AVP Synth MBS-100 Analog/Digital Synth
Hi-Tech Music
Na was haltet ihr von dem kleinen??
MBS-100 - a monophonic bass synthesizer inspired by synthesizers produced in the soviet era times while having the flexibility, MIDI control and compact steel package of the 21st century. It has 19 knobs, 3 switches and 4 buttons with which you can control the parameters of the sound and MIDI.
Details:
 Method of synthesis – hybrid analog-digital synthesis;
 Voltage-controlled digital oscillators (VCDO) - two, each with four waveforms: saw, square, pulse 1 (25% rate), pulse 2 (10% rate).
Note: Pulse 1 and 2 are similar to PMW but are fixed similar to «Aelita», «Polivoks» synthesizers for e.g.
Octave ranges - 3 octaves for OSC1 and 5 octaves for OSC2.
 Voltage Controlled Filter (VCF) - one fully analog 12 db/oct low pass filter with cutoff and resonance parameters;
 Envelope Generators (ADSR) – two;
 Voltage Controlled Amplifier (VCA) – one, fully analog distortion effect selection switch;
 Low frequency oscillator (LFO) - one with two waveform options (square and triangle) to control the VCF.
 MIDI interface - MIDI In, MIDI Thru (16 channels + Omni);
 Audio output - one mix output (mono 6.3 mm jack);
 Controls - 19 knobs, 3 switches, 4 buttons and 11 LED indicators;
 Case: durable steel case with wooden sides;
 Weight: 1 kg;
 Dimensions: L30 x W16 x H8 (cm);
 External power supply – 220v adapter 9 VAC (included).
You can read the full manual here:
https://drive.google.com/open…
Video with direct audio will follow soon !
Price: 449 EURO (or its USD equivalent)
Trackable shipping to Europe/UK, USA/Canada is included.
For other locations, please contact us for a quote!
For all the inquiries please email us:
avpsynths@gmail.com
Best regards,
AVP Synth
Spannungsgesteuerte Digital-Oszillatoren...? :hae:
...liegt hier ein Übersetzungsfehler vor? --> DCO?
Naja...
Die digitalen Spektren sind durchaus cool... aber schlussendlich bleibt es eben ein weiterer Mono-Synth... Ohne zweiten LFO, ohne Presets und ohne internes Netzteil.
Wo bitte sind da "digitalen Spektren"? Die Waveforms sind klassisch analog, gemäss Handbuch genau 4 (saw, square, pulse 1 and pulse 2). Das reicht nicht zum Hybrid-Synth. Ist einfach irgendwas in Richtung Poly 800, Crumar Bit Serie, Synthex oder Rocket.
...und trotzdem spricht man von hybrid analog-digital synthesis.
Es werden ja Wavetables im Spiel sein, wenn herstellerseitig von "VDCO" (schwammiger Begriff) die Rede ist.
