Tom der Wessi
hat das noch eine Firma genutzt... damals ? korg ?
DIN Sync
Roland and Korg both used an interface known as DIN Sync for synchronizing drum machines and sequencers. DIN Sync is named for the 5-pin DIN connector used; it's the same connector used for MIDI, but DIN Sync is an entirely analogue interface and, of course, is not at all compatible with MIDI. DIN Sync provided a basic 24 or 48 pulse-per-quarter-note (ppqn) signal, as well as start/stop controls. Roland's DIN Sync machines used a 24ppqn clock, and include the TB-303 (input only), TR-606, TR-808, CR-8000, MC-202, and TR-909 (input only). Korg equipment such as the DDM-110, DDM-220, and KPR-77, however, used a 48ppqn clock. If you sync Korg and Roland together, the Korg will run at half speed.
A number of machines exist that can convert between MIDI clocks and DIN Sync clock. The Korg KMS-30 has MIDI in/out, Sync in/out, and tape in/out. Any of the three can be the master clock, and the Sync connections are all switchable between 24ppqn and 48ppqn. The Roland MSQ-100 and MSQ-700, though both intended primarily as sequencers, can both convert between MIDI and Sync clock. The Roland SBX-10 and SBX-80 are both intended as dedicated sync boxes and offer more features. Kenton's Pro-4 also outputs DIN Sync clocks from a MIDI signal. Garfield also made dedicated sync boxes; the Masterbeat, for example, offers a bewildering variety of sync options.
