pleased to show you the finished product! This is probably 99% the same as the what will be rolling off the assembly line shortly. We are in the process of negotiating with manufacturers and parts suppliers.
See us at NAMM!
We are normally enjoying our warm socks and hot chocolate in Toronto during January, but this year we thought we'd take a break from the cold and visit Anaheim for NAMM 2015. The fine folks at Muffwiggler have graciously offered to have us join them in their booth #1371 in Hall E. We will be bringing PHENOL to show to synth fans, so if you are attending please come and check it out yourself. Oh, and don't worry... you will absolutely get PHENOL before retailers... we respect and appreciate all of you for helping make this project a reality.
And finally... a short video that shows what the finished synth will look like, complete with the new features that we have discussed before. :)
Das hört sich wirklich gut an..bin gespannt auf das Teil. Nur beim Layout hätte er etwas mehr Platz zwischen Beschriftung und Steckfeld lassen können *Nörgel* :opa:
Auf jedenfall ein Hammer Preis-Leistungsverhältnis..und das bei einem Boutique-Synth..irgendwas stimmt da doch nicht! :selfhammer:
Hallschlag schrieb:
den Phenol hol ich mir, sobald er bei Schneiders landet. Oder sind die da schon eingetroffen? Ne Vorbestellung hab ich da am laufen...
Ja? Hab ich da irgendwo was verpasst? Ist es wirklich so, dass Schneiders den Phenol verkauft?
Über ein paar Infos würd ich mich freuen.
Danke.
Best
Argument
..Schneider hat auf jedenfall die Kilpatrik Module im Sortiment – ich denke schon dass sie dann auch den Phenol im Programm haben werden.
Aber vor Juli wird das eh nichts..
Hi Argument,
vom Phenol (wird offensichtlich noch einige Zeit brauchen) bin ich dann auf den MacBeth 'Elements' 'umgestiegen'...
Mit der Auslieferung wird es doch wohl Ende März werden...
LG
Hans
Besten Dank für die schönen PhenolBeispiele :supi:
..ich muss dennoch mit ner Bestellung warten, da ich inzwischen nen MacBeth Elements und nen Hornet von PIN Electronics bestellt habe.
Also ein finanzielles Problem. Zudem ist meine Hütte auch schon (über-) voll mit Maschinen.
Schaunwermal... ;-)
Das is ja sehr nett von dir Peter, aber noch sind keine Auslieferungs Termine bekannt.
Du kommst dann einfach mal vorbei für nen gemütlichen Nachmittag/Abend mit den neuen Schätzchen :lol:
Platz für die zwei Neuen hab ich noch, da ich im Wohnzimmer mein 2.Studio momentan baue. Hat dafür keinen Wohnzimmer Charakter mehr...aber man kann ja nicht alles haben :mrgreen:
Cu beim Stammtisch ;-)
