midi-musiker.de presentiert Monochrome SL1 by Nox
Ein Sampleplayer der etwas anderen Art
Monochrome SL1 is a simple and easy to use 1-slot stereo sample player built with Outsim SynthMaker.
You can set the start and end points, reverse the sequence, change the sequence speed, adjust the pitch and add effects.
Or just loop a sequence, it's up to you...
Monochrome works well for D'n'B and Dub loops et cetera... or just for random glitchy percussion and total chaos. Zwinkernd
It's all about experimentation.
Chief effect is definetly the Tap Delay with a 16-Step Draw Scope.
State Variable Filter and Overdrive are separately switchable. (Be careful, those can hurt.)
Um das Plugin runterzuladen, muss man sich registrieren, ist aber 100% kostenlos
http://midi-musiker.audiopalace.de/inde ... pic=2706.0
