danke für deine Mühe, hier ist der output
patch@patchbox:~ $ edid-decode tv.edid
edid-decode (hex):
00 ff ff ff ff ff ff 00 4d 10 48 10 00 00 00 00
ff 14 01 03 80 52 2e 78 2a 1b be a2 55 34 b3 26
14 4a 52 af ce 00 a9 40 90 40 81 80 01 01 01 01
01 01 01 01 01 01 02 3a 80 d0 72 38 2d 40 10 2c
45 80 34 cc 31 00 00 1e 66 21 50 b0 51 00 1b 30
40 70 36 00 00 00 00 00 00 1e 00 00 00 fc 00 53
48 41 52 50 20 48 44 4d 49 0a 20 20 00 00 00 fd
00 17 4c 0f 4b 11 00 0a 20 20 20 20 20 20 01 14
02 03 2e 72 50 9f 90 20 14 05 13 04 12 03 11 02
16 07 15 06 01 23 09 07 07 83 01 00 00 e3 05 03
01 6c 03 0c 00 30 00 b8 2d c0 3d 3d 5b 5b 02 3a
80 18 71 38 2d 40 58 2c 45 00 34 cc 31 00 00 1e
01 1d 80 d0 72 1c 16 20 10 2c 25 80 34 cc 31 00
00 9e 01 1d 80 18 71 1c 16 20 58 2c 25 00 34 cc
31 00 00 9e 01 1d 00 bc 52 d0 1e 20 b8 28 55 40
34 cc 31 00 00 1e 00 00 00 00 00 00 00 00 00 2e
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: SHP
Model: 4168
Model year: 2010
Basic Display Parameters & Features:
Digital display
Maximum image size: 82 cm x 46 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6328, 0.3330
Green: 0.2050, 0.7021
Blue : 0.1503, 0.0810
White: 0.2919, 0.3222
Established Timings I & II:
IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz
DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz
DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz
DMT 0x08: 800x600 56.250 Hz 4:3 35.156 kHz 36.000 MHz
DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz
DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz
DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz
DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz
DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz
DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz
Standard Timings:
DMT 0x33: 1600x1200 60.000 Hz 4:3 75.000 kHz 162.000 MHz
DMT 0x2a: 1400x1050 59.978 Hz 4:3 65.317 kHz 121.750 MHz
DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz
Detailed Timing Descriptors:
DTD 1: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz (820 mm x 460 mm)
Hfront 528 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
DTD 2: 1360x768 60.015 Hz 85:48 47.712 kHz 85.500 MHz
Hfront 64 Hsync 112 Hback 256 Hpol P
Vfront 3 Vsync 6 Vback 18 Vpol P
Display Product Name: 'SHARP HDMI'
Display Range Limits:
Monitor ranges (GTF): 23-76 Hz V, 15-75 kHz H, max dotclock 170 MHz
Extension blocks: 1
Checksum: 0x14
Block 1, CTA-861 Extension Block:
Revision: 3
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 2
Video Data Block:
VIC 31: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz (native)
VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (native)
VIC 32: 1920x1080 24.000 Hz 16:9 27.000 kHz 74.250 MHz
VIC 20: 1920x1080i 50.000 Hz 16:9 28.125 kHz 74.250 MHz
VIC 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz
VIC 19: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz
VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz
VIC 18: 720x576 50.000 Hz 16:9 31.250 kHz 27.000 MHz
VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz
VIC 17: 720x576 50.000 Hz 4:3 31.250 kHz 27.000 MHz
VIC 2: 720x480 59.940 Hz 4:3 31.469 kHz 27.000 MHz
VIC 22: 1440x576i 50.000 Hz 16:9 15.625 kHz 27.000 MHz
VIC 7: 1440x480i 59.940 Hz 16:9 15.734 kHz 27.000 MHz
VIC 21: 1440x576i 50.000 Hz 4:3 15.625 kHz 27.000 MHz
VIC 6: 1440x480i 59.940 Hz 4:3 15.734 kHz 27.000 MHz
VIC 1: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Colorimetry Data Block:
xvYCC601
xvYCC709
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 3.0.0.0
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 225 MHz
Video latency: 123 ms
Audio latency: 123 ms
Interlaced video latency: 183 ms
Interlaced audio latency: 183 ms
DTD 3: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (820 mm x 460 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
DTD 4: 1920x1080i 50.000 Hz 16:9 28.125 kHz 74.250 MHz (820 mm x 460 mm)
Vfront 2 Vsync 5 Vback 15 Vpol P Vfront +0.5 Odd Field
Vfront 2 Vsync 5 Vback 15 Vpol P Vback +0.5 Even Field
DTD 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz (820 mm x 460 mm)
DTD 6: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz (820 mm x 460 mm)
Hfront 440 Hsync 40 Hback 220 Hpol P
Vfront 5 Vsync 5 Vback 20 Vpol P
Checksum: 0x2e
patch@patchbox:~ $
