Kernel Bug
marco93
Shnitzled in the Negev
Mir ist die letzten Woche nun schon zweimal das System kurz nach dem Einloggen eingefroren In beiden Fällen sehe ich das hier:
[drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:42:pipe A] flip_done timed out
Ist das definitiv ein Kernel Bug und sollte man den melden?
Code:
Jul 26 20:26:21 marco-MS-7817 kernel: [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:42:pipe A] flip_done timed out
Jul 26 20:26:22 marco-MS-7817 systemd[1]: systemd-fsckd.service: Succeeded.
Jul 26 20:26:21 marco-MS-7817 systemd-timesyncd[667]: Initial synchronization to time server 91.189.94.4:123 (ntp.ubuntu.com).
Jul 26 20:26:21 marco-MS-7817 systemd[1]: Starting Daily apt upgrade and clean activities...
Jul 26 20:26:21 marco-MS-7817 systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 26 20:26:22 marco-MS-7817 systemd[1]: blueman-mechanism.service: Succeeded.
Jul 26 20:26:23 marco-MS-7817 systemd[1]: apt-daily-upgrade.service: Succeeded.
Jul 26 20:26:23 marco-MS-7817 systemd[1]: Finished Daily apt upgrade and clean activities.
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: JACK MIDI <-> ALSA sequencer MIDI bridge, version 9 built on Sun Oct 13 18:36:50 2019
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: Copyright 2006,2007 Dmitry S. Baikov
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: Copyright 2007,2008,2009,2011,2012 Nedko Arnaudov
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: Bridge starting...
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: Using JACK server 'default'
Jul 26 20:26:27 marco-MS-7817 autojack[2631]: Hardware ports will be exported.
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: Cannot read socket fd = 6 err = Success
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: CheckRes error
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: JackSocketClientChannel read fail
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: Cannot open a2j client
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: ERROR: a2j_jack_client_create: Cannot create jack client
Jul 26 20:26:32 marco-MS-7817 autojack[2631]: ERROR: a2j_start: a2j_new() failed.
Jul 26 20:27:04 marco-MS-7817 kernel: rcu: INFO: rcu_preempt self-detected stall on CPU
Jul 26 20:27:04 marco-MS-7817 kernel: rcu:         0-....: (60004 ticks this GP) idle=7ca/1/0x4000000000000002 softirq=23094/23094 fqs=14881
Jul 26 20:27:04 marco-MS-7817 kernel:         (t=60000 jiffies g=11765 q=87882)
Jul 26 20:27:04 marco-MS-7817 kernel: NMI backtrace for cpu 0
Jul 26 20:27:04 marco-MS-7817 kernel: CPU: 0 PID: 2446 Comm: jackdbus Tainted: G           OE     5.4.0-77-lowlatency #86-Ubuntu
Jul 26 20:27:04 marco-MS-7817 kernel: Hardware name: MSI MS-7817/H81M-E34 (MS-7817), BIOS V17.5 03/30/2015
Jul 26 20:27:04 marco-MS-7817 kernel: Call Trace:
Jul 26 20:27:04 marco-MS-7817 kernel:  <IRQ>
Jul 26 20:27:04 marco-MS-7817 kernel:  dump_stack+0x6d/0x8b
Jul 26 20:27:04 marco-MS-7817 kernel:  ? lapic_can_unplug_cpu+0x80/0x80
Jul 26 20:27:04 marco-MS-7817 kernel:  nmi_cpu_backtrace.cold+0x14/0x53
Jul 26 20:27:04 marco-MS-7817 kernel:  nmi_trigger_cpumask_backtrace+0xfa/0x110
Jul 26 20:27:04 marco-MS-7817 kernel:  arch_trigger_cpumask_backtrace+0x19/0x20
Jul 26 20:27:04 marco-MS-7817 kernel:  rcu_dump_cpu_stacks+0x99/0xcb
Jul 26 20:27:04 marco-MS-7817 kernel:  rcu_sched_clock_irq.cold+0x25e/0x4f0
Jul 26 20:27:04 marco-MS-7817 kernel:  update_process_times+0x2c/0x60
Jul 26 20:27:04 marco-MS-7817 kernel:  tick_sched_handle+0x29/0x60
Jul 26 20:27:04 marco-MS-7817 kernel:  tick_sched_timer+0x3d/0x80
Jul 26 20:27:04 marco-MS-7817 kernel:  __hrtimer_run_queues+0xf7/0x2c0
Jul 26 20:27:04 marco-MS-7817 kernel:  ? tick_sched_do_timer+0x60/0x60
Jul 26 20:27:04 marco-MS-7817 kernel:  hrtimer_interrupt+0x109/0x220
Jul 26 20:27:04 marco-MS-7817 kernel:  smp_apic_timer_interrupt+0x71/0x170
