ESQ1 Hardware Controller !
http://home.netspeed.com.au/aistorm/Images/e[/b]
[img]http://home.netspeed.com.au/aistorm/Images/esqm1a.jpg
ESQm Controller
Providing complete realtime and hands on control of all the parameters of Ensoniq's ESQ-1 and ESQm synths this controller provides the complete synthesis experience. Bringing the control and user interface of a monster analog synth to the ESQ synths with their modern synth features like memory, polyphony, and stable tuning delivers a throughly powerful and useable synth.
For those of you not familliar with the ESQ synths they are an analog synth with digital sampled oscillators, there are:
* 3x Oscillators per voice, 32 waveforms, sync and ampltude modulation between oscillators 1 and 2
* 4x Envelope generators per voice, 5 point with velocity sensitivity and keyboard scaling
* 3x LFO's per voice, each with integral ramp generators and 4 waveforms
* 1x 24dB/octave analog low pass filter per voice with resonance
The analog signal path is fixed but all the control signals (CV's) are free to be patched between the components which is where the patch bay comes in.
The controllers complete 60 point patch bay allows intuitive control over the routing in real time just like any patchable analog synth. Quickly connect any input to any output, modulate the oscillators by an LFO modulated with an envelope, patch inputs together and run them from a single output, setup a crossfade between all 3 oscillators, anything becomes possible and its all done physically without any menus or computer editors. Then hit save and everything is stored just like any other synth, next time you call up the voice the entire patch is recreated without the need to put all the cables back in. Its also possible edit the routings in a saved voice by simply patching over the parts you want to change, again without the need to rebuild the whole patch.
No longer is real patching limited to the domain of analog modulars.
http://home.netspeed.com.au/aistorm/esqm.html
Ist das krank :shock:
Selbst wenn das ganze nur eine Idee bleibt find ich es aber cool 8)
Die Jungs müssen ihren ESQ echt lieben.
sehr fein, aber letzlich kann man das mit jedem Synthesizer
sehr fein, aber letzlich kann man das mit jedem Synthesizer machen, vielleicht kommt ja mal ein Hersteller auf die Idee, SysEx in Controllerboxen zu haben..
Dann könnte man das quasi generell machen.. nur oft nicht so flüssig wie mit CCs heute..
der SPASS bei so einem Controller und die Intuition dürfte jedoch maximal sein.
[quote:8f4f780c78=*Moogulator*]sehr fein, aber letzlich kann
Aehm... Das Doepfer Regelwerk kann beliebige SysEx-Strings (bis 30 Byte oder so) senden.
oha, ich h
oha, ich hätte sagen müssen: wenige können das.. das Peavey ding kanns auch..
müsste halt nur flexibler und üblicher werden.. in der tat kann man mit dem http://www.sequencer.de/syns/doepfer Döpfer sowas machen ,solang es auch die verschiedenen formate senden kann.. kann es?
time to read the fuckin manual ,odeR? ;)
vor allem: wer hat lust, so einen midi controller auf die ga
vor allem: wer hat lust, so einen midi controller auf die ganzen sysex strings einzustellen?
ein fertiger, beschrifteter controller hat schon seine vorteile...
korrekt, also sowas w
korrekt, also sowas wäre schon gut..
obwohl ich persönlich nur 2 maschinen habe, oder 3 bei denen sowas sich lohnen würde..
tendenz fallend.
