Chips in Synthesizers
Aus Synthesizer Wiki
Version vom 13. April 2024, 21:59 Uhr von Moogulator (Diskussion | Beiträge) (→‎DSPs)
(Unterschied) ← Nächstältere Version | Aktuelle Version (Unterschied) | Nächstjüngere Version → (Unterschied)
Hardware Chips - Synthesizer
Analog Synths today - based on SSM / CEM
  • after the death of Doug Curtis there are a number of clones available by ALFA and Behringer/Music Tribe under the brand of "Cool Audio". There is also: "Sound Semiconductor" OnChip - is the last one remaining after SSM/Curtis as the old one - strangly.
atm it is easy to pick up one of the first 3 right now - ALFA has them for about 7€ per item which makes it totally possibly to make analog (poly)synths again in 2018 and later.
List Synthesizers - Analog + Vintage
Akai
AX80 8 - CEM3372 24dB/Oct Filter/Mix/VCA "Processor"
Banana (created by EEH / Syntec, since 1999 the SSB is closed..)
Cheetah
CMI
Crumar
DSI /SCI see SCI/Sequential
Doepfer
A107 Morph. Filter: CEM3379 A121 Multi Mode Filter: CEM3320 A122 LPFilter: CEM3320 A123 HPFilter: CEM3320
A-109 VC Signal Processor (CEM3379) A-111-1 High End VCO (CEM3340) A-130 VCA (linear)/A-131 VCA (exp.) (früher/earlier: CEM3381/CEM3382, heute/today CA3080) A-134 VC Panning (CEM3381)
Und vermutlich - possibly: A111-2 Dyn. VCO CEM3394.
Elka
Synthex 8 CEM3320 VCF
Ensoniq
Mirage 8 CEM3328 VCF
Keytek
Kawai K3
____________________________________________________________
Korg
DSS1 / DSM1 SSM (no?)
Poly 61 6 SSM2056 EG
Linn
Moog
more v'ger see my moog page..
Oberheim
Prommer 1 CEM3328 VCF
Octave Plateau
Cat SSM2044 Filter
Paia
PPG
Wave 2.0 4 CEM3320 VCF 4 CEM3310 EG
Wave 2.2/2.3 8 SM2044 VCF - info: - ssm2044.pdf 4 CEM3360 Dual VCA
Fender / Rhodes
Roland
Roland SH101 and MC202 1 CEM3340 VCO roland sh101 MKS-20 5 CEM3360 Dual VCA
RSF
Sequential Circuits / DSI
VS 1 CEM5510 Fast Sample/Hold 1 CEM5530 30ch S/H 8 CEM3382 Dual Low Noise VCA 8 CEM3378 VC Signal Processor - CEM3372 Filter/Mix/VCA UPDATE: VS used 2 x CEM5530,4 X CEM 5510 (8chan s/h),2 X CEM3365(dual vca for vector mix)
PROPHET 5 - the first Prophet 5 series used the SSM filter, laterthey were changed to CEM Prophet 5 Rev 3 11 CEM3340 VCO 10 CEM3310 EG 5 CEM3320 VCF
MAX 6 CEM3394 uP Voice
Siel
Simmons Drums
SDS8 5 CEM3372 VC Signal Generator -->CEM3372 Filter/Mix/VCA
Solton
Steiner Parker
Synton
Waldorf
Microwave microwave 1 8 CEM3387 VCF,VCA,VCP (later models) 8 CEM3389 VCF,VCA,VCP (early models) the revision was app. at the same time as waldorf changed to the Nextel-Housing --> "old" eloxiertes Gehäuse (housing) = 3389 - Nextel-Gehäuse (housing) = 3387 it's know exactly know if there are also a small amount of old/new CEMs in the vice versa housings, but it is most likely the same date.. ;) microwave 1 opened
the Q naked (non analogue version) BOARD - eine nackte nichtanaloge Kuh PLATINE ;-) (thanks to midicase.com! for the pic of the board!)
waldorf q boardwaldorf q+
Yamaha
DSPs
what DSP in what synthesizer? - welcher DSP in welchem synthesizer? Motorola renamed to Freescale and afterwards out of business, so here the names corresponding to their release:
Access Virus A — Motorola 56303 Access Virus B — Motorola 56311 Access Virus C - Motorola 56362 Access Virus TI - 2x Freescale DSP 56367 Access Virus TI2 - 2x Freescale DSP 56367. Later models used DSP56321
Waldorf MW2/XT — Motorola 56303 Waldorf Q — Motorola 56303
Clavia Nord / Micro Modular — Motorola 56303 Clavia Nord Modular — 4 Motorola 56303 Clavia Nord Lead 3 — 6 Motorola 56362
Novation SuperNova — Motorola 56303 Novation Nova — 5 Motorola 56362 (synth) 1 Motorola 56303 (fx)
Korg MS2000 / Microkorg — Motorola 56362
TC Electronics PowerCore - 4x Freescale DSP 56367
Waldorf
waldorf q board
Korg
Clavia
Novation
Radikal
Creamware
Access
Access Virus A --- Motorola 56303 Access Virus B --- Motorola 56311 virus c - unknown motorola (1x DSP !) virus caccess virus C
Quasimidi
Quasimidi Polymorph --- Dream SAM9707
Alesis
Emu
EMU Coldfire 33Mhz for the Audity2000 and 40Mhz for the Proteus2000
btw: please keep in mind that the only cool 303 is the 56303 ;-)
Links
