Hab mich mit BM2 nicht mehr befasst, aber vielleicht interessiert es den einen oder anderen, dass es ein Update auf 2.3 gibt.
MIDI Clock Input ist natürlich ne feine Sache, ebenso wie Audio Tracks.
New features
►Audio tracks with disk streaming support
►Support for USB class audio interfaces on iPad via Camera Connection Kit
►Record up to 8 audio tracks simultaneously (current iOS limitation)
►Gain and noise gate on audio inputs
►Sample drag'n'drop on drum machine via "Quick Load" feature
►Event recording is now allowed anywhere in the app
►Patterns can be dragged directly on the song editor
►Sample streaming in drum and keyboard samplers (samples are not loaded in RAM)
►Automatic audition of samples in browser
►New auto-loop mode for pads (quantized)
►Revamped iPod Library import
►Sustain pedal is now supported in the keyboard sampler and is editable in the pattern editor
►Keyboard sampler now supports layers
►Revamped sampler mapping editor
►Retina graphic content for the 3rd generation iPad
►Receive MIDI clock messages for tempo synchronization
►App Settings: Added OMNI and input clock
►More automatizable parameters: Auto-pan sync and sync toggle / Effects bypass / LFO sync rate / Invert ADSR / Tune, Fine-Tune / Filter key / Pads reverse and mute / Mixer track mute and solo / Sustain pedal
Improvements and bug fixes
►Fix crash when resetting auto-scale on an empty pads
►Fix noise when looping very small samples
►Fix issue with installing BeatMaker 1 'bmkz' files
►Fix sampling rate issue with some accessories (ie. Apple Digital AV Adapter)
►Fix behavior of MIDI virtual input ports
►Install BMKZ kits when using Dropbox
►Other minor fixes and engine improvements
►Update to Dropbox SDK v1.2.2
►Improve preset/projects file format (quicker load/save)
http://www.intua.net/forums/viewtopic.php?f=5&t=2901
