Olydian Photosynthesis
mioo
Olydian Photosynthesis: ein solarbetriebener generativer Wavetable Synthesizer
https://www.gearnews.de/olydian-photosynthesis-wavetable-synthesizer-solar/#
https://www.olydianmusic.com/
The Photosynthesis is a portable, solar-powered, generative MIDI synthesizer and drum machine. It has a unique tonal touch keyboard, which can be selected to play in any key and 16 different musical scales. It features a powerful arpeggiator and sequencer, which can be controlled very precisely, or let loose to create new and unexpected results.
The built-in sounds are made with beautiful, nostalgic, wavetable synthesis. There is MIDI out, so you can control other instruments with this one. There are also built-in effects.
The case is made from a hardwood: North American Cherry. The solar charging top piece of the case comes standard and protects the instrument from damage while on the move.
Features:
  • Wavetable Synthesizer with 128 tones
  • Drum Machine
  • Capacitive-touch Keyboard
  • Scale and Key locking
  • Arpeggiator
  • 32 Step Sequencer
  • Eraser function for adding rests
  • 3 built-in effects: Reverb, Delay, and Chorus
  • BPM and Swing controls
  • Harmony generation for counterpoint and melodic movement
  • 3.5 mm Headphone Out
  • MIDI Out
  • 10 hour battery
  • Solar charging
  • Charging via 5v USB C or 2.1 mm barrel jack
  • Cherry Hardwood Case
