T
TMM
Hi,
I contact You for your experience on the vintage analog synthesizers.
I'm having problem with MKS-80, its controller MPG-80, the Edirol UM-880 midi interface and Cubase SX 3.1
This is my actual midi cable configuration:
UM-880 MIDI out---->MPG-80 MIDI in
MPG-80 programmer out----> MKS-80 programmer in
MKS-80 MIDI out----> UM-880 MIDI in
(Is this configuration correct?)
PROBLEMS:
1) ON CUBASE If I try to use for midi in the "all midi inputs" option or the "MKS-80 in" to drive the MKS-80, It falls in a terrible midifeedback. I try to use another device to drive the MKS-80 on Cubase and all seems good, but I can't use the "all midi inputs" to drive the other synthezisers because the MKS-80 transmits the notes previously insert.
2) Cubese doesn't recognise the movements of MPG-80 faders.
Do You know a solution for these problems
Thanks!
Manuel
P.S. Excuse me for my terrible English...
PROBLEMS:
Thanks!
Manuel
