Native Instruments Massive X | Seite 9 | Synthesizer @ Sequencer-Forum
Mein alter Intel 980XE 6-Core von 2011 hat das scheinbar noch nicht.
Edit: Sorry, falscher Prozessortyp, du meinstest sicher den i7-980XE von 2010
Der sollte aber schon AVX haben (Intel® SSE4.1, Intel® SSE4.2, Intel® AVX2, Intel® AVX-512), vielleicht stimmt was mit dem Installationspfad nicht.
Massive X v1.3
Firstly, crashing issues related to the new LOGIC PRO X 10.5 update are now fixed, so you’ll be good to go again.
As far as the fun stuff is concerned, you’re in for a real treat: The new update includes 20 new presets, and 50 new noise tables (25 loops, and 25 one-shots). You can also import your own samples into the noise module – time to put your field recording collection to good use!
We’ve also added parameter readouts and, as usual, have swatted a few bugs.
Changelog:
  • Added: Parameter Readouts: Values are now shown below/above the parameters, including macro parameters.
  • Added: Custom Noise Samples: External samples in various file formats and sample rates can now be loaded into the Noise section.
  • Added: Embedded Noise Samples: Custom noise sample/-s that are saved with the preset are embedded into the preset file.
  • Added: Noise One Shot mode: In one shot mode noise samples are only played once. One shot mode can be accessed through the Voice section in the Noise generator drop-down menu.
  • Added: Noise Keytracking mode: Added: an option to the Noise section to enable keytracking for sample playback.
  • Added: 50 new Noise Samples (25 Loops and 25 One Shots).
  • Fixed: Massive X crashed on instantiating in Logic Pro X 10.5.
  • Fixed: Some 3rd party Massive Presets were instantiating Massive X.
  • Fixed: Massive X was indicating some presets as modified (with asterisk) when no changes were made.
  • Fixed: Colors of Noise & Wavetables headers in the menus in Dark Mode.
  • Known issue: FL Studio 20.5 VST: when loading a preset the interface will shrink. Fix: update to FL Studio 20.6 or higher.
  • Known issue: Cubase and Studio One: text input does not work correctly when Massive X is hosted in Komplete Kontrol or Maschine KPI view.
  • Known issue: When dropping a preset on to the Massive X GUI, the preset will load in all instances of the plugin.
Seit dem Update auf 1.3.0 habe ich ein Problem mit den Wavetables...
So müsste es aussehen:
Doch so sieht es aus - leer:
Und wenn ich in die leere Fläche klicke, bekomme ich eine leere Auswahl:
Watt nu? "Rescan Content" hat nichts gefruchtet...
PS: das gilt nur auf meinem PC, nicht auf dem Laptop, da ist die Installation OK.
Vielleicht stimmen die Pfade nicht, teste das gerade hier und beim ersten Start nach dem Update (erst gestern runtergeladen) ist er was am Wave-Files und NKFS durchrödeln. Edit: Wird hier aber alles richtig angezeigt.
Update:
Das Problem ist bei NI bekannt:
Allerdings hat keiner der oben vorgeschlagenen Lösungsansätze funktioniert. Ich habe über Native Access einen Reinstall gemacht, ohne Erfolg, ebenso deinstallieren über die Systemsteuerung und erneute Installation über Native Access. Das Rumfummeln in der Registry hilft nicht und das Kopieren der Ordner in der User-Content-Bereich auch nicht.
Ich werde mir in absehbarer Zeit eh einen neuen PC zulegen, dann wird alles frisch installiert und dann sehe ich weiter. Solange kann ich neue Sounds auch auf dem Laptop bauen und gut is. Letztes mal war das Problem irgendwann weg (da wurden Patches nicht gefunden), vielleicht durch ein neues Update, ich weiß es nicht mehr, vielleicht passiert hier also auch noch ein unerwartetes Wunder.
Schön ist das trotzdem nicht und ich frage mich, warum man das nicht einfach fixen kann. Das erinnert mich an das MIDI-Timing-Problem bei MASCHINE, da gibt es einen hilfreichen Registry-Hack, aber auch keine grundsätzliche Lösung in der Software selber.
Das scheint aber doch ein recht alter Fehler zu sein, die Versionsnummer stimmt aber? Zumindest früher hatte man bei den N.I. Sachen immer mal das Problem, dass das Plugin nicht ersetzt wurde, man ein altes Plugin mit neuen Daten hatte.
