micromoog
Rhabarber Barbara
Nur zur Info - hier gefunden:
http://midisoft.de/OBXA/OBXA_magicBox.html
NEW! now available for The Oberheim OB-Xa analog Synthesizer.
OB-Xa MIDIcontrol is a plug & Play MIDI-Interface for The OB-Xa 37Pin COMPUTER PORT.
This interface transforms your OB-Xa into a realtime MIDI controlled Synthesizer.
The interface needs an external DC power supply (not included)
The power supply should output 5…9V DC where the center pin = (+)
If you don't like to use an external power supply (as I do) you can supply your interface from the OB-Xa by doing a Little modification.
Plug & Play
Plug the OB-Xa MIDIcontrol into your DB37 connector at the rear panel of your OB-Xa
and you have real time access to all 41 Parameters, 56 additional ROM presets, 56 additional USER Memory, EDIT, COPY, PASTE, STORE, Program Change, Pitch, Modulation, SysEx and much more.
The OB-Xa MIDIcontrol gives you total control and fully expanded capability of 56 additional sound presets and 56 additional user memory patches. The patches can be stored, and load via MIDI SysEx and completely controlled, edit and saved in realtime with MIDI cc. You can transfer patches to other OBXa (equipped with this magic box) or any computer, iPad or iPhone. Important to know, that no battery is needed to hold all memory in the box.
OB-Xa MIDIcontrol stores all parameters in its own Flash ROM, including the additional 56 factory patches and the additional 56 user memory patches. We leave the Oberheim internal patches completely untouched.
OB-Xa MIDIcontrol allows realtime control of note-on/off, pitch, modulation and all other OB-Xa parameters as well as MIDI Tune Request and several additional features. All parameter adjustments are done by any MIDI remote control e.g. Behringer BCR2000, iPAD, iPOD, iPhone, computer or any other MIDI-controller.
Installation is much more easy than any other MIDI retrofit.
No modification, no service, no drills are needed, just plug the magic box into the 37-PIN connector at the rear panel of your OB-Xa,
That’s it, it’s that easy.
Feature list:
23 Encoder parameter
23 Switches parameter
CC# 06 VCF RELEASE
CC# 07 VCA RELEASE
CC# 08 VCF SUSTAIN
CC# 09 VCA SUSTAIN
CC# 10 VCF DECAY
CC# 11 VCA DECAY
CC# 12 VCF ATTACK
CC# 13 VCA ATTACK
CC# 14 PULSE WIDTH
CC# 15 RESONANCE
CC# 16 VCF ENV AMOUNT
CC# 17 LFO RATE
CC# 18 FM MODULATION
CC# 19 PULSE MODULATION
CC# 20 PORTAMENTO
CC# 21 VCF FREQENCY
CC# 22 OSC 2 DETUNE
CC# 23 OSC 1 FREQUENCY
CC# 24 OSC 2 FREQUENCY
CC# 77 MOD WHEEL AMOUNT
CC# 120 NUMBER OF VOICES
CC# 85 Preset 1…56 select
CC# 86 User Memory 1…56 select
CC# 25 (ch3) OSC 2 FM
CC# 25 (ch4) VCF FM
CC# 25 (ch5) UNISON
CC# 25 (ch6) LFO WAVE SINE
CC# 25 (ch7) LFO WAVE SQUARE
CC# 25 LFO WAVE S&H (Sine&Square off)
CC# 25 (ch OSC 1 FM
CC# 26 (ch3) OSC 1 PWM
CC# 26 (ch4) OSC 2 PWM
CC# 26 (ch5) OSC 1 SAW ON/OFF
CC# 26 (ch6) OSC 2 SAW ON/OFF
CC# 26 (ch7) SYNC
CC# 26 (ch F_ENV
CC# 27 (ch3) VCF KEY TRACK
CC# 27 (ch4) OSC 1 PULSE ON/OFF
CC# 27 (ch5) OSC 2 PULSE ON/OFF
CC# 27 (ch6) OSC 2 HALF
CC# 27 (ch7) 4-POLE
CC# 27 (ch NOISE
CC# 79 KBD MODE (MEMORY / CYCLING)
CC# 87 Load: Preset/User Memory
CC# 88 Save: Preset/User Memory
CC#107 Dump: All User Memories
The OB-Xa MIDIcontrol works with any OB-Xa.
MIDI OUT hardware:
There is only one MIDI Jack, but if required, you can use the free MIDI jack pins 1,2,3 for the MIDI OUT functions.
All you need is a MIDI Y-Split cable, and here comes the pin out:
Use such a MIDI Y-Split cable to connect MIDI OUT to the BCR2000 (or iPAD) MIDI IN
and connect MIDI IN to the BCR2000 MIDI OUT B/THRU (or to MIDI OUT of your iPAD MIDI-Interface)
MIDI OUT functions:
1. MIDI SysEx dump
CC 107 (value 127) tells the interface:
Send a MIDI SysEx dump of all 56 user memories to MIDI OUT.
So you can backup all your programs.
Of course you can send back these SysEx files via MIDI to your interface.
This will replace all your current user memory locations automatically.
2. PARAMETER FEEDBACK
After a MIDI Program Change or a Program Load, the interface sends
the current program parameter values to its MIDI OUT pins. If a BCR-2000
or an iPAD receives such a parameter feedback, then a BCR-2000 as well an iPAD
will display all parameter values. Now you know exactly where you are and you
can visually edit your program relatively to the current settings.
To avoid MIDI feedback loops using a BCR2000, set the BCR2000 Global setting to S-3 by pressing
EDIT & STORE, then dial the upper most left encoder until the display shows S-3
and at least press the EXIT button.
Plug & Play
Feature list:
CC# 06 VCF RELEASE
CC# 07 VCA RELEASE
CC# 08 VCF SUSTAIN
CC# 09 VCA SUSTAIN
CC# 10 VCF DECAY
CC# 11 VCA DECAY
CC# 12 VCF ATTACK
CC# 13 VCA ATTACK
CC# 14 PULSE WIDTH
CC# 15 RESONANCE
CC# 17 LFO RATE
CC# 20 PORTAMENTO
CC# 21 VCF FREQENCY
CC# 22 OSC 2 DETUNE
CC# 25 (ch4) VCF FM
CC# 25 (ch5) UNISON
CC# 25 (ch OSC 1 FM
CC# 26 (ch7) SYNC
CC# 26 (ch F_ENV
CC# 27 (ch7) 4-POLE
CC# 27 (ch NOISE
MIDI OUT hardware:
MIDI OUT functions:
1. MIDI SysEx dump