Jul 26 20:27:04 marco-MS-7817 kernel:  apic_timer_interrupt+0xf/0x20
Jul 26 20:27:04 marco-MS-7817 kernel:  </IRQ>
Jul 26 20:27:04 marco-MS-7817 kernel: RIP: 0010:read_tsc+0x3/0x10
Jul 26 20:27:04 marco-MS-7817 kernel: Code: 5d c3 90 90 90 90 90 8b 05 66 e0 80 01 c3 66 0f 1f 84 00 00 00 00 00 c3 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 0f 01 f9 <66> 90 48 c1 e2 20 48 09 d0 c.3 0f 1f 00 8b 0d ea 83 ae 01 48 89 f8
Jul 26 20:27:04 marco-MS-7817 kernel: RSP: 0018:ffffb32e40e5bea8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff13
Jul 26 20:27:04 marco-MS-7817 kernel: RAX: 00000000068f6570 RBX: ffffb32e40e5bf00 RCX: 0000000000000000
Jul 26 20:27:04 marco-MS-7817 kernel: RDX: 0000000000000044 RSI: 000000000000001f RDI: ffffffffaf030ca0
Jul 26 20:27:04 marco-MS-7817 kernel: RBP: ffffb32e40e5bec8 R08: 0000000000000000 R09: 0000000000000000
Jul 26 20:27:04 marco-MS-7817 kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
Jul 26 20:27:04 marco-MS-7817 kernel: R13: 00000000000248f4 R14: 0000000000000000 R15: 0000000000000000
Jul 26 20:27:04 marco-MS-7817 kernel:  ? recalibrate_cpu_khz+0x10/0x10
Jul 26 20:27:04 marco-MS-7817 kernel:  ? ktime_get_ts64+0x4c/0xe0
Jul 26 20:27:04 marco-MS-7817 kernel:  poll_select_set_timeout+0x50/0x80
Jul 26 20:27:04 marco-MS-7817 kernel:  __x64_sys_poll+0x97/0x150
Jul 26 20:27:04 marco-MS-7817 kernel:  do_syscall_64+0x57/0x190
Jul 26 20:27:04 marco-MS-7817 kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Jul 26 20:27:04 marco-MS-7817 kernel: RIP: 0033:0x7f8d053a4aff
Jul 26 20:27:04 marco-MS-7817 kernel: Code: 54 24 1c 48 89 74 24 10 48 89 7c 24 08 e8 79 1c f8 ff 8b 54 24 1c 48 8b 74 24 10 41 89 c0 48 8b 7c 24 08 b8 07 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 2b 44 89 c7 89 44 24 08 e8 ad 1c f8 ff 8b 44
Jul 26 20:27:04 marco-MS-7817 kernel: RSP: 002b:00007f8d04626d50 EFLAGS: 00000246 ORIG_RAX: 0000000000000007
Jul 26 20:27:04 marco-MS-7817 kernel: RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 00007f8d053a4aff
Jul 26 20:27:04 marco-MS-7817 kernel: RDX: 0000000000007cff RSI: 0000000000000002 RDI: 000055a45ca1eec0
Jul 26 20:27:04 marco-MS-7817 kernel: RBP: 000000000484ea79 R08: 0000000000000002 R09: 00007f8d04626d58
Jul 26 20:27:04 marco-MS-7817 kernel: R10: 00007f8d04626d50 R11: 0000000000000246 R12: 0000000000000001
Jul 26 20:27:04 marco-MS-7817 kernel: R13: 0000000000000001 R14: 00000000ffffffff R15: 000055a45ca86070
Jul 26 20:27:56 marco-MS-7817 systemd[1]: Starting Ubuntu Advantage APT and MOTD Messages...
Jul 26 20:27:56 marco-MS-7817 systemd[1]: ua-messaging.service: Succeeded.
Jul 26 20:27:56 marco-MS-7817 systemd[1]: Finished Ubuntu Advantage APT and MOTD Messages.
Jul 26 20:28:00 marco-MS-7817 kernel: usb 5-1.3.4: USB disconnect, device number 8
Das sieht so aus als hängt es mit dem Jack Client oder Daemon zusammen.
Hast du es mal ohne autojack versucht?
Melden kann man das, schaden kann es nicht... Im schlimmsten Fall wirds geschlossen oder nicht bearbeitet.
Welche Distro? Welcher Kernel?
PS: seh grad ubuntu im log... Viel erfolg, ich hab leider keine guten erfahrungen mit bugreports bei ubuntu...
Wenn jack rumzickt muss es nicht immer gleich der Kernel sein.
Außerdem, 5.4? Bevor ich da was melde würde ich erstmal ein Update probieren.
Edit: die Meldung kommt ja nicht vom Kernel, sondern von autojack
Wo seht ihr denn, dass es an Jack liegt?
[drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:42:pipe A] flip_done timed out hat irgendwas mit der Graphik zu tun sagt mir google.
--> hab es schon gemeldet, aber vermutlich im falschen Bereich: https://bugs.launchpad.net/ubuntu/+bug/1938076
Sorry, ich habe den Error nicht in der ersten zeile gesehen...
Könnte am drm-kms-helper liegen:
Ja genau, aber die user betraf es nur beim Booten. Ich kann mich ja anmelden. Dann erst friert es nach einigen Sekunden.