Na ja, er zeigt ja 1.3.0 an. Dann wird es wohl stimmen...
Edit: Screenshot angehängt:
Habe mal wieder etwas mit Massive X gemacht. Ist schon sehr vielseitig und die Möglichkeit Samples zu verwenden (bei Bedarf mit Keytracking) ist schon fein. Ein no go ist für mich allerdings die eingeschränkte Möglichkeit per MW zu modulieren. Das geht ja in weiten Bereichen nur für ein Ziel. Bin jetzt schon dabei mir das Pitchbend als zweite Quelle anzulegen (nachdem man die normale Funktion auf 0 gesetzt hat) aber schön finde ich das nicht. Ausgefuchste Nutzer von Softies haben da sicher ihre Tastatur mit zig Slidern.... aber das ist mir dann zu aufwendig und muss ja auch erst mal angelegt werden. Zudem wechseln meine Einspielgeräte...
Schade - bei anderen geht´s ja auch mit diversen Mod-Zielen gleichzeitig per MW.
Den fehlenden (?) Wavetable-Import finde ich nicht so schlimm - kann man doch mit dem vorhandenen Material und den Mod-Möglichkeiten schon sehr viel anstellen.
Nein, das ist nicht eingeschränkt. Jede mod Quelle und jedes Macro lässt sich mehreren Zielen zuweisen, wenn man die kleinen Kästchen unter den Reglern, statt den Regler selbst, als Ziel bestimmt. Und dann die Offsets einstellt.
Eine Direktzuweisung auf den Regler selbst hat keinen Offset und geht immer nur auf ein einziges Ziel.
Ich habe tatsächlich jetzt erst, nach lesen der Anleitung herausgefunden, dass man per mouse-drag Zähler und Teiler einstellen kann. :oops: :lol:
Muss da definitiv mehr mit machen, so geht dass nicht.... :harhar:
@Tom Noise Kannst/darfst du sagen, von was dass Asimov Filter inspiriert ist? TB-303? Ist mein Lieblingsfilter in Massive X und auch nicht nur für monophone Sounds. Daher würde mich das schon mal interessieren. ;-)
Aus der Anleitung:
"This low-pass filter is based on the paradigm of the filter found in a classic bass synthesizer from the 80s, despite not being a direct clone. Its defining characteristic is the lack of self-oscillation, providing a huge sweet-spot for resonant filter sounds."
Ja, soweit ich weiß ist der Asimov-Filter von dem 303 Filter inspiriert/modelliert.
Wusste ich anfangs auch nicht, bis ich dann mal in einem Forum "belehrt" wurde.
Gute Sache.
Die Unterscheidung in 3 verschiedene Versionen kann ich allerdings nicht nachvollziehen, insbesondere weil sich die Bundles dann auch noch in den Effekten unterscheiden... Replika XT ist z.B. mein go-to Delay, und, das ist nur bei einem Bundle dabei. Schade.
Replika (nicht-XT) ist doch beim kostenlosen Komplete dabei, warum nicht gleich in Select auch noch reinpacken?
Was viele nicht wissen, ich bin ja von Beruf Sounddesigner und jetzt möchte ich gerne ein Pack für Massive X rausbringen. Dieses soll ein spezielles Feature enthalten. Die Presets sollen sich natürlich anhören, auch wenn sie 100% quantisiert mit dem Sequencer eingegeben wurden. Dafür habe ich ein Macro gemacht, dass ich in diesem Beispiel Preset SeqMod genannt habe. Damit kann man quasi z.B. ein Piano relativ natürlich programmieren ohne viel im Sequencer zu fummeln. Glaubt ihr, dass sowas bei manchen Leuten auf Interesse stößt?
Hier der Patch zum ausprobieren:
Es gibt ein neues Update:
1.5.0 - 2025-03-27
ADDED
New Multi Compressor effect in the Stereo Effects section for multi band upward and downward compression
ADDED 60 new presets (please update the Massive X Factory Library via Native Access)
FIXED Browser view scrolling to incorrect column or scrolling back and forth
FIXED Rare crash with Logic Pro on Intel Mac when recalling projects with certain presets loaded
FIXED Multiple sound type selections disappear when selecting preset in browser
FIXED UI controls sometimes not reacting to user input after host automation assigned to a Macro on Intel Macs
Ich habe mich gerade mal wieder an das Teil rangesetzt. Ich bin immer wieder erstaunt, was man da alles mit machen kann.
Hätte ich doch bloß mehr Zeit!
