Midi Merger
Merges 2 or more MIDI Signal into one, it's not possible to simply "split" Midi Signals or mix it together, in this case case you need a MIDI MERGE BOX = Midi Merger.
Diese kleine Box macht es möglich mehrere Midi-Signale zusammenzumischen, man kann Midi Signale nicht einfach zusammenführen oder Splitten!
- Pilarik & Elger PMM88 + PMM44 (4 / 8 Ports) - very flexible
- Midi Solutions Midi Merger
- Waldorf Midibay
- Roland UMM88
- Doepfer MMR4/4
- Edirol UM550
- Any modern 8-Port-Midi-Interface like Emagic (now Apple) AMT8 + Unitor 8, Esi,
- Motu timepiece series and many more..
if you eg have 2 sequencers chained via thru you can use the clock via thru OR the midi out.. so if you want both you need to merge the midi ports digitally, same with controlling 1 synth from 2 keyboards or sequencers..
- see also Midi Thru Box
